Everything posted by PerfMad
- Honda City(Gd8) 2004 Cvt Gear Box Issue
Reupholstering Interior Panels
@Davi - I have the same issue in my lancer. Can you please tell me where can we buy these from SL ? I would like to try out this as well. And is there a brand we should look for and roughly the price? Cheers
If you live close to Nawala, then probably it worth checking N@wala cushion works.. I have seen some of their work and its really impressive. Gotta say their work is bit expensive but worth checking it's located on the opposite side of where elcardo was before( just in case you need a land mark)
Hi All Just an update on this.. Today I went to Nilwala motors to check on my cvt gear box issue.. After a trial run he advised me to use this for lil longer cz that slipping issue doesn't come always. And later I asked whether this drive chain can be replaced.. And his answer was Yes. However he mentioned that it will take 2 days for the repair (fingers crossed) but might need to replace worn out parts along with it (i.e clutch plates) and all.. He said it will roughly cost 65000/- which sounds reasonable ? Just posting these since I know there are people who are undergoing the same issue.. Cheers
Nissan Pulsar -Car Cranks But Won't Start (Ga15De-Engine)-Auto
@The Don - Thanks for the lengthy explanation I just gave up that idea
Hi Nimz77 - No worries machan.. I got the required answer.. no more quizes related to this hehe Cheers Keep us posted with your update
Guys just asking.. I know my quiz isn't related to this. But I don't want to create new thread to discuss this. Therefore following are my concerns; I have a Mitsubishi cb1 car (1300 cc carb model) where I'm curious on doing the following may be someday 1. Is it possible to switch my carb engine with a EFI 1500 engine ? 2. If yes, what would be the best suitable engine (racing isn't my highest priority using this as a daily runner)? 3. What are the other things that should be changed along with this swap ? 4. roughly how much will it cost ? only for parts ? Just curious to know that's it.. If anyone can help me out that would be great Note : There are no issues with the carb, just curious to know the cost and needed parts that's all... Cheers
Isn't it too early for an engine to worn out ?? assuming your ado meter readings are correct
- Lancer Silencer
- Lancer Silencer
@The Don - Can you tell me normally where can we do a compression test ? How much does it cost ? and whats the limit which requires engine overhaul ?? @Nimzz - What's the milage of your vehicle ?
hmmmm to be honest im not quite sure about it.. but planning on showing this to my mechanic and get his opinion as well.. This issue could be due to starter motor as well as engine compression..not quite sure.. but it's always better to get the starter motor serviced
My lancer has the same issue.. but i don't worry much..cz this scenario is applied only when the engine is hot.. so at the moment i slightly press the accelerator before i start and it works.. i think mine is due to starter motor hoping to service it in latter stage.. since its not a big issue for me at the moment..
- Lancer Silencer
- Lancer Silencer
Hi Thilinap I know that's the exact response from St@ford.. they first ask to change the oil, and may be engine tuneup.. when nothing works they come to conclusion saying previous owner have used non CVT oil and bla bla... As per the research i have done so far regarding HONDA cvt gear box of these model have a wet clutch system, if im not mistaken and this tends to slip by the time.. If we can replace that part i think we can overcome with this issue.. I cant exactly recall this, cz i read these articles few months back... And is there any new CVT gear boxes available or used ones (cz nobody knows the condition of the used gear box either)... ?? Is it possible to convert this to manual gears ? cz i remember this same model came with manual 6 speed gear box (if um not mistaken).. and how much will it cost to do the change.. I'm checking for alternatives to fix this issue.. I had a chat to ma garage guy, he asked me to check with Nilw@la place.. Hoping to pay a visit soon.. cheers
- Beat Silencer
Hard To Turn The Key
well..to solve your Problem, you can put a security system... after that you just need the key, only to start the vehicle... (just a suggestion)
Tune 4G15 Carburetor
Thanks Kusal.. I just showed mine to my bass... And he checked the spark plugs and found out that only 1 was working well.. other 3, the distance of the tip was too closed (that's what he said) and then he aligned those and cleaned the tip of all 4 plugs and did some fuel adjustments as well.. And asked me to come back after doing 50KM's... So after doing 50Km today itself, i went to show him and he removed the spark plugs to check, and those seems to be cleaned... He asked me to pump full tank again and recheck the consumption.. As per him, now fuel figures should increase... Hope this would do.. I really don't wanna remove my BEAT silencer ... Will update you all once i figure out the fuel figures.. And Kusal, Please do update us on your repair as well Cheers....
@the Don- initially i thought if it makes like 1kmpl difference..that would be fine..not sure whether it has affected even..cz early days i only used this on weekends..so didnt measure the consumption much... but now since i use it daily only this issue came up..hmmm if this im unable to increase it, then sadly i have to remove the beat and fit my stock silencer again
@hrm & @The Don- hmmm.. i think I'll give one last shot..will be going to garage on this saturday to sort this out most probably..im having a doubt is it because of the silencer... but removing that will be my last option.. because daily i go close to 10KM so my plan is to limit it to 1liter To be honest im really careful on throttle unless someone pissed me off hehe and that's why im thinking that it should do atleast 10.. does anybody has a beat silencer installed on their vehicles ? fuel figures change after the beat silencer ? any ideas / experience ?
@hrm - then i think no point of chasing this to increase further but anyhow I'll be most probably going on this weekend to check spark plugs and all are in good condition.. I think that's all i can do with related to this...
Why A/c Not Working Continously
Ya... i think you are correct machan.. Well in that case i have no experience with that sort of issues ... my suggestion will be to show it to an AC mechanic, rather than ruin something while trying to isolate issues (if you are not a PRO on that area)..
Isn't it the required behaviour ?? I mean it's the same in my car as well.. When i switch on the ECON it works for lik ~10 secs then turn off... and then switch back On again.... but when i change it to AC it takes more than 10 seconds.... AC's are not meant to work continuously isn't it ?? correct me if Im wrong... Please ignore my comment if i have misunderstood the question... cheers
