Everything posted by PerfMad
Honda Civic Ek3 D15B Engine MAP sensor
how much did it cost you? much appreciated if you can share contact details on the thread as well.. So that someone else can directly contact them in case of a similar issue.
- Sudden Engine Knock When Engaging And Disengaging Ac While Driving In Slow Speeds (10-30Kmh)
@Rumesh88 i checked it today, and there were instances where i didnt get the knock when the engine was bit cold, but once its in working temp. i felt the knock even within 1500 rpm range most of the time.. So as for ur tips, i should start with IACV sensor and then fuel pressure, spark plugs and wires? I personally dont think doing a engine tuneup will be better, i rather check for specifics like above, isnt it? just curious could this be due to a vacuum leak or something as well? do you think i may need to replace this unit? if so any idea how much will it cost?
Ok machan, i will check this today evening and update you on my findings.. Im planning to put the car to garage again to resolve this and one of my rear suspension sound . So i wanted to filter out to least possible issues, that could lead to this prob, rather than replacing or doing any unwanted things blindly..
I wasn't there when they did the tuneup (since it was done on a weekday).. they said they cleaned all the sensors and plugs and wires were in good shape so no need to replace as well. I will start with the fuel pressure then.. Just curious what should be the standard value (as in for an example if the value is less than X, then its preferred to change the pump) ? And i'll check whether it will make the knock is below 1500.. However just curious, either way (even if its below or above 1500) it shouldn't make a knock right?
even after the adjustment, i dont feel any difference in timing though ( i think he just set it back to usual state, since i complained rev have increased ).. however, if i release the gas padel suddenly, then i will get the knock in 1st and 2nd gears specially. But if i release it slowly then it will reduce smoothly without a knock.. Could this be due to petrol starvation ? I dont think mine have replaced the fuel filter nor fuel pump and currently ODO meter reading is close to 190K.. Do you think its better to do a tuneup again? I did one like 6 months ago, due to lack of pulling power.. after the tuneup it was resolved, and still it has good pulling power.. But i dont think they checked the fuel pump pressure..
POOR FUEL EFFICIENCY AE110
This could be due to some issue or worn out parts in ur tranny.. Better to get it checked with some auto gear box repair mechanic..
- Honda City 2001 - Rear suspension noise
Just to add to what u mentioned, he did kept an oil seal for both shock mounts (if thats what connects from inside diky, and tightened the nut saying this should omit any sound if its coming from the shock mount.. but it didnt help either.. So as per you there isnt anyother way than replacing to check noise is there or not? Can you direct me to a good place to get these checked, before replacing? (only if there is no other way to diagnose this issue properly) ??
Hi Davy - Nope, i just bought the shocks only, since care care people told. I just asked my mechanic to get it fixed.. Is there any possibility to identify this is the exact issue, without replacing the shock mount as well? And also if the left side is faulty, is it good to replace left shock mount ONLY? or do I have to replace both together ?
Nope, actually it wasnt the mech, mech's golaya only did it..he didnt use anything, he just used moved it abit based on the sound it revs i guess.. but since the idle was bit higher i think he kept it the same location (not quite sure though).. I really need to get this sorted. all this time i thought this may b due to manual, didnt no it was an issue, until you explained it.. Is there any good place that you can recommend ? How much will it cause just to get this timing re-done the way you mentioned ?
Hi Experts I'm currently having a Honda City 2001 vtec model car, and like month ago i went to do my wheel alignment to Car ***e and found out rear left shock had 0 gas on it, so they asked me to replace mine and come back for the alignment. Therefore I went and bought 2 Tokico shocks and replaced em. However, before shock replacement I had a daga daga noise whenever i go through a shitty road.. Initially i thought this was due to bad shocks, but even after replacing my shocks i was keep getting that same noise from same side. Then i though this could be due to back spare wheel plywood board, and tried removing everything. But noise was there.. So last saturday i went to my garage and asked my mech to check it, then he went down and checked and he said links are weak so need to replace (because it was making some noise after shaking), then i replaced both sides with genuine items which were bought from Tec motors, and even after that i was getting the same noise.. Then he went under the car and asked me to "car eka podak padanna" i did it couple of times so that he can identify the root cause.. But he wasnt able to.. I took the car as i wanted to go somewhere and needed the car so badly. I told i will bring it back on friday. He said needs to remove left shockabsober again and see.. What do you guys think could be the root cause for this sound? Is there workaround to verify the root cause before replacing anything else further ? Hoping to hear from all of you, since i don't wanna replace anything even though its worn out, unless that is what making the noise.. Cheers PerfMad
Hi Rumesh88 I just showed mine to my mechanic (mech ge golaya tamai baluwe), he went with me for a ride and i showed him the exact issue, he said it can be overcome by advancing the ignition (by rotating the distributor position), by doing so Rev increased upto 1000 from 850... Then I told him it got increased and he reduced it, didnt see how it was reduced.. however after adjusting the distributor position, he said now this should be good and go for a ride and see.. but i felt the same feeling. So i took the car because i was in a hurry to to go somewhr else and i told him i will put the car again on friday to get it checked.. My question is, What he did was correct? (adjusting the distributor position) ?? What are the pros and cons in doing so? Im gonna ask him to start testing from spark plugs and plug wires on friday, cz this knock is really annoying when driving in low gears specially...
Ok I will get it checked tomorrow and update you on that.. is there anything else that needs to be checked after that? if everything is fine.. P.S. There were two instances where when i start the car initially i felt sort of a miss, but it was there for like 10-20 secs and just vanished and never came back again...
Hi Rumesh88 - When engine is cold RPM sits at 1500 and then slowly cm down to 800, I never felt any miss though.. i feel it specially lets say i go in the 2nd gear and speed is around 20-30 and if i take the leg off from the padel, then also i get a sort of a jerk.. is that normal...? Same sort of jerk comes when AC engages and kick off during above mentioned speed limit specially.. However i can check what u told, and give my feedback today..
in idle it works smoothly .. i can hardly feel AC is engaging and disengaging.. However my car is a manual, so when i speed within 20-40kmh range and lets say i shifted from 1st to second gear when speed is 20kmh and if suddenly AC kicks in during that time, i feel it bit hard, with a sudden vibration.. other than that it not noticeable
- Gearbox - Lancer C12
Nissan Serena c23 auto gearbox problem
When was the last time you did an ATF oil change? and how many KM's have u done after that? For me it looks like the pressure isn't enough to move the car when its cold in D position. You can try out by changing gear box oil. This may resolve your problem if it hasn't been changed in proper intervals. But if you have done it with recommended intervals + with recommended oil, then ur gearbox has worn out. There are places where you can get it resolved, if not you may have to go for a recon gearbox. Keep us posted on your findings. By the way, to me it looks like pressure loss therefore even if u keep the vehicle in start and in P position for 10-15mins, i suppose you should be able to drive it with putting directly to D position. Just check this out and let us know. Cz One of my cousin had a serena and he faced the same issue and im quite familiar with it. if the gearbox is worn out, then changing fluid will resolve it for few days and not completely.. Issue will arise again after couple of days.
Mazda Demio Shock Absorber Failure
Damn you've got ripped off big time hmm.... I never go to such places. Just find a trust worthy local garage and you can get things done for really reasonable price.. Just to add to what @Vengeance mentioned, i replaced all the oil seals of my honda+ steering rack seals + some steering bushes+new 4liter (mobile) oil can+ new oil filter+some other tiny stuff and for all the stuff it cost me 32000 only including labor (this includes taking the engine and gear box out to replace all the seals) PS. I used all genuine seals from authorized dealer Lessons leanrt -> do not come into conclusions without doing your home work properly, otherwise it will cost you alot. Cz these days its really hard to trust these people.
ABS, Handbreak and check engine bulbs give alarms
Does it idle properly? Just check whether your battery terminals are tightened properly. Bcz recently i had sort of similar issue due to above mentioned reason.. If it doesn't work out, better to get your car scanned ..
Swift starter motor malfunction
Hi DKING Did you have any delays in starting the car prior to stater motor failure (may be like week or 2 prior, for an example you feel like it starts with difficulty, mostly you'll feel like weak battery sort of feeling) ? For me it sounds like your starter motor bushes are gone (assuming battery is fine). Also check your battery terminal whether those are intact tight enough and both positive and negative terminal are clean (no oxide).. Cz last week i faced the same issue, as in my starter motor gave up , worked sometimes but not always.. Initially i thought battery is weak, but then I saw oxide in + terminal, and i cleaned it, and issue resolved.
Transmission issue in Lancer CK2
try panchikawatta.. you should be able to find one for a cheaper price.. UM motors will give you big no's for spare parts.. You won't believe they just asked 1500rs for my lancer gear bush (each). since i needed 4 of them, i just got it re-bushed for lesser cost.
Auto gear box problem in mazda car
Yup as everyone mentioned, when was the last time you did a gearbox oil change? I believe its better to start with a oil flush and see how it works.. If it didnt sort your prob, then you can show this to a professional gearbox repairing mechanic and do the needful repairs/ go for a recon gearbox.. If im not mistaken, these model gearboxes are fairly cheap.. Once when i was hunting for cars, came across with one of these and the owner told me he replaced the gearbox with a recon and cost him around 15-25k (if im not mistaken)
