YRD
Everything posted by YRD
  1. Link to watch online anyone? The google links to Channel Eye are all dead.
  2. Damn.. From what I heard the F30 320D gets some options that the 520D doesn't such as xenon headlamps, retractable mirrors, real leather etc.. Any idea if it's true?
  3. 320d f30 for 6.9mil without the cost of the permit or with? prestige was selling the f10 520d for around 10 including the cost of the permit.
  4. Filled. What is the purpose of this survey?
  5. Old headlight wiring or old bulbs can be a cause too... Go to an electrician and ask him to check the headlight wires and bulbs.. Over time the headlights get dimmer because of old wiring.. I replaced the headlight wires in my EK3 and afterwards it was much brighter.. If you have to replace bulbs better go for a good brand like Philips, GE, Bosch, Hella or Osram..
  6. Happy birthday bro!!! Hope u have a good one.. Cheers
  7. Suba aluth avuruddak to all members & guests... P.S. Some kokis & asmi would be excellent!
  8. Cheers.. Let me know how it goes as i'm curious to know what the result is...
  9. Bro.. 8dbi antennas are impossible to find sl.. if u know anyone aborad can easily get it or try ur luck woth ebay it's available for super cheap... Since ur using tp-link why don't u try TL-ANT2408CL..
  10. bro.. stock antenna on that is 5dbi... where did u get the 8dbi antenna from? i called sense micro this morning (tp-link agents in sl) and they said trc doesn't allow them to import antennas.. did u hand carry or manage to shape up the customs chaps on ur ebay import?
  11. Moving the router seems to be the cheapest option.. what is ur router may I ask? did it come with the 8dbi antenna or did u fit it urself?
  12. In case ur not familiar.. generally the address in 192.168.1.1 or 192.168.0.1 and the username n password are both admin.. under wireless settings u will find the channel information... before u change anything i recommend that u use a tool like inssider and do a scan to see if there are any wifi networks on the same channel as yours and then update accordingly. also, if ur set on a antenna this one may be worth considering as it is 8dbi which is a considerable improvement over most standard antennas which are 2-5dbi generally...
  13. Moving the router is a better option.. Also, when ur gettin ur antenna try to get one without a cable or as short a cable as possible as the cables have some signal loss in them..
  14. Cordless phones may or may not be interfering (most phones run in either 900mhz/1900mhz/2400mhz/5800mhz band). Easiest thing to do is to google ur cordless phone model no and check the frequency before u move it anywhere. I found my cordless phone to be at 900mhz so I didn;t bother moving it anywhere. Cordless phone only needs to be relocated if it is running in the 2400mhz(2.4ghz range) that too if ur router is running the 2.4ghz band, if it's 5ghz don't worry about it although most routers that are 5ghz are dual band an as such are running 2.4ghz too... Also, while testing I have found that my wifi signal takes a serious hit in the kitchen when i'm using my microwave... Bluetooth too will have an effect as it operates in the 2400mhz band but shouldn't be that bad if u move it as it's range is rather short (approx 10m)...
  15. Higher is generally better.. but no so high as to be near the ceiling.. higher than most objects in close proximity and away from concrete.. Let me know what happens to the D-Link if u do buy it.. I was utterly disappointed with the U.S. Robotics one I purchased..
  16. No, what I mean is when i hooked up the antenna and checked signal strength using inssider it showed no improvement in signal strength and the areas which couldn't receive the wifi signal earlier still were left without wifi..
  17. No idea.. It didn't work for me on my previous router (single antenna).. I have a US Robotics desktop wifi antenna u can use to test before u commit to ur ebay purchase.. Give me a shout if ur interested...
  18. I've also been wondering the exact same thing.. Never took the plunge though as I heard some networking guys says that while this may boost the range of ur network, there might not be a big difference as whatever ur using wifi on has to have a wifi chip and antenna that is powerful enough to be able to transmit the signal back. I was on the verge of buying one to cure dead spots in my house but resisted after I heard this as I didn't wanna make a useless purchase as my router has 3 antennas and that was kinda expensive for all 3 as wireless-n uses something called MIMO (multiple in multipe out). Another way of boosting signal is to increase the transmission power of ur router. If ur stock firmware doesn't allow u to increase it u can try an open source firmware like dd-wrt which is linux based and allows u to overclock ur router.
  19. YRD replied to b4es5's topic in General
    If u run out of luck with what masterdon says u can try Unit#d Mot#rs (yokohama), if they don't have the size they will usually be able to bring it down for u with their next shipment without quoting exorbitant shipping and handling fees
  20. The ad was running on Yes FM for quite a while.. Sponsored by Caltex I believe..
  21. Check this link for more info on the comparison: http://www.gsmarena.com/compare.php3?idPhone1=3621&idPhone2=5033 It is clearly visible that the galaxy s2 is much more advanced hardware wise
  22. Bro.. Honda Insight ZE2 uses CVT Fluid. Use only Honda CVTF. NOTHING ELSE or the repercussions will be quite serious.. U can get it changed anywhere that they have the fluid in stock but i'd recommend a place that can reset the warning light after you get it done... I personally would prefer to go to the agents but there are plenty of places that specialist in hybrids such as hybrid motors, arabian motors etc but as I said before any garage that has Honda CVTF can change it for u, comes down to ur personal preference.. Capacity is almost 4L and the cost per liter is about Rs. 2,000/= Hope this helps...
  23. Have to agree with magnum, the s2 hardware is far more advanced.. Point to note, s3 mini and s2 won't get android 5.0 (key lime pie) when it eventually does come out they are currently on 4.1.2 jelly bean and the last update they will receive is 4.2.2 jelly bean... Hit this link for more info: http://www.gsmarena.com/galaxy_s_iii_and_note_ii_to_get_android_50_others_get_stuck_at_422-news-5720.php
  24. YRD replied to Watchman's topic in General
    hmmm.. then my cousin must be having an extremely light foot or he's extremely good at spinning yarns...
  25. YRD replied to Watchman's topic in General
    8-9? are u sure bro? I jus reconfirmed the 10-12 figure with a cousin of mine who has 520D F10..
