K.o.N.o.S
Everything posted by K.o.N.o.S
  1. If the car is having any steering rack issues you can try dismantling and rebushing of the rack that will resolve about 90% of the issue. I have done for mine at mazna motors for 9k. But if the rack is far too gone you will have to replace the rack which will cost you about 75k. So check the current condition of the steering rack before buying further I would suggest checking engine mounts.After all it is a 10 year old car. You can easily identify this by starting up the car and reving up a bit. if the upholstery is shaking excessively then most likely that engine mounts have gone really bad.
  2. Brilliant work bro!! The things that you are doing with your car makes me fall in love with lancers..❤️
  3. Great to read on your positive experience in Mira. And also glad to know there are still people out there who think out side of the Box and not living in these echo chambers of Wagon'Rs and Stringray's.
  4. she looks like an absolute Minter. Congratz!!
  5. I think you are referring to bleeding the ABS modular using pressure bleeder and scanning tool. I just double checked with them and it has been done.
  6. Yes.ABS system scanned and resetting done. Subsequently brake washers replaced and system was bleeded.
  7. Hi members. I encountered this brake issue again.So I took the car to Mazna motors for inspection. Everything seemed fine and they bleeded the system again and replaced rear brake bushes ( they were pretty worn out). Lalith said that due to the complexity of the ABS braking system it’s pretty hard to diagnose this issue as they have to replace part by part to find out the source of this issue. Yesterday I was on my way from Colombo to kandy and suddenly brake padel sinked to the floor again. The issue was there until I reached home.(had no option but to drive very carefully through heavy rain). Now I am kind of convinced that brake master cylinder has gone bad. I am going to take the car to the local mechanic as I can’t risk taking the vehicle to Colombo knowing that brake padel is spongy. Anyway appreciate if you could share some insights. Thank you.
  8. The manufacture recommended tire pressure is too excessive for Sri Lankan Roads. Better go with 30 or 29PSI
  9. My Demio came with Kumho and so far they have served me well.
  10. Guys this may sound like a stupid question.I am having a hard time figuring out the gear box in my car..I have searched and gathered the following points so far. 1- in a conventional auto gear box we can actually feel the gears are being shifted whereas in cvt you we do not feel the shift change- in my case I can feel the 1st gear shifts and I do not feel any subsequent shifts.instead RPM level goes up along with the acceleration. 2- We can identify cvt by looking at gear lever-In conventional auto gear lever contains P,R,N,D,2,1. However in cvt it’s usually P,R,N,D,S,L.- in my case it’s the latter. Also in my understanding you can not identify CVT by just looking at the gear lever- help me clarify Car is Demio- 2009- DBA-DE3FS- 1340cc thanks in advance.
  11. Guys I have bleeded the braking system and the system is working as expected. Will let you know if something unusual happens in the future.Thanks all for your valuable advice and guidance..Cheerz!!
  12. I just performed the above test twice and as per the 4th point the padel did not sink to the floor.?.
  13. Thanks Mr Bourne..will give this a try.☺️
  14. Hi, is there a specific person at Mazna motors that I could get advice on this with?
  15. No. I haven’t done any maintenances or repairs to the braking system after I bought the car ( about 1 year ago). If the air had trapped internally it would have behaved the same way consistently correct? Why the system suddenly came back to normal? I am on the run for about 3 days now and no issues so far. Unfortunately we couldn’t bleed the system..maybe it slipped my mind & mechanic’s mind as well..thank you for enlightening.
  16. Hi. 1.Yes the AC was on 2. This is the first time I encountered this issue. I have been driving the car for two days since the issue and as of now braking system is working smoothly.
  17. Davy, it was just a regular press to slow down in a very bumpy area of the cross road leading up to my house. Actually yesterday I did some testing and everything seems normal.ABS kicked in as expected. The mechanic was with me the whole time ( he’s a relation of mine).Anyway he’s very firm on the fact that a worn out master braking cylinder could be the underlying cause.Even though the system works fine the problem might surface anytime soon. That is according to his advice .Now I am kind of scary to drive the car..?
  18. Could be..Because the road leading upto my house is very narrow & bumpy (about 1.5 km from the main road) so most of the time I have to depress the padel to slow down..for the record I do not rest my foot on the brake pedal. I did about 20 min of driving
  19. Hi members, yesterday when I was driving my Demio when drepressing suddenly brake pedal went all the way to the floor. Luckily I was near a garage & took the car for inspection right away..however after about 10min or so brake system came back to normal without having to do any repairs..I searched the forum/Net and found out that, 1- Could be a brake fluid leak- which was not the case & the mechanic did a through inspection 2- Error in the braking booster- highly unlikely according to mechanic’s advice 3- failure in braking master cylinder- which mechanic suggested that if the issue happens again he will do an inspection on the component.could be an internal issue he said. he advised me to drive the car normally for the moment and not to panic. I am skeptical and I need a second opinion on this and appreciate if you guys could shed some light. thank you.
  20. I did the same when I bought my car. It was registered in Colombo and got it changed to CP. you will need to pay a transfer fee at dept of motor traffic
  21. According to the reviews this camera has passed the high temperature test which has been conducted in very hot places like 160 degrees Fahrenheit. So I do not think it will be an issue
  22. Guys I have been doing some extensive research on dash cams for the last couple of days and finally decided to go with this product. I think it is one of the best out there and although I didn't want with the rear camera at first,knowing Sri Lanka I thought it would not be a bad idea to mount something on the rear as well. It is bit expensive and luckily my aunt is coming Down from US next month. So it will be FOC for me..?Again thanks for your valuable inputs and support.. https://www.amazon.com/dp/B071LPV7G6/ref=sspa_dk_detail_0?psc=1&pd_rd_i=B071LPV7G6&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=1713835751726239774&pf_rd_r=X3A5GVJ1P5KXV7CFA2FY&pd_rd_wg=6G51H&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&pd_rd_w=fx4Su&pf_rd_i=desktop-dp-sims&pd_rd_r=9a10785e-781f-11e8-8576-5b08dfeab856
