Honda Cvt Gear Box, Pls Help
Hi experts,
I'm planning to buy a YOM 2003/4 Honda City/ Fit Aria
As they both have a CVT gear box, which are known for major issues due to poor maintenance, I wolud like to know how to check the condition of the CVT gear box before buying the car. Most of the sellers don't have any maintainance records.
Thanks in advance .
Hi experts,
Thanks in advance .
Get it checked by agents? I think Sta**ord does.
The proper, scientific way would be to get it tested by agents.
You can check for the most common issue with this CVT box (aka the "Honda Shudder') by having the car idle on a road (preferably on an uphill climb), and then floor the accelerator at once. Basically check if it vibrates or shudders when accelerating from a dead stop.
  • Author
Thanks Guys,
Any idea of the Honda City 2004 brand new imported version with 1500cc manual gear box?
Asking price Rs.1.85M ( third reg owner)
  • Author
The manual City I checked found to be the Indian version.there were some corrosion as well.
So still hunting for one.
Btw thanks guys for the feedback,and pls do let me know if u guys know anyone who is selling.
(I'm checking autolanka and ###### )
  • 2 years later...
Hi guys, I'm also going to buy a Fit Aria (GD8).
Apart from the procedure mentioned above, what are the other things I can do to check the gear box condition by my self. without taking the car to the agent?
ย And also what about the spare part availability for this model. I have found that most of the spare parts shops even at panchikawatta don't do Honda. My current car is Honda city type z 2001 and had fewย troublesย with findingย spare parts.
Appreciate if someone can help.
The first thing you can do is check for maintenance records to make sure transmission oil has been changed on time, with the proper type of oil.ย  Issues with the transmission might not be that obvious during a test drive unless you push the car a bit. The things to look for (other than the ones stated above) are rattles and jerks during acceleration and slowing down. It's quite normal in some CVTs for there to be a faint rattle, but excessive rattle and vibration isn't normal.
thank u very much dude...
How can I find the exact suitable cvt oil type other than asking from a service center?
Can't find service manual on the internet.ย
The agent should be able to let you know the recommended oil.ย ย
