gayanath
Everything posted by gayanath
  1. Dear Rookantha, In the first instance please see this. A*W has recommended 20W50 for your car. But according tho the maintenance manual provided by manufacture (http://marutistorage.blob.core.windows.net/marutisuzukipdf/Final_Book_Alto_800.pdf) it should be 5W30. The letter before W is not important as Sri Lanka is tropical country but viscosity is important for better fuel economy and engine performance. (Its true that 20W50 will not harm to your engine but performance wise not recommended). This will reflect how the local agent concerning about your car. What I understood is they are trying to harvest from you than providing technically sound service. Please download the manual if you have not received original one and read the pages from 71 on-wards. The knowledge gain by reading is more than enough for maintain your car. It will save lot of your money. As you have changed Air filter at 10,000 km, no need to changed it now. need only cleaning. If I were you, I will also not change coolant and brake oil at 20,000 km although the manual indicated.(Its according to my vehicle maintenance experience but others may oppose to this). I will use them at-least up to 40,000 (subjected to age of the vehicle). Gear oil change is mentioned in the manual as 160,000 km or 10 years. Don't wast your hard earned money. Cars are made for your comfort and you are not made for the comfort of the car.
  2. According to your usage pattern (as with no traffic) Fuel Average = Prius 25+ km/L Allion = 16 km/L (I guess Allion is doing less than that) Note: Prius is doing only 15-18 in city traffic but in your case it will do 25+ guaranteed. Service Cost = if Allion cost 6000 per month, Prius cost 4000 per month (its service intervals are pretty long if you follow manufacture recommendation and less maintenance required for most of the parts) Depreciation = Allion is also depreciating now like as hybrids Propose to recalculate by these data.
  3. Prius doing 17+km/L in Colombo city traffic and 22+km/L for long run. (Those data are tested by fuel full tank). But non-hyhbrid Axio 17km/L is extreme condition shown by car reading. It will not do average more than 13km/L. I could guarantee that, with comparing same category(size) Toyota vehicles, hybrid is doing 60%++ than non-hybrid which is massive achievement.
  4. Yes, no need to worry, But next time on wards, always ask them to fill in between max & min marks. You can fill balance in next day morning.
  5. Then its clear that its knocking. Don't worry. I have experienced this not my Aqua but vitz. It will go away withing some days.
  6. 35k kms usage is not bad. (If you use them as much as possible by interchanging and replace all at once is the best for next tire set. The advantage is you could do proper tire rotation at every 5000 - 8000 km and take maximum output from next tire set onwards (with proper alignment and balancing).
  7. There is only one clutch between engine and generator (which work as starter motor too). This clutch works only for start the engine. No any clutch involvement withing power train of Aqua or Prius. Power transmission, balancing and engine to motor ratio adjustment is doing by power split device without any clutch involvement. So, Jerky while starting is normal and that's the only time we feel jerky in Aqua. The term "rattle" is normally used to describe the engine knocking sound. Do you feel knocking sound while the starting jerk?? Otherwise, your case is normal and we too observing the same in our cars.
  8. Is this rattling last long or just for 1 ot 2 seconds. I think you aware about the sudden jerk coming sometimes while engine starting (EV to non-EV) and hope you are telling not about this scenario. Did you experienced rattling with this jerk or without the jerk.?
  9. There is a facebook group "Toyota Aqua/Prius C - Sri Lanka". Its well updating and there are enough enthusiastic for Aqua and Hybrid related latest technological stuff. Join with it and post your issue. definitely you will receive good solution.
  10. There is a facebook group "Toyota Aqua/Prius C - Sri Lanka". Its well updating and there are enough enthusiastic for Aqua and Hybrid related latest technological stuff. Join with it and post your issue. definitely you will receive good solution.
  11. If no issue with bolts tightness, then you could interchange the wheel to left side (just for experiment only) and see the situation. If left vibrating, then the issue is with the wheel. How old your tyres???
  12. Higher the millage means higher the wear. That means more clearances between engine components. We have to use high viscosity oil in that case. So 40 or above is good solution. Even you can use 50 and some times 50 could be better than 40 for your engine. 30 is most suitable for new engines. (two numbers after letter W is the viscosity index. No need to worry about the number before W as we are in the tropical country) If you are not not doing at least 1500 km per month, no point of using synthetic oil (no value for the money expended) and mineral oil is more than enough.
  13. Yes, Please go to http://jpnauction.com and create a login for you. Then go to statistics sales. You can find the auction data up to last 3 months by entering auction number. (please note that, sometimes there may be several vehicles for same auction number in several days. you should select required one).
  14. Mentioning the Auction grade in the inspection certificate is not a must. There are enough vehicles without mentioning this data. But, if it not mentioned, there is a high possibly that the car is R grade. (normally R grade is not mentioning) Inspection certificate contained the data at the inspection time only. The exporter is the person who obtaining it. So he can do several things before send the car to the inspection. Auction sheet is more reliable (but not 100% accurate) than inspection certificate. The date mentioned in the action sheet is first registration date in Japan (not the manufacturing date). Normally both are inline but not a must.
  15. Actually, the statement is for old cars above 15-20 years and not for the cars less than that. By the way, the new car trend is developing in the country since few years (without any government policy implementation) according to my observation. So, vehicles are no more appreciating asset in Sri Lanka and there is a high depreciating trend comparing with 10 years back.
  16. Can you tell why this should be top of the dump list? Any body can tell any thing (I know that, lot of seniors in the AL is thinking they are the cream of automobile in Sri Lanka ). But we cannot reject the reality....
  17. As simotor said, the particular Leaf SD card of your car is only working with your head unit only. I don't know whether it will work by cloning. Any way, to make a clone you need your card. How could you find it if it was stolen.
  18. If you consider resale value, please think about below points, Cars less than 2 M has good resale value than above 2 M because of the affordable level for majority (There are enough buyers who buy Maruti Alto for 1.6 M as second hand while the company B/N price 1.525 M, because of waiting list). Now most of the people not consider about the brand but the price. Before the WagonR Hybrid, Aqua was the cheapest Japanese car. So it was the best selling Japanese car. but after WagonR, (the cheapest Japanese car now) some trend has build up for it despite of small engine, etc. If you go for high price car, 3 M or above, re-sale is difficult for good price because of less no of buyers despite whether the car is hybrid or non-hybrid. But even Maruti can sell for good price after 2-3 years. No more market for old cars as government is planing to introduce road worthiness test after some age (lets hope 15 - 20 years).
  19. I too agreed about GS. Most of the time they are telling the truth about spares.
  20. @ Crosswind, I think, the things are messed in your mind because of no broader view regarding the matter. Your some points are extremely correct and I too agreed. But I cannot understand why you tell "But if you think the purpose of Sampur should be for providing cheap electricity to consumers, that's where you are wrong" . Who told sampur is required for EVs or we can use EV's due to Sampur. Clearly I have mentioned that Sri Lanka have enough power now to cater maximum demand. but at higher cost. Norechcholei helped to reduced the cost (in addition to match the maximum demand) but still we should reduce the cost to improve the industry of the country. (Your second paragraph is correct and agreed). Yes, not only power price but also other factors affecting to industry but I didn't discuss it earlier as this is a separate issue. Same time, I have told your 82.5 MW matter is nothing due to availability of enough power at off peak time at low cost. No need any new power plants for it thanks to Norechcholai and hydro. So, lets appreciate that, even in Sri Lanka, energy sector is turning by positive way but slowly due to the culture (political) of us. We should support to it. Otherwise we will be selfish as you told. If you need to study further regarding the energy plan of Sri Lanka for next 20 years, please go to the web site of Public Utilities Commission of Sri Lanka. CEB has published the plan for 2016 to 2035 and they are requesting public comments which you too could participate. @ NPP, Thanks for highlighting the tariff matter. Although I had known about the discussions are progressing, just I know that it is implementing very soon. Yes, agreed with your other matters too. On the other hand, Nissan Leaf is not the only EV car which we have to discuss. Lets see new models in future. Same time Toyota is going for Hydrogen Fuell Cell. Lets welcome them too if they good for us as a Nation (only if good). but still if we can build our own, its the best.
  21. 1. Same thing I have mentioned above. Thats why need new meter as existing meters are not time dependent. Need to make policy. Will come soon. 2. Already port power plant 60MW, Matara power plant completely shutdown. Yes... there are several political issues available those who are in power. but some improvement can be expected. Think about burning fuel in less controlled manner inside IC engines every where. Burning coal is done in very controlled manner. That's why I told all should be compare and evaluate. 3. Thats why I told efficiency. high efficient means high power by less quantity which lesser the emission. But until we go for solar (bec solar is the base of all) we cannot completely eliminate. 4. Agreed. But we should go as a nation. Any way this all energy related engineering matters cannot clarify by this type forum.
  22. Can you tell us how you plan to enforce this 2230-0400 charging time ? Answer: Very Simple. There are enough control systems (with timers) and electricity meters. Already the CEB industrial meters having remote monitoring features (I personally know) but not using as other infrastructure still developing. We could plug our car at night. Control system will do it. CEB has to give new connections (actualy one more meter to be fixed only) as a national policy. This has under discussion now.... We don't need to build Sampur to charge electric cars. Sampur is needed to ensure that we can continue to provide electricity to the entire country around the clock. Answer: Sampur is building not for electric cars man.. Its to provide low cost energy to fulfill the requirement of the country. Norochcholai is currently providing a unit for 5-7 rupees while diesel plant cost around 20-30 rupees. If sampur completed we could shout down some diesel and entire cost will be reduced not only for EV but for entire industry and poor households. (Do you know, All the plant cost of Norochcholai is recovered now. Considering the environment matter, 99.5 % exhaust dust are collected and only 0.5 % could be go out. Its minor considering the impact of the vehicle emission). The Only way the EVs are gonna be green is if they use the excess capacity coming out of solar systems. For you to do that u have to become a bat so that u can sleep during the day and roam during the night. Answer: No need to argue on this as by looking this I could just say you have no idea about electricity / power / generation efficiency related matters. Using more efficient generation means less harm to environment. Yes, solar is extream end but IC engine is at low end. So what ever in between should be considered towards green. Hybrids are greener than Non hybrid due to higher efficiency. EV's are greener than them as those are depends on efficiency of the power plants which is more than hybrids with engines. Any way, accepted that, there are draw backs on EV's. That's why I told in my previous post, we have to change our life style to take the maximum benefit of it. Otherwise it will not suitable for us. Every things are having pros and cons. Decisions should be taken by doing "Cost benefit analysis". Lots of people telling thing by looking only pros or only cons. It will not beneficial to the nation.
  23. Almost same with Suzuki Swift. 9-12 in Colombo, 12-14 in Outstation. You may obtain 14-15 if you go outstation at late night
  24. This story is only 5% true. By looking the basic info provided (car prices, tax amounts, etc.) we could observe that, the writer has no sound knowledge about the car market and how its handling. How we accept the things written by the person who having no proper idea of the subject. Same time, He is also a person who went to japan by "magodi" way. (According to his story, he went to japan giving some money to some party). But now, giving advises to others.... (Yes, Magodies know well about other magodies than us. ) :-)
  25. May be or may not be. It depends on the charger we used. We have the option of selecting the charging pattern. On the other hand, if we use something to take the benefit of it, same time we have to change our life style to suit it. Otherwise, all technology improvements will be burdens to us.
