Everything posted by Dushyantha
- Buying A Used Hybrid Car
Lancer Ck2 Engine Mounts
U could use brand new aftermarket mounts from Panchi . would be better than using recon ones and recon engine mounts wouldnt last long since they would be old and rubber tends to degrade and harden over time . But best is to go for the genuine brand new mounts coz even aftermarket mounts dont sometimes come upto the genuine standard .
Mg 6 Turbo Petrol
A car made in china for 6.3ml ?? not sure thats a good idea
Vibration On Radiator/ac Fan
Check if the fan is wobbly . Could be that the fan bearings are worn out and causing the vibration .
- Viva Elite Full Option Car Issue In Fan Belt
Vibration/rattle Sound Under Dashboard When Hot
Do not take it to your local mechanic if it involves the removal of your dashboard . Better ask the agents on what their opinion is , coz there are some models which develop creaks and vibrations in the same places due to the padding which gets harder due to the hot climate here .
The fans are fixed to the radiator itself with small rubber bushes and the radiator is fixed to the car with another set of rubber mounts . Fans usually dont make that much of a vibration unless the fan blades are broken or something . did you check if both the fans are not missing any blades ?
Side Skirts & A Spoiler For Lancer
U would be able to find a good original spoiler for less than 20K from Panchikawatta i suppose. Not sure about the sideskirts .
Tax Change On Vehicles
u could watch a youtube video . easier to understand . what i learned by doing a google search was that the atkinson engine was a special engine where complicated mechanical parts were used to make the piston travel further on the power stroke than on the compression stroke hence an increase in the expansion ratio compared to the compression ratio on the same cycle whereas a normal otto cycle would have the same expansion and compression ratios . this setup included so many compicated moving parts and as u know the more the moving parts theres more chance of a failure occuring . somehow this type of engine didnt become popular . another thing was that since the volume of air during the compression cycle was reduced there was a considerable loss of power . Prius does not operate on the original design of the atkinson engine but simulates this atkinson cycle engine behaviour in a more cost effective way by manipulating the valve timing so that in the compression stroke the intake valve is kept open untill the piston goes a bit up some air is again pumped back through the intake valve and the compression starts after the piston travels a bit up . In the end what happens is that there would be a higher expansion ratio compared to the compression ratio . in other words the piston moved a larger distance during the power making stroke compared to the compression stroke so energy is saved in moving the piston compared to a normal otto cycle due to the smaller distance it has to travel . draw back of this is that it produces less power due to the lower compression ratio . where the prius uses an electric motor to compensate for that . there are other cars like mazas which runs on the otto cycle but depending on the situation switches to the simulated atkinson cycle by manipulating the valve timing .
Rowan Atkinson ? the difference of atkinsons car to a normal car? hmmm let me see . the pad lock fixed door ?
Strange Hissing Sound?
Can a tiny leak in the exhaust cause a hissing sound ? and then once it heats up , maybe due to expansion the leak gets smaller that the hissing isnt heard . better check your exhaust pipes for any damage
Even if the equipment at the emission test was working correctly the HC emission would greatly depend on the engine temperature and the outside temperature . so . a small deviation like that would be negligible i suppose . And i think the petrol pump in the lancer is located inside the fuel tank itself . Hence there wouldn't be much of a sound . There maybe a possibility that i may be coming form the petrol pump as the mechanic said . edit: just remembered . you could check if its the petrol pump by getting someone to switch on the car but not start it after keeping the car for sometime. so that the petrol pump works for a small time to prime the system . if its the same sound . then it sure is the pump
- Post Whoring - Part 2
- Help With My New Cs3
Advice On Buying A Mitsubishi Used Car
Thanks davy . Found the thread .Came in very useful when i was searching for a mitsu myself . but wasnt of much use when i was searching for a mitsubishi obd scanner . Yaman . if you want more details about the CS model go to the thread link below . and better post your questions there . http://forum.autolanka.com/topic/15687-help-with-my-new-cs3/ Jor-el . that adapter costs almost 17000LKR (8000LKR for the adapter and 8500 for shipping ) . hence nearly costs as much as a cheap double din
cant think about any cons Pros- Its a japanese car and much more comfortable than most jap cars Search the forum . there are some threads with info about the CS model 150000 kms is ok if its a genuine mileage . and about the current market - can be anywhere from 2.6 to 3 mn or more (depends on the condition of the car ) You get what you pay for . A well maintained car would probably cost much more than a poorly maintained car . however if you are somewhere near Colombo you could take it to the agents and get the car checked for a fair amount of money . A GLX would have power mirrors , power shutters , ABS and dual airbags . CHeck if all these systems are working correctly , Common cheap jimlart repairs that some broker type car sellers do is if there is a fault with the Air bag or ABS they take out the ABS or airbag bulb or wire it to some other indicator bulb such as the oil pressure light or check engine light . or vice versa where the engine light is wired to turn off with the abs or airbag light . so get it checked It is hard to drive for 150000kms in srilanka without facing some kind of accident , at least a dent . so check that any accident repairs are done up correctly .Also check for minor things like worn out brakepads , tyres , drive belts , CV joints and suspension related parts .check If theres any oil leaking from the shockabsorbers , if so they would need replacing . things like these add up and when you realize that theres a ton of repairs to do after spending all ur money on a car , its too late . so better keep some money for doing repairs if u notice any . Edit :Remembered a Con point . - U cant fix a double din player without fixing an adapter which costs as much as a cheap double din unit .
CS1 - 1300cc CS2 - 1500cc CS3 - 1600cc For 2.2mn u would be able to find a CS2/3 YOM 2003 or 2004 i guess 1) They are sedans so dont expect fuel figures like in hybrids or hatchbacks . CS2/CS3 wouldnt hav much difference in fuel consumption and the auto would do 1 or 2 kmpl less than the manual. 2)Full option comes as GLX with ABS ,airbags and PS ,PM 3)They are jap cars and maintenance/spares wouldnt be a problem. 4) CS2 and CS3 are 1500 and 1600cc respectively 5) CS cars after 2007 had minor upgrades than the older 2003 models 2003-2006 has a different old style steering wheel than the 2007 upwards model Front grille is more roundish and small than the 2007 upwards model 2003-2006 basic models did not come with power shutters whereas from 2007 upwards all CS models came with power shutters. both facelift and the old 2003 models have the same engine and suspension . 6)U could squeeze out some more KMPL out of a manual than an auto . No other issue other than that between auto and manual. Thigs to look for when buying . If it was owned by a company and the meter reading is like 100000kms then probably the meter is altered . If u still want to buy it although the meter is altered Get the engine checked through the agents. CS1 Auto would have less pulling power . try to go for a cs2 or cs3. Ive seen an autogear lancer CS2 with 200000km on the odo running fine . if the car was maintained properly dont get scared of the mileage. Check things like suspension bushes and shockabsorbers coz a suspension repair on these are costly. You wouldn't be able to identify the difference between a cs1 /cs2/ cs3 from outside or the interior unless you check the Model number. They have hydraulic operated clutches so if the clutch pedal feels spongy . then its probably time to replace the clutch pumps. When the Abs light goes off u will hear a relay switching off "tick" sound which is normal . Check if the idle up works by switching on the ac . if not . maybe a simple fix as cleaning the Idle valve or an expensive fix such as replacing the idle controller. Take off the spark plug covers and check for oil leaks into the spark plugs . (A common fault in those engines) simple fix , not costly Mobil oil in Mitsubishi engines are known to give sludge problems . so if mobil was used . get prepared do a complete engine flush and use Valvoline instead . (not 100% sure about the credibility of this information coz it is said by the agents, but better safe than sorry ). If an Auto then the auto gearbox would need proper maintenance and periodic oil changes which will make sure the auto box runs forerver without much issue. Gear shifter on mitsubishis are stiff compared with most cars . so if its wobbly , then the bushes at the end of the shifter cable needs replacing . (no idea about cost but wouldnt be much expensive i guess) whatever the seller says , unless he has replaced the timing belt through the agent keep some money to spare for a timing belt change and get it changes as soon as possible. If u want a better look than performance . Buy a 2007 or 2008 facelift model CS1 manual . has some decent ammount of pickup . if ur more of a drive fast person then buy a cs2 or cs3 but for 2.2mn u would have to go for the prefacelift model .
Nissan Leaf Vs Toyota Aqua
well u wouldnt be able to get both driving pleasure and economy both in one car so better decide which u want the most . not much of an idea about the leaf except that it probably is great on pickup and speed , and that charging the car isnt as simple as plugging it into your normal household plug point . it needs special cable and plugs and all sorts of stuff to be set-up . Leaf would be great if u have another car with an internal combustion engine at home . so u could use the leaf for going to the supermarket and stuff and use the other car for long distances . Oh and at some point u would need to replace the Leaf battery and since ur considering economy i think they have stopped bringing down reconditioned batteries from japan due to some environmental issue . hence a brand new battery replacement wouldnt be cheap . since both are Japanese and the srilankan people hav some wierd concept that jap cars are better than european cars u wouldnt hav to worry much about secondhand market. Or U could buy something like a 2000 model BMW 320D which would be better in fuel and provide u with awesome driving experience and would have a better show off than a aqua or leaf . but then they arent economical in maintenance . so .. ur back to the first question ... better to decide if you want a car which is less on economy but a pleasure to drive or a more economical car with less driving pleasure. and if ur choosing between the aqua and leaf .. buy the leaf and rent a car on ur occasional outstation trips rather or u could sacrifice some of that economy and buy the aqua so u wouldn't have to worry about outstation trips. p.s . i would go for an aqua if i had to choose between the leaf and aqua mainly coz i wouldnt wanna calculate the distance i have to travel every time i get into the car .
Cold Start Vibration - Fit Aria 2003
seems like your mechanic isnt very cooperative . Im not an expert but i think the egr doesnt need any special pulse to operate . I have seen people apply grease on injector O rings before fixing them urs maybe a similar situation
Peugeot 307 & 207
plus points Comfortable good handling engines are less prone to wear powershutters, power mirrors, airbags and stuff come as standard on most models some models even have cruise controll and auto wipers , auto headlights and stuff Has more safety features compared to a same year jap car since ur buying second hand , low secondhand market mileage tampering isnt as simple as changing an IC or replacing the instrument panel so in most cases a genuine mileage minus tend to give trouble is not maintained properly most spare parts are only available as genuine hence higher cost only a handful of reconditioned spare part dealers. the multi function display doesnt last very long and costs abt 15k for a recondition one. your average garage baas wouldnt be able to rectify the mysterious electrical faults that sometimes occur due to the complicated electronics A fault which triggers the engine light would require a trip to the agents or some specialist who has an expensive scanner and charges an exorbitant amount of money just to plug it in and read the trouble code. 15-16 year old car . so might have some signs of hidden corrosion If its a recondition car then the mileage is shown in miles so beware of that
- Ek3 Alternator Problem
Recondition Car Or Suv Around 2.0 Million
CS1 is probably better in comfort than the demio but would be low on fuel economy compared with the demio .
- 10 replies
- SUV
- Car
- 2.0 Million
- Recondition
some time back while i was searching for a car i came across a lancer cs1 2007 for and the owner was asking 23.75 as i remember and 80k on the odo . If u are not planing on travelling upcountry regularly then a Lancer CS1 would be good . not as fuel efficient as a viva elite but has more space and comfort when compared to those small cars .
- 10 replies
- SUV
- Car
- 2.0 Million
- Recondition
