Rohnd
Everything posted by Rohnd
  1. Prices may depend on the brand , additives used and the country of origin where they packed etc. Most of the JDM vehicles run on 0W-20 according to the Temperature.environment in Japan, however I hope that 10W-30 is good for the environment for Sri Lanka. Some manufactures publish different ranges according to the resident country of the vehicle, sometimes use even 15W-40 in hot countries such as Middle East. There are many compromises will not harm engines. Anyway it is good to have the change oil at intervals less than 5000 Km and 6 month duration (whichever comes first), I do not have any idea about Staffo+d's recommendation. If you experienced a minor sludge formation you may clean the engine by applying short term oil changes very few times( say 1 to 3 times) at 1500 Km intervals like according to the situation. This is one of cleaning methods without flushing or dismantling . I think it is wise to get Stffo+d idea too about your problem.
  2. Yes , In newest engine designs the PCV is incorporated into the middle/bottom part of crankcase with an oil separator instead of baffles. The baffles may be still there for the upper crank case to throttle body linkage. Access to the PCV is very difficult in these engines and the so called separator is also vulnerable for clogging due to carbon particles and oil sludge etc. This unit is also replaceable if found abnormal. What are the next steps to be taken if, this problem is an inherent problem to Honda Fit and what the cause in real to begin according to Honda experts ?
  3. What I wanted here was to discuss the main cause of Sludge in engine, and identify the main cause to that is as the poor maintenance or prolonged service intervals because Vitz had two similar attacks according to him. Every time we cannot say PCV. Though it is a reason for sludge formation, low evidence for failures (within itself) , since it is a very reliable mechanical device. That is why I stated as very rare. I hope nothing is wrong. With regard to point 2 , I agree that there is a separation (baffles) to oil mist and Blow by gases, but still we see PCVs clog due to contaminated particles from oil . I hope, that is why we talked cleaning of clogged PCVs due to these particles. None of these particles come through inlet air duct but from crank case side. I think clear.
  4. It is worthwhile to mention here a non-coincident attributes relating to the PCV unit. 1. PCV failures (open or clogged ) is very rarely contributes for sludge formation, 2, If the Sludge already formed due to some other reason ( Ex: No timely changes of engine oil), PCV is a very first victim of the engine that may be clogged due to its location. This should not understand incorrectly as PCV failure oriented. matter & should not be blamed for PCV .However most of the time it can be cleaned and reuse. To simply check it after cleaning , remove the PCV ( Vacuum hose to be kept as it is ) from the plug attached to the cylinder upper head, Start the engine and keep in idle . Put your finger on the top of the removed PCV tip for a short moment & several times, If you feel valve open and close each time the PCV is good. This clears the both fault conditions ( open & clogged) of a PCV.
  5. PCV can be checked using your finger tip when the engine is operating. A simple check.
  6. This action will ruin specially poorly maintained old engines further.
  7. Rohnd replied to a post in a topic in General
    Unlike in earlier days most of the parts in Japanese cars now manufacture in China or Malaysia as a measure of cost reductions. (Ex: Some electronic Sensors , Headlights & windscreens etc.). These 'Saint Gobain Securit' windscreen accessories can be seen in Japanese assembled vehicles as genuine equipment. (Ex: Mazda Axela 2004-2008 ). So no problem it is OEM or Genuine.
  8. Yes , As Rumesh88 said, sludge should not be always suspected. The sludge is sometimes oil brand specific , engine model specific , owner (behavior ) specific problem. It is not a mineral or synthetic problem too. Some manufactures do not recommend synthetic on their engines because of varying unknown chemical additions, About 10 years back Mobil 1( A synthetic ) caused sludge problems on engines of Toyata, Audi & VW in their certain models. After million attacks I hope Mobil 1 anatomy had been changed and car manufacturers also modified their designs. The caused was the excessive temperature on VVT head and non-sustainability of Mobil 1 to such temperatures. Around 10,000 km intervals between oil changes are not considered as a safe margin for a country like Sri Lanka where the grade of fuel is not reliable, not up to the standard and also the environmental factors which lead to premature oil deterioration. 5000 km (or less) and 6 months non distance dependable time are normally accepted for engine oil changes whether it is Synthetic or mineral. As per Vitz cases, he always a victim of Sludge. Around 2009 he had a sludge problem on his Vios. Now this time on Honda Fit. It is worth to refer here. I think it is wise to monitor & pay your attention on engines and lower the oil change intervals, use of genuine oil filters and Air filters etc. Dismantling of the engine may clear all the problems and if improperly handles (the repair ) it could a cause of series of new problems,
  9. Agent may charge more. Any competent garage can do. Must remove the upper head of the engine and an original Gasket & seals may necessary. However get more sure about the fault. Have you noticed some exhaust smoke at idling each time (provide gap of 5 minutes in between) when you start the engine ?
  10. This could be from worn Valve stem Seal (oil) rather than the piston rings. Little smoke at the start (at idling) and then disappear within very few minutes is a sign for this fault while piston ring failures lead to give constant smoke every time when the engine is active, At the both cases oily stain at the tip of the exhaust end is a common sign. Dry black deposits on the center electrode ceramic area of the spark plug also shows this could be originated from leaky valve seals. You will not be noticed any reduction in pulling power at this fault. Changing the viscosity of the oil won't help.
  11. Sorry. Corrected !
  12. Mazda has noted that it's new SkyActiv Generation 2 Engine will make it's debut in the new Mazda 3 next facelift scheduled in end of 2018. A 30% fuel saving (3.3L/100km) has been suggested against the current SkyActiv petrol engine (5.7L/100Km) ahead of Toyota Prius (3.4L/100kM). The features include a petrol engine without Spark plugs, uses Homogeneous Charge Compression Ignition (HCCI) technology similar to that of a Diesel engine. it also features less emissions specially NOx. According to Mazda, the HCCI has been pursued by numerous manufactures notably Mercedes Benz since 2007 , none has been able to deliver a production ready. They also indicate that this, as a key development to enable the return of the rotary engine. From internet sources...
  13. In brake lines the thread follows the British Standard Pipe (BSP) threads most probably in Japanese and European vehicles, not the normal metric/ inch thread format . The American analogy is NPT (National Pipe Thread) but not compatible with BSP. You may use a bolt of 1/4" BSP thread at the brake hose end to lock each end, if available or lathe a bolt to the said specification.
  14. All MP's (Ruling/Opposition) /Ministers are humans who fell from Sky. Their Mercks/Benz/Land Cruisers are different from commoners ! Special editions, Zero emissions though gasoline, Duty free so no Carbon tax. Will be changed by election to election. But a pension is there.
  15. All these shows Sri Lanka has no Vehicle Policy as a country. Recent budgets show the Government aiming particular brands of vehicles time to time, no clear cut rules on vehicles. A country must have one policy on that at least for several years. When present bribery rate for Policemen is high government is trying to increase it further and reduce the Government income by introducing high fines for road offenses. This is correct, if on the road Sri Lankan Policemen are discerning , well educated and correct decisions makers. As a whole R K**** is in blind state, and budget is no good.
  16. This type of failures are not normal. Probably man made or poor environment. You may order a genuine one through Agents (Stafford Mot***).
  17. With AC for urban/town run this is quite normal for a car around 20 years old. You have not mentioned these conditions. Have you got an emission report after the repairs?. Because it's readings indicate some clues for the problem.
  18. Rohnd replied to Nishan.dj's topic in General
    Try Camebrig* H very near to AC Pa** . They had this few years back at reasonable price.A Chinese one. OR at International Marketin* same row.
  19. When the cars are flooded in future, there will be no concepts exist any more such as 'second hand market value'. Those concepts were mainly interpreted by car brokers in history. See the technological advances, oldness, susceptibility to failures, spare parts unavailability (do not think Chinese copy), but not a particular make. Your price quoted for this car is high, so do not talk specially the 'Second hand market value' . you will be trapped!.
  20. No need for a glue. You may use a bit of red grease for the purpose you mentioned.
  21. This UA is famous for customer dissatisfaction. Their fast behaviors specially at Tsunami was black. Everybody knows! Why still??.
  22. There is a concept called ' Initial Bed in' to enhance the performance of the changes you done with new pads. Better to have a web search on that. The mechanic threw water as a cleaning aid to prevent the body paint damages and related since water absorb brake oil greatly, A brake part cleaner is for another purpose. He has done a wrong procedure by neglecting the brake oil spill to the environment, since there are methods. Shows another Maka Bass theory.
  23. The Grinding & Humming could be from two different sources other than bearings. For example Grinding may be associated with the brake pads/shoes mechanisms while humming could be initiated with worn tyres etc. Before proceed please make sure, try a tire rotation(hum), cleaning of brake mechanism/Cylinder/Rotor etc.(grind) and any side to side play of the wheel on lift (bearing). Is this Hum/grind a speed dependent ?.
  24. For Mazda 3 2007, it comes with the Hub/Bearing complete Assembly. So the prices are such that. No separate bearings available for this model. Why do you replace these?. What is the reason?. I ask this question since you have stated that the time has come to change!!.
