Everything posted by PerfMad
nissan presea long cranking when hot start
This is the place https://www.google.lk/maps/@6.9671699,79.9079507,3a,75y,328.9h,79.16t/data=!3m6!1e1!3m4!1snUOb0Ax5Kcu42UxHRP8k3Q!2e0!7i13312!8i6656?hl=en his contact no - 072 214 2143 (if you are going better go in the morning and stay there and get it sorted, otherwise it will take ages to get ur car as he is a busy person)
- nissan presea long cranking when hot start
Is Honda city a good vehicle to buy?
hell yah. im using 2 of these 2001 and 2004 models for 5+ years now. very reliable and fuel efficient cars
which battery i should use
but if the charging system is working correctly regardless of the battery status should it show 14v when charging under load ?
So guys my car didn't wanna start today morning. Battery charge indicator was showing "WHITE" jump started it and went to a battery shop. After checking voltage with and without AC and they said charging system is fine, its just the battery is weak and told 45amp battery (exide) will cost around 12k (with 2 year warranty) . I went to another shop and got my battery checked and they claimed battery is fine, its just the charging system is not giving maximum output when AC is turned on (currently its giving ~13V which should be around ~14 right??) Can someone please suggest a proper battery shop to get this checked (to get a third opinion) before replacing my battery blindly. P.S. This battery was bought on 2016 December
I think Exide dealer has it but its not cheap.. the cheapest we found was the LUCAS battery (which supports idle/stop function) costed around 12k
Since it has idle stop function, you can use LUCAS battery as well. One of my friend replaced his grace with the same and costed him around 11-12k
toyota ist 2007 electrical problem
Check whether battery terminals are tightened properly
Honda City 2000-2001 Model Manuals
Did you find one?
- Need a solution for vibration when idle
Project A72V
@varotone where do you live? If you are closer to kotte area, then i can give a contact no of a location (he might be able to resolve your concern as he is well equipped with most of the latest equipment's.
- 189 replies
- 1
- mitsubishi
- a72v
- 1400
- mmc
well , if that's the case you can change the gear oil as well with Honda recommended oil. Um not quite sure about the civic CVT multimatic gearbox, however in my fitaria i was advised to change CVT fluid in 20k intervals. but i usually does it around 15-18k to be on the safe side. if you have a Stafford workshop close to your place, i would suggest you to do the oil change their, their labor cost will be around 1500 and they usually have the recommended oil as well
First of all welcome to the forum.. Assuming a proper tuneup has not been performed recently, i would suggest you to start with it. Probably this could be due to clogged IACV or injectors as well. During the tuneup make sure to check all related components and clean/replace them accordingly..
Check engine comes up when accelarate beyond 2000 RPM
To start with, this car comes with a OBD1 port which is located under left dashboard. Port should look probably green colour or blue. Secondly, most of the garages have the bluetooth scanner. Go for a garage which has the cable scanner and those comes with a OBD1 adapter which can be connected to yours (as far as i know). Best thing is to get it scanned without replacing items blindly. Where do you live? If you are close by i can recommend a garage which has this scanner.
Mecedez Benz E220
True that. Will see i will hunt until end of December probably, by then if i don't find a good one, plan is to give up the idea (may be buy his E250, when he plans to sell it )
Mecedez Benz E220
I checked two petrol versions, and one of them had fabric interior and the other was having leather. Both were facelifts. Went to check one petrol E220 last weekend and that was in really bad condition from inside (lot of rust) and it had a carb engine. Also checked a E300 diesel car, engine was smooth, but interior and body rust was there and paint job was not in good condition. I'm really having a difficult time in finding a good car. So far only option is to opt to E220 which i had a look initially. However my uncle asked me to look for a diesel rather than going for a petrol since petrol will not do more than 7 in city. All the Diesel versions i checked are from 1985-1989 years, except the E300 which was 1992/3. Assuming a 1996/7 E220 petrol (manual) car both interior and exterior in good condition, how much will it worth?
Mecedez Benz E220
- Mecedez Benz E220
There were two variants. The one you referring could be for the non-vtec. I think vtec variant came with 115bhp (if im not mistaken). And yes, true that its bit lighter and you get a decent pickup compared to vehicle which falls under same category i guess.- Mecedez Benz E220
Mine is not that fast. however i own a Honda city 2001 vtec car mate it provides decent amount of power like 115-130bhp i guess- Mecedez Benz E220
True that.. Totally agree with you. I'm actually not in a hurry to sell this. I will only sell this if the buyer is willing to pay my price. I've done alot of maintenance before its due as i initially had plans on keeping this for 4-5 years. This mood swing happened recently after i drove this merc and started liking it too though its not that sporty of fun to drive as mine. I guess i took a wise decision on taking you'll opinion before selling mine. Even one of my friend who owned a 2004 crv sold and bought a w210 and he claimed the parts are way cheaper than his honda- Mecedez Benz E220
True that. Not sure about the issues though. my uncle had a E200 (32-XXXX) which had a 5 cylinder engine swapped and recently he sold it and bought another E250 both are having the same engine. However this one is smoother than the previous and doesn't hear much sound to inside either.. he is the one who changed my mind to buy a Benz He said its a solid car and let's buy a good diesel he doesnt like petrols though hehe But gotta admit car is solid as rock and so comfy and awesome ride for cruising too- Mecedez Benz E220
Hmm.. the thing is i went to see couple of diesels non of them were in good shape. Only these 2 petrols were good. out of them one car is still in really good condition. All other diesels are way out of my budget now i'm thinking whether to sell my daily (just only because i want to shift to a merc or stick to my daily as its still in better condition and is also newer than these old mercs). But i drove a manual E250 and i wanted to own one That's why i wanted to get in touch with all the required information before making the choice. However, thanks for your input. Really appreciate it - Mecedez Benz E220
