gayanath
Everything posted by gayanath
  1. 1. Didn't you experienced this oil burn before servicing this time? 2. What are the oils used for previous services ? 3. Check your garage floor and underneath of the engine for any oil leaks. If no leaks and oil burning issue is not a sudden case, then you may use 15W40 or above from next service onward. Viscosity index 50 (xxW50) preferred than 40. But if this is a sudden issue which observed the first time of your car, then your approach should be different. If this is not a sudden issue, you may refill with 10W30 and run up to next service. But if this is sudden issue, its worth to replace oil with xxW50 and observe the situation. Is your car a Toyota Passo ? Then 1000 cc or 1300 cc??
  2. I mean it should not be the first step as it involves more dismantelling and cost. Considering misfire and burning smell, why didn't he inspected the wires at the frst instant ????
  3. One more example of incorrect diagnostic by the mechanic. Observed, most of the mechanics are recommending tune-ups (cleaning) without diagnosing the issue.
  4. Let's do below checks before going to engine tune up (I hate the word tune-up as its only a cleaning job) 1. How many time cranking required for morning start (1, 2, 3 or more) ? 2. Try to start the car with little depressing the accelerator (throttle) and observe the difference. 3. How old your battery and the type of your battery (maintenance free or not) ? 4. Where did you refill fuel. Is it reliable place. (Can't be due to some additive - diesel or kerosene - in the fuel ???) As Rumesh88 said there is a possibility that fuel pressure not retained due to some issue and normal running no issue due to pump is working continuously. One another possibility is fuel filter (inside the fuel tank) partially clogged. Further, As I experienced in my Vitz, its difficult to understand the deterioration of the battery other than starting delay (I experienced this for tow times). Suddenly it becoming worst. (I went some where evening. Car started with slight delay. after running 20 km, stopped the car. Just after 5 min, I couldn't start the car. I have to start by jumping. Next day morning had to jump start again. Checked the charging and its working well. Replaced the battery, all finished.
  5. I have used Vitz 2007 1000cc for 3 years and 3 months. I too observed this type issue rarely when battery becomes outdated. but not continuous. I have following questions..... 1. How did you check the RPM value while in the traffic?. (Because generally, Vitz 2008 1000cc hasn't RPM meter) 2. Is this issue observed recently ? (you have used the car 10,000 km after purchasing. How many km's used with this issue ???) 3. Did you removed your battery without giving outside power for some reason ???? Further, 1. Increasing the RPM when shifted to N while AC on is normal for Vitz. It's increasing and decreasing time to time according to cooling load requirement. 2. If the millage is 19,000 km (13000 + 6000) when you bought the car and now 29,000 means, there should be original tires when you buy the car. If you didn't change tires or at-least one original tire is with you, please check the tire manufacturing date. If it inline with car manufacture date, most of the time your millage will be genuine.
  6. This is another example of our mechanics who are just saying to replace the parts without investigating the issue. Is this (engine stopping while switch on the AC) happening while idling or both running and idling????
  7. Changing millage by removing meter pannel and plug it in to the computer is known thing. But first time heared that, this can be done through OBD2 port.
  8. According to manufacture (both Suzuki and Toyota), transmission (CVT) oil is having very high changing intervel (First change far above 100,000 km). But here, they are doing it in less intervels.
  9. I think Swift CVT model (2008 and above) comes with same Toyota CVT gearbox which used in Vitz. I have seen one of my friends Swift 2008 which GB was almost same with my Vitz K410 box by just outside. Hearing less troubles could be due to less no of cars here.
  10. If you are using smart phone, please install "Google translator" app which will help you to translate that kind of things by just taking a photo.
  11. It is mentioning only about the tire pressure. Its not recommending the tire size. Either you could use 175/70RR14 or 185/70R14 and recommended tire pressure is 210 kPa or 2.1 kgcm2. (It's 30.45 psi which we all are familiar in the air pressure gauge). For emergency tire T125/70D15 or T125/70D16, recommended tire pressure is 420 kPa or 4.2 kgcm2
  12. For me, Toyota Vitz 1.3 L without any doubt.
  13. Gradually reducing during a month from high to low means; though we assume it as a leak, its could be unnoticeable as the leak could be tiny (like a crack). Leaked coolent will be evaporated due to heat before pouring. Please observe for another month to check whether its increasing or decreasing. Check whether your overflow tank cap fitted correctly as well.
  14. Lets summarize.... Got the car 2 months before after 2-3 days - level below the LOW, refill with wurth after 4-5 days driving - again level drop, what happened up to now for last one and half months? My car imported as 0 millage last Janualy. No coolant level drop up to now. My previous car vitz 2007, bought unregistered 2010 sept, first coolant top up done after using 2 years (around end 2012). any way, level reduction for 3-4 months is not an issue if its not an increasing trend. Starting from simple, 1. Could be a leakage. please check inside the plastic undercover using a torch and same time your garage flow 2-3 hours after parking the car. 2. Check your radiator lid. (be safe, don't do it at Hot) How about your car millage ?? 3. check your engine oil for any color change (milky mix). its a sign for major internal leak, but cannot detect for minor.
  15. No... no..... its not isolated to you. Every one who driving Aqua experiencing this. Not only aqua, Vits (KSP90 & SCP90) having same drawback. Not only in right turn, Its too risky at level crossing when pedestrians crossing from our right to left.
  16. Ah.. that's it. Yes you are correct. Same thing can be observed using touch screen of head unit or smart phone while driving. Unless looking towards the display, 90% doing wrong touch.
  17. First time heard "centre console roulette".... Googled it. Couldn't found any thing.
  18. Can you explain more (continuous or time to time, how the relationship with speed, how the relationship with cornering, etc. ) with Car details (Make, model, Year, millage, ) In simplest case, any stone chip inside brake disk ventilation hole also giving some noise.
  19. One of the factor for my decision of buying an Aqua is the transmission. I'm not in the view of Honda Dual Cluch Drive (DCD) is a failure. My concern was, its too early to take decision as it was introduced to hybrid at 2012 (however, DCD is not a new technology) plus mechanically its little bit complicated . But Toyota eCVT is mechanically simple (bit complected in software though) and proven by 14 years success.
  20. Both VVTi & iRage clarified your comment well. So not going to bother you again. For what ever the reason, you too riding a Prius (auto) ne ???
  21. I and my friend have imported Aqua and Fit GP5 same day. Fuel efficiency - Aqua Comfort - Fit GP5 Internal space - Fit GP5 Driving pleasure - I prefer Aqua due to smoothness in running and acceleration, but some prefer step changing acceleration in GP5. Second hand market - can't comment. Note: Our second hand market is based on several uncertain matters. 1. Popularity - popular cars having high second hand market 2. Affordability - Even Indian alto having the highest second hand market than any car in Sri Lanka. 3. Availability of used spares (kadapu badu) for low price - In that case Toyota having + point. 4. Tax - its always uncertain
  22. I said it regarding the time factor as he is doing very low millage per month. Otherwise, if he was a frequent runner at least more than 2000 km per month, sure I will recommend him higher millage interval (at least 8000 km) [subjected to the origin of the oil] knowing majority of AL users are criticizing it. As I remember , at end 90's to mid 2000, all were criticizing automatic cars and prefer manual cars. Price of auto car was comparatively low with same category manual car. But what happened now? While the technology is advancing and popular, mindsets are changing too. Same criticism can be observed for Hybrids and EV's now. Likewise, same scenario applies to other technological matters too. But when it familiar, people will follow it.
  23. When some one ask a question, why the hell the others giving lots of "pora talks" without answering his question. Although some questions deeply discussed previously, anyone should have the chance to ask again if he feels it slightly difference or if he have no enough time to refer all threads. If not, why the hell using forums, he can google and search the answer for any quarry without post his question here as more or less all the technical stuffs are on internet. If you are not willing to answer, keep silence. Others will do it. Always, be honor to others too. Criticisms are expected and accepted. Will move to the questions. 1. This is the thumb rule. Typical mineral oils should be changed on or before 6 months considering the deterioration of quality of the oil due to exposing the atmosphere, added numerous chemical reactors while circulating in the engine, exposing the temperature differences, etc. Therefore, this is more important than millage factor. So, please change at 6 months. As you are running less, don't use synthetic oils. It's not cost effective for you. 2. I always prefer to avoid agents due to unnecessary cost. I haven't any experience with S****d, but having with T**L. They only focus on the money and not the technically sound service. They, just giving advises which some are not recommended by manufacture too and at least having no any technical reason or document. When I request a document, they told they haven't. Actually, they have failed to prove their (some) recommendations. For me, actually need the facilities of the service station (tools, hoists, etc.) only. I am competent to manage technical part for preventive maintenance until any repair needed. But in your case, as I think, both A**T M**G and S**D neither worst nor the best. As you have no much idea about oils and other consumables, just go to agents for first 2-3 services and always try to talk with those people as much as possible and ask lots of questions. Be familiar with typical service matters. Then you could do your service at any place as you wish if you are a good reader/researcher. Knowledge is freely available at present.
  24. They are using 10W30 oil as they have equipped oil delivery system to service bay with 10W30. 10W30 will not give any harm to your engine (even xxW40 also will not give any harm) but 0W20 is the most suitable and recommended by the manufacture for best performance and fuel economy. If we requested to use 0W20, they have to spend little more to handling the oil. My concern is, they are proposing lots of other extra maintenance things which even not recommended by manufacture too, claiming safe side of our car (but with a big cost to us and huge profit to them). Why the hell they just ignore oil viscosity matter?.
  25. They are not using recommended oil (0W20) until we specially request due to their business reason. They care more about business than our cars. Will you go there for next service ....???
