Everything posted by ThushanthaSrimal
- Mist coming from AC
Mist coming from AC
Thanks everyone. Did a compressor change due to the problem in the clutch/ pulley. And done a full clean of the system as a part of the repair. And there was a problem in the temperature sensor. It was happened to cut-off around 15 'C. Technician told me that it should run up to 5 'C before cut-off. So he adjusted it using a resistor to cut-off at 5 'C. Can this cause too much load for the compressor? Is this temperature is loo low and responsible for the mist?
- Honda city 2001 AT gearbox issue
My car is honda city 2001 type z auto When i drive my car after a while, lets say in the morning, gear shift from 1st to 2nd does not happen as usual. It takes some time and I have to up the rpm round 3500. After the first shift next gears are changing as usual. And also after that for the entire ride, lets say for the entire day, that problem never happens and all the gears are changing fine. Is this a normal thing or a problem? I have changed the gear box oil recently. My mileage now is 203,000 km.
Buy Honda city 2001 CV joint
My car is Honda city type z 2001. I want to change my CV s Does anyone know a place where I can buy original set for a reasonable price. And round how much will they cost me?
Honda city AC compressor
My car is Honda city type Z 2001. I recently did an AC repair. Clutch and the pulley of the compressor were damaged but the compressor is good. I had to replace the whole compressor as I was in a hurry. Does any one know a place where I can sell my old compressor?
- Alternator current not enough
My car is Honda city 2001 type Z My alternator current seems to be not enough when the AC is on. I checked it with a multi meter and when the engine is in idle with AC on voltage keeps dropping in the batt terminals. Also a sound is coming from the alternator. Can this be a problem in the brushes? I did a alternator coil replacement recently. Can anyone identify the problem? What are the good places for a repair in Colombo?
- Compressor thermal protector
My car is Honda city type z 2001. Recently I repaired my ac compressor due to a problem in the coil. After the repair I noticed that the mechanic has wired the compressor, by passing the thermal protector. Now the ac is not enough when the engine running idle under a hot sunshine. But when I'm driving its fine. Is this a problem with that thermal protector and is it a problem by passing it?
OBD port in Honda city type z 2001
Nop no problems. I'm just curious as you said. And also I want to check the possibility of using an OBD II HUD Speedometer. But I think this model don't have an electrical speed sensor. Is that correct? Speedometer is connected to a cable. Does it means that it doesn't have a electrical one?
- OBD port in Honda city type z 2001
- When to change timing belt
