gayanath
Everything posted by gayanath
  1. Seems yes... Both Newbies, single post count, same pattern of name, .... ??
  2. Probably a material defect ?? (may be on a particular batch) Or more heat ?? (but rare chance. Isn't it?
  3. There are Genuine Denso filter models with glue strip in the middle. See below photos. The old one is genuine one came with the car (0 millage personally imported car I personally collected from Hambanthota port - So no chance to replace it by any body in SL) and used 50,000 km. The new one is bought from local market (they said genuine part).
  4. Has the vehicle came to "Ready" mode ?
  5. Already checked ITI for oil sample analysis but they have no such facility for motor oils. As I remember, they will provide the service for food related oils only.
  6. Assumptions ...... ? To realize the ambient temperature effect on Oil...
  7. Probably no. I too searched but couldn't find any place withing SL. As I understood, the easiest method is sending Singapore.
  8. Note: This question not related to Engine Oil selection for an ambient temperature. It's related to the service life of same oil in different ambient temperatures. Let's assume below two hypothetical conditions in two countries A & B. If we took oil samples from each vehicle after same period of time with same millage (lets assume after three months at 5,000 km usage), Sample A - Country A Sample B - Country B Which sample would be more deteriorated?
  9. This is good one considering traffic as well as parking spaces. We could see huge numbers of vehicles parked roadsides in the evening and night (specially on Colombo byroads which is unpleasant to road users). The people who live in flats have numbers of vehicles and three wheelers but they have no dedicated parking spaces. Before implementing a regulatory system, there should be a good citizens database including where they actually living, etc.
  10. You mean registered or unregistered?
  11. Since you have a cash problem, suggest you to buy OBD Scanner (BT or Wifi) and use with your smartphone (it will cost around 2K or 3K). You may clear the code when it appears and use the car for sometime until you could afford the repair. * Subjected to the error code is P0A80 always. Please check the code every-time before clearing it. Otherwise you will mis any different one if arises. Knowingly, doing this is no harm to the safety of your ride or any mechanical/electrical or electronic damage to other car parts.
  12. Military or Civil Aviation? Isn't the Civil Aviation and Medical are higher than military?
  13. How it goes inside? How you removed it?
  14. YOM? Is it with original 12V battery yet?
  15. I just remembered this old thread when I saw below article... https://healthreviewglobal.com/sri-lanka-coronavirus-update-setting-a-global-example/?fbclid=IwAR0CTP5Izq5p_AWVd4XMCxaw4u2eT0BXQRdM9rMnMX-E8DeQ5NWDgv3KP54 Quote... Sri Lankan health system has both public and private health care sectors. The public health system is free for all citizens. Going hand in hand, Sri Lanka has a free education system until graduate school for the last 60 years. Thanks to the free education system. Sri Lanka has trained thousands of well-qualified healthcare professionals and paramedical workforce for many decades through 9 well regulated and state of the art medical faculties covering all regions of the country. And, all free of charge. The doctors and paramedical staff receive post-graduate training and continuous medical education throughout their career. ... unquote
  16. Seems this is common issue. Few other car models also having such kind of issues time to time
  17. 92 is fine and more than enough for Axio. No point of paying 17.5% extra for no gain.
  18. Battery replaced just after the Flood or later or before? Light blinking issue happened just after the flood or later or before?
  19. Hope your 12V battery is good. Is it new one or still using original one?
  20. Tyre rotation is an important thing a vehicle user should know. And that's why I suggested you to buy a cheaper one and use until you replace all 4 together. Since you ordered new one from same type - Front tires are wearing fast. So you could keep new one always in front (but it will tends sidewear so you may need to remove and refit - only if non directional) and rotate other three at every 5,000 km (Since others done only 13K). When others are doing about 60K, your new one also will fully wear by 47k. Then you could replace all 4 together.
  21. Nothing will happens to others because of different brand. Anyway now you have ordered same brand ne...
  22. You have to check whether side walls are damaged or not due to 2-3 km flat running. , If extensively damaged, definitely you have to replace.. Couldn't you find a cheaper brand for 15k to 20K ? Still 13K km means your other tyres should be good. Furthermore, If you don't follow proper Tyre rotation in future ( due to a bad tyre,) you may have to replace other three also bit early due to sidewear. You could repair the punch. But if side walls damaged, you have to replace the tyre. If car boot is designed for small size one, you should only buy smaller one. otherwise you have to face several ergonomics/user friendliness matters while using boot space as well as extra weight.
  23. @iRage, Couldn't this issue be associated with VVTi system (may be some kind of issue in actuator, tensioner, or something) ?. Guess that, some component working for some range but not functioning properly for another range...
  24. 1. Millage? 2. Previous engine related repairs (inducing cleaning)? 3. How long is this fault? 4. Is this coming with acceleration? 5. Is this coming with deceleration? 6. Is this coming with continuous same speed about 70 km/h? 7. Did you check it at expressway? high speeds? 8. No sound with load? (with 4 people and slight acceleration)
