Everything posted by Ruslan
Glove box hinges (bottom holding clips) of Lancer CK1
try partsouq.com, megazip.net or amayama.com. partsouq contains the part catalog, when you enter your VIN.
Toyota Vios 2004- different arrangement of the rear signal /break lights
As Far As i know, there were no 2 Break Lamps in one housing. one is a Rear Fog Lamp (Most of them were rewire to act as a Brake Lamp by locals). could be a aftermarket tail lamp.
Is all wheel drive worth the money?
This is common in My AWD Vitara as well. It has to be the same psi on all 4 corners.
Engine issues with 2007 Toyota Vitz
^^Above Nilwala Motors!.
Wow!, Sampath did you remove the wheel cylinders and check for any rust? and check the washers. when i got the Vitara, recently overhauled the brakes and for my surprise, both rear wheel cylinder washers were leaking, Front left side Piston is corroded but not leaking, since agents didn't carry the parts, i have ordered them online. looks like the previous owner didn't even care to change the brake fluid and hence the consequences. and That Brake fluid can very similar to Seiken Brake fluid, perhaps Seiken is the Supplier for Mitsubishi?
Japanese Car News
Wow! Interesting indeed!.. (Not For Thel Higannas I Guess :P) looking forward for the GT. it's about some time Toyota introducing something interesting and get rid of the Boring.
Side effects of Engine de-greasing?
One of My Friends had to Replace the Bearings of Alternator, Idler pulley (There was a whirring noise came after couple of miles) etc, due to Degreaser. Service Jhonnies forgot to cover them.
- Pajero Computer body
Recently switched to a Grand Vitara and Boy why wouldn't i love the All wheel Drive of this thing. at fraction of cost of Fuel, it gives a far reachability than my previous Car. Yes you have to take care of Differential and Transfer case oil etc, but i must say, it's well worth the extra cost. Even between 2WD Vitara and AWD variant, there's difference with Suspension, Lower Arms etc. 2WD version is little bit lower in Ground Clearance as well.
- Toyota Premio 260 GearBox Repair
New car/crossover for permit
True on Toyotas as well, All the Agent imported cars came with Rough Road package (aka Stiff suspensions, Higher ground clearances, Steering Rack differences etc.) and better tolerating plastics on dashboard etc (Corolla 141 never had dashboard going bonkers but the Axios). some of the brand new imported cars (Suzuki Wagaon R Premium Hybrid) came with ECUs tuned to local Fuel as well. and i'm sure most of the Euros were Tropicalized as well to suit local conditions.
Confused between Axio Luxel and Civic FD1
Go for The Luxel, it' simple, you know the History of the Car than Unknown Car. as iRage mentioned, this specimen looks fully loaded as well. for 2ZR-FE, those are very solidly built engines (Family owned a Premio with the Same Engine). get it checked with the agents, and change the usual suspension bits, such as lower arm bushes, D Bushes of Sway Bar etc.
Shock strut mount and other rubber accessories
Inbox you the details
Im Still using Tenacity over 2 years and it's still standing strong. i don't see any difference in comfort with OEM ones.
I Can Vouch for Tenacity Lower Arm Bushes which purchased from GS. those still standing great even after 2 years driven in local pot hole ridden roads. Quality seems better than RBI stuff. if you looking for Japanese Bushes, look for Tezuka or TZK Rubber bushes.
- Familiarity breeds contempt, or how I crashed the shitbox because it had bad brakes.
- 2018 Budget - Vehicle import duty
Upgrade head light to adjustable
Yes From eBay, https://www.ebay.com/itm/2x-LED-Chips-160W-16000LM-H4-9003-HB2-Headlight-Kit-H-L-Beam-Bulbs-6000K-/222199186381?hash=item33bc1a83cd
I have lumiled H4s on my 2006 Vios. Compared to Halogens, its much better. But cant compared them with HIDs. You can adjust the angle of the bulb as well. No stray beams and this does not give glare to oncoming drivers. Will post a photo when time permits.
Buying New Shocks From Which One
Plus, Naamratne has Tockico as well.
Nope no Auto Adjustments, this came with Halogens. there was switch with scroll wheel where you can adjust the Height.
Yep, My Fathers. yes Height Adjustment came as standard.
First check whether the wiring is present for height adjuster.
Good tyre for Premio 195/65/15
I'm Running Pirelli Cinturato P1s 14" on my Vios, overall it's a good Tire and road noise is less. better side wall compared to Michelin Energy XM2s. On the Shock absorber, i think your Bumper stops has failed. when it compressed, is it stops immediately? if yes then your shocks are good, unless if there's a sign of oil leaks around the cylinder. for replace just the bumper stops.
