19
Everything posted by K.o.N.o.S
@fiat fan Hyaenidae is a Web genie. He will definitely help you out 😉. @Hyaenidae How about going way too cheap for something like this https://vi.aliexpress.com/item/1005001726486270.html?spm=a2g0o.cart.0.0.57f638daFX94AG&mp=1&gatewayAdapt=glo2vnm Worth a try?
- 397 replies
- 1
- 397 replies
- 1
finding difficult to find a pair with Dual beam with 35W. 6000k would be fine right?
- 397 replies
- 397 replies
@Hyaenidae My Headlight projector bulbs have seen the better days. It is time to replace. The cost of replacing the OEM bulbs around 325$. Well I am not in a position to spend that much. So I am thinking to go with LED option. I can get it done below 30k. Will it require additional modifications to ensure proper functionality? Your thoughts? BTW I have done several maintenance activities on my car and I will post them here when free.
- 397 replies
- 1
@Hyaenidae BTW, is this what you got ? https://vi.aliexpress.com/item/32720737378.html?spm=a2g0o.productlist.main.11.39731429SXlRvR&algo_pvid=afbdf769-0803-42a9-959a-a6e29875ccfe&algo_exp_id=afbdf769-0803-42a9-959a-a6e29875ccfe-5&pdp_npi=4%40dis!LKR!101481.26!55814.69!!!310.00!!%402103266e17021825095756962ead2a!12000025773942125!sea!LK!1814407703!&curPageLogUid=clNiD6iwp4vU
- 397 replies
That's classy, now I am kicking myself for not getting the same unit. did you get it installed yourself?
- 397 replies
Guys, Humming noise at high speed and slight movement to left when letting go of steering wheel (even after wheel alignment). Is this related to a wheel bearing issue? My other suspension components are in order.
Recon one was 85k Machan. 150k for the brand new unit. Last time when the bumper was removed during the AC repair we were not able to fit it back in properly when assembling. Hence in some areas had to paste it using hard glue to the body. Side markers are pretty good. These are sequential side markers. Saw a youtube video and fell in love right away. About the side mirrors since the car roof is blacked out I think it goes well with the black and blue theme. Anyway that is totally subjective. Well to be honest since replacing spark plugs car is pretty much stationary at home due to fuel scarcity. Have done only 2-3km runs. Hence I am not in a position to comment on FE. I think those Bosh spark plugs are pretty reliable considering that I have replaced at 131k. I assume they still had about 10-15k left on them. I think in Amayama they are a bit less expensive. However so far I have had nothing but positive experience on Partsouq+Aramex shipping. It took only 6 days to arrive at home.
- 397 replies
- 1
Hello Guys, Few repairs were done on the car. Radiator Coolant tank was leaking and upon checking it was tattered in half.replaced with a brand new tank at kandy radiator house.It was such a pain to remove the radiator as I specifically advised to remove the unit without removing the front bumper. It was finally doable and the guy was extremely patient in removing and replacing the unit. Gave him generous tip for a job well done.I was also advised that radiator also was on it's way out. but damn!! the price of the brand new unit is 150000.00rs. Considering the cost definitely not doable at this point of time. Cost for the tank and the coolant-19000.00rs As of late I have been having starting issues where the car was hesitant to start at the first go.The situation got worse after a few days and my mechanic examined and advised that the problem is definitely with the starter motor and needed immediate service. Service was done at Roshan auto electronics where the starter Brusher and the starter solenoid had to be replaced.Roshan electronics are pretty much starter motor specialists they had the brand new units so replaced them right away. Starter brusher- 2800.00rs Starter solenoid- 5800.00rs Labour charges-2000.00rs Total- 10600.00rs As I mentioned on an earlier maintenance thread my long due spark plug replacement was finally done. (after almost 13 years). Ordered through partsouq and arrived at home via Aramex. Cost for the spark plug set and 4 bumper clips- 86.32$ Total cost-36700.00rs (including shipping and 4700.00rs tax charges) and finally some small aesthetic touches. Headlight cover was polished and resurfaced. front grill Mitsubishi badge was turned to black (since I am not a fan of chrome accents). Steering wheel was wrapped with leather cover (Hand Knitted). Side mirrors were wrapped with carbon fiber sticker. Smoked side markers were Installed. Cheerz.
- 397 replies
- 3
Planning on b***** Politician Houses? 😄
19009.00rs for just over 42 litres. Actually to my surprise the ride felt pretty smooth after pumping 95. I was using 92+ STP booster before.
- 397 replies
Got a Full tank of 95 today at IOC kandy after 2 long months. 😉
- 397 replies
Guys so octane 95 is available for you? Me no luck yet. Do you run the vehicles with 92 + octane boosters? (even boosters are out of stock).
- 397 replies
Ignore the above. I was actually looking at the wrong page. 😄
Wait a minute, This means 1500models should run with 95 RON only correct? This is what my owners manual states.
Yes. I do not think there's any much of a use in using a stabilizer specially for vehicles which are designed to run with 95 octane (High compression engines). The objective would be to increase the Octane level to protect the engine components in the long run. I guess looking at the current situation we will not be pumping 95 for a foreseeable future. To make the matters even worse as of now there's no Octane boosters available in the market. So we are pretty much doomed. 😟
No idea about the additives being used to make Fuel stabilizers. I think what it does is it extends the life of fuel by keeping the fuel fresh for a longer time.
In theory Emsol is not an octane booster correct? is it just a fuel optimizer?
Between the two I would choose Lancer simply because I am biased and I would like to see a forum member owning another lancer. However honestly speaking you can not go wrong with either of them as most of the Lancers,FDs are owned and maintained by enthusiasts. It's like choosing Apples or Oranges.
Yes they do. I ordered a smoked Side marker light for my lancer and arrived within 7 days (from overseas)
How is STP is treating you? I am using the same and I do not feel that much of a difference except the smell.
Years ago when I was riding a bicycle I dreamed of having a Car of my own and I envied the people who had them. After years of hard work I bought my Dream car in 2019. Naturally I was the happiest man on the planet. Fast forward to 2022 I am searching for a bicycle in quick sites for my daily needs.😩 not trying to discourage you by any means.
It's a toyota wigo, dont remember the year though. Not sure if it is made for 95. But he has been using 95 throughout.
