Everything posted by Rookantha
Did you buy it? how is the vehicle ? Common faults ? availability of parts, Fuel economy etc ?
I too have a similar problem. Anywhere close to Battaramulla to get the keybarrel repaired ? Thank you
Can you please recommend good quality service providers around Malabe, Battaramulla area to get following done at a resonable price. 1. Touch up 2. Alloy wheel polish/ buff 3. Interior cleaning 4. Head light restoration 5. Engine tuneup 6. Cut and polish 7. Painting 8. Dent repair Thank you
- touch up
- alloy wheel polish
- (and 6 more)
HI, Automotive lubricant oils What do you all think about unmet needs with related to lubricant oil industry (Engine oil − Gear oil − Grease − Hydraulic and transmission fluid) and any issues that has not been addressed by lubricant manufacturers and distributors. Consider brands like Caltex, Mobil, Laugfs, Servo, Hyrax, Toyota, Castrol) (This is for a market survey and pls share your valuable inputs) Thanks
HI, Motor vehicle/ machinery/marine lubricant oils What do you all think about unmet needs with related to lubricant oil industry (Engine oil − Gear oil − Grease − Hydraulic and transmission fluid) Consider brands like Caltex, Mobil, Laugfs, Servo, Hyrax, Toyota, Castrol) (This is for a market survey and pls share your valuable inputs) Thanks
- survey
- heavy vehicle
(and 3 more)
Did you get it repaired ? i have the same problem with my TV? pls let me know details. Thanks
ඇල්ටෝ 800 (2010) 65000km මගේ වාහනයේ සාමන්යයෙන් කාපට් හෝ රලු පාරක යද්දි "ටක ටක" සද්දයක් එනවා. යමක් වදිනවා වගෙ. ඉස්සරහ වම් පැත්තෙන් තමයි එන්නේ. නවත්තලා තියලා යන්න ගත්තම ටිකක් වෙලා ගිහින් එන්නෙ. වලක වැටුනාට සද්දෙ එන්නෙ නෑ. ගරාජ් දැම්මම කිව්වෙ rack එකේ දැති ගෙවිලා කියල. rack බුෂ් මාරු කලා. දැනට දුවලා රැක් එකක් අලුතෙන් දාන්න කිව්වා. මේ ගැන ඔබගේ අදහස් මොනවාද? rack දාන්න කොපමණ මුදලක් වැය වෙයිද?
Hi, I'm also in need of getting following done to my Alto (45,000km). can you recommend a reliable place somewhere around Borella area. 1. Wheel alignment 2. Suspension testing 3. Full inspection (T belt, brake, clutch etc) 4. Headlight alignment Your advice in this regard wold be appreciated
Thanks. I asked from them. They said it'll be around Rs5500 for service and additional for parts. A*W said they'd charge Rs9500 for all.
- 29 replies
- Service
- Full service
(and 3 more)
No. Its not under warranty. Now 25000kms and 5 years. Next service will be after 750kms. Its Maruti Suxzuki Alto (2010) and fuel consumption is 11.5km/l to 12.5km/l in Colombo traffic. One of my friend said (He drives a Lancer CS1) that should be more than that for an Alto? can you suggest a better place to get a tuneup done? or Agents will do a better job?
- 29 replies
- Service
- Full service
(and 3 more)
Thank you for your opinion. But sometimes I feel the pickup is not enough. That maybe because of 800cc engine. I'm not sure. How can I identify whether a tuneup is necessary.
- 29 replies
- Service
- Full service
(and 3 more)
Thank you very much for your detailed explanation. Yes. I read the manual and it clarifies lots of doubts. However I'm still learning about vehicle maintenance. I'm also thinking of getting a tune up done as it has never done previously. (25000kms now)
- 29 replies
- Service
- Full service
(and 3 more)
Hi, Thanks for the response. When I bought the car its done 10000kms and all the free services done by A*W. However after that I got the services done by a local service center (Only Engine oil and filter, air filter changed). I'm really confused why some experience guys say it is not compulsory to change coolant, gear oil, brake oil since there are no issues with the system. Rookantha
- 29 replies
- Service
- Full service
(and 3 more)
Is that so? do you know a good place?
Hi, Did you buy seat covers? from where? how is the quality and price?
Dear Mr. Silvy, Found your email address in Autolanka forum. I'm also a member of the forum. I'd be really thankful if you can share your expert ideas on below matter. I own a Maruti Alto 800 (2010) and 25000km service is around the corner. I have never taken it to A*W for maintenance but thought that I'd take the car there (Rajagiriya Service center) this time as few have recommended and after reading posts in Autolanka. As my knowledge in this side is weak I'd like to get an advice from you. Hope you'll help me. In the manual it says to do the following after 25000kms. 1. Change brake oil (Never changed) 2. Change coolant (Never changed) 3. Change gear oil (Never changed) 4. change spark plugs (Never changed) 5. Do an engine tune up (Never done) 6. Wheel alignment (Done recently) 7. Change Engine oil (Done 20000km) 8. Change Air filter and Oil filter (Air filter changed 15000km and oil filter 20000km) What is you idea about above. Some say it is not compulsory to do all these right after 25000kms done. I've attached a quote from A*W which I was taken few months back. It say all together it'd cost Rs17000. But or last service I only had to spend Rs6500. Pls advise Regards Rookantha
In the manual it says to do the following after 25000kms. 1. Change brake oil 2. Change coolant 3. Change gear oil 4. change spark plugs 5. Do an engine tune up 6. Wheel alignment 7. Change Engine oil 8. Change Air filter and Oil filter What is you idea about above. Some say it is not compulsory to do all these right after 20000kms done.
- 29 replies
- Service
- Full service
(and 3 more)
Hi, Just going through the topic and want share my experiences. At A*W they use a special chemical for underwash? so far it has not caused any issue? what is your idea? Rookantha
Good Tyre Brand For My Alto Car (145 80 12R)
Rookantha replied to sahan84's topic in General Automotive
Hi, You are lucky that you could use MRF original tyres till 50000kms. I've only done 25000kms by my Alto and in the last week found that the steel cord of front right tyre is broken and comes out to the surface. So will have to change tyres. I'd like to know what is the brand you selected to replace MRF? and you replaced again with 145/80 or a one with higher diameter? I wish to replace my tyres with 165/80 or 155/80 and would like to know your idea? Thanks -
In the manual it says to do the following after 20000kms done 1. Change brake oil 2. Change coolent 3. Change gear oil 4. change spark plugs 5. Do an engine tune up 6. Wheel alignment What is you idea about above. Some say it is not compulsory to do all these right after 20000kms done.
- 29 replies
- Service
- Full service
(and 3 more)
good one LOL
Apologies about the posted link. I just wanted to know the idea since this is selling like Unu kawum in ebay and Ali express
