ThushanthaSrimal
Everything posted by ThushanthaSrimal
  1. Guys if I do a engine flush will that help to get rid of the slug? Is it a good thing to for this engine?
  2. No I dont hv records. I recently bought this and the mechanic to whom I went for check the car before buy also said about the slug and also showed it to me. He said that its a normal thing in vios engines and not a big thing to worry about. If I do a engine flush cant I get rid of the sluge? That machanic said it will not.
  3. Ya I got ur point? If I run this for about 20000km more will the things get things worse?
  4. If so the only option is to bore the engine and place new pistons right? If I just keep checking the oil level and run this for about 20000km will that be a big issue? What if I use a ticker oil?
  5. Thankz guys... I ran about 2500km and there was a oil drop around 800ml - 1l. No oil leaks Yes there is slug in the cam area. What is the connection between slug and oil burn...
  6. My car is vios 2007 Recently I have noticed that engine oil level drops with a long range drive My mileage is now 102000 km and Im using 15w40 toyota oil. No white smoke is coming out in noticeable mannar. Will changing the oil to a thicker one solve the issue or will a boring needed? ???? What is the next thicker level of oil? 10w60?
  7. Hi guys, Recently bought a vios 2007. And I find that it is not much comfortable as I expected. I did a front suspention replacement also as those shocks were timed out. Again after the replacement not much comfortable as I expected. Has anyone got some experience on this? Comfortability level compaired with other models?
  8. Thankz dude I had a really big doubt.....
  9. My car is vios 2007 I accidentally found this today? This the belt that drives alternator and compressor. Is this a normal thing a belt have or some kind of joint. These strips are like nylon. Cant see a belt seperation point though. Im confused. Dont think a belt can run with a handmade joint. What is this?
  10. Thankx dude that was very helpful. I bougt it recently and havent done a tune up or pump cleaned. Only done a full service with engine oil, air filter and oil filter changed..
  11. Hi all, My car is Vios 2007 and it has some issues as follows 1. Brake - I have to push the brake paddle more deeper to engage the brakes. Is this normal or can be fixed? Can this be a problem with brake pads? Left side brake pads are worn out more than right side. Is this a indication of a problem in the braking system? 2. Power steering - Turing the steering wheel is little harder compared with other cars. Oil level is not low. Can this be a problem in the belt? 3. Starting need more crank time - To start the engine I have to run the motor little longer compared to my previous car Honda city 2001. Is this a normal thing?
  12. Thank u very much dude. Yep, will do the inspections.
  13. thank u very much dude... How can I find the exact suitable cvt oil type other than asking from a service center? Can't find service manual on the internet.
  14. Anyone has idea on how to identify the vehicles which are effected by floods. Recently Sri Lanka had serious floods specially in western and southern region and vehicles are also victims. When we buy a second hand vehicle(car) how can we check this? If not there can be serious issues. Anyone has ideas, please help.
  15. Hi guys, I'm also going to buy a Fit Aria (GD8). Apart from the procedure mentioned above, what are the other things I can do to check the gear box condition by my self. without taking the car to the agent? And also what about the spare part availability for this model. I have found that most of the spare parts shops even at panchikawatta don't do Honda. My current car is Honda city type z 2001 and had few troubles with finding spare parts. Appreciate if someone can help.
  16. Guys the issue was low oil level. I didnt know that the oil level should be checked when the engine is on. Issue was not there yesterday. Need to check today also...
  17. As you mentioned there is a small oil leak from the gear box. One place was repaired, a sensor oil leak on top side of the gear box. Mechanic couldnt find the exact oil packing and he made a packing from a packing material and placed it. Is this ok or bad?
  18. My car is honda city type z 2001 auto When I start the car cold, lets say in the morning reverse gear not engages at once. It takes some time. Drive gear is working fine. After the engine gets hot working fine. And also shifting from 1 to 2 also takes time with cold start. Run the car for sometime everything works fine..... I changed the oil recently and its only old for 18k km... What could be the problem? Will changing the oil agin be a solution? Or the box replecement? ????
  19. Thankz guys. Those were really helpful. Will try.....
  20. My car is Honda city type z 2001 There was a pair of fog lamps already installed when I bought my car. That pair is not original, no original wiring is found. Each lamp has 4 pins, one pair is for the main lamp and the other pair for the ring (edging) around the lamp. I want to make this ring always on when I start the car and the main fog lamp controlled by the switch which I already have. What is the best and safe place I can get a positive(+) line out for these two rings to light-up?
  21. My car is honda city 2001 type z Idle rpm without ac is 600 and with ac is 900 Isnt this 900 is too low? Ac is not enough when it is parked under a hot sunlight....when running it is more than enough.. How can I increase the idle rpm when the compressor switches on?
  22. Thankz everyone for your comments. Ya I will look into replace with brand new ones. Anyone know a good place in colombo which I can do that. A place with resonable charges.
  23. My car is Honda city type z 2001. My CVs are making noise when turning for a while. It means that they have worn out. Can they be fixed by using grease and new boots? How long can I run with this condition? Is there a possibity of breaking the joints while running?
