sira
Everything posted by sira
  1. Yes i did
  2. Hi My car starts shake on driving. recently i replaced front hub and Lawer arm bush. it was fantastic for 4 weeks time. now got this issue. i also relized the left side front and rear Shock absobers are bad. is this the cause for shaking? Also advice me replacing Second hand shokabsobers? are they good? Let me see your views Sira
  3. Hi. My friend brought toyota allion a15 2002 recently and the audio setup in Japanese langauge.it is Multi AV station 2 is it posible o change it in to english and how can we search TV channel on this thanks Sira
  4. sira
    Fb 13 Camber
    Hi anybody Know how can i adjust the camber angle on FB13 car? Sira
  5. sira
    Fb13 Carb Tune Up
    Hi guys What is the best place to tuneup Nissan FB 13 carb? Sira
  6. For your infomation, Meanning to say that SLT stil not 100% avalable for everybody like Dialog TV Thanks Sira
  7. Hi Guys Please note that SLT PEO TV will not be available for some cities bit a far away form Colombo. i lived in aturugiriya and they cannot provide IP TV because the Line condition, Distance and Exchange compatibilities are poor. It is bit a desperate to me. As far as I know the IPTV quality is very good comparing t dialog TV and existing ADSL customers can get PEO TV with FOC. FOC always F up Thanks Sira
  8. How ever managed to fixed my XBOX after 2 weeks searchinf teh solution on internet. can eb download the recovery CD - LINUX and need to read the luck key with connecting 3 wires to mainboard(XBOX) and with linus boot disk it can be saved to HDD .now XBOX works OK Thanks all for your coments Sira
  9. Hi, I'm having big issue with my car now. recently there was an issue with water pump and it replaced. now on another water leak on thermostat area (there are 5 hoses connected to thermostat housing). i did contacted the agent and they said the houese are not avalable. on thermostat housing side the metel pipes also dechey too. what should i do thanks sira
  10. Hi N16 is a good car as wel as fb 15. go for 1500cc car. normally both of them can reach max fuel efficiency around 12- 15 sira
  11. My Nissan FB 13 alternator giving Alternator problem since one year time. I had to replaced 2 alternator last year and the recent alternator giving problem too. When Iswitch on the ignition morning the charging light come up. drive few KM and stop and switch on the ignation the charging light will no comeing up. cannot tell the exat time that charging light issue.soem time it will comming up and soem time it's not After that I check the grounding the indicator wire form alternator side. The light is came up. I think some thing wrong with in side the alternator.I removed the alternator and clean all broushs and checked all the parts (diode place roter and strater) all looks ok. and i dont know how to check the IC. How ever the charging is ok. I check the battery voltage with head light on and AC on. it showed me 14-15 voltage. Can some body tell me why the alternator getting faulty. Thins is the third alternator of my car. is this common problem in FB13 or soemthing wrong with my wiring.last alternator i used aound 6 month. I have attached some pictures of Service manual and need to know what AGC of my alternator is Please Help me Sira http://img26.imageshack.us/img26/6789/alternator2ly7.th.jpg' alt='a>'> sira
  12. Dose anybody know about honda bike called jade 250? please advice me i'm trying to buy one sira
  13. Nissan uses NGK plugs(most times), agent have NIssan plugs only different is box is nissan inside the box plug is NGK. Original NGK plug cost will be 300 rupee. but nissan will ask you 550 rupee. just tcheck the pulg model what is your plug model if its BKR5E2 then eack cost you 300 if its platinum plug will be expensive and i dont have the price with me some body told em it cost 3000. I did my car - FB13 with carb 3 years ago and it cost me 4000 with all plugs and filter. best way ask the price without plug i think it will cost you less than 4000 cox EFI is siple than carb Sira
  14. Yes it is, if you want i can send you the factory service manual to you can download for nissanforums.com the ECU sense bellow items 1. Air Fuel ratio 2. Speed of the vehicle 3. Gear position (natural position or not, this is only got domestic model which is imported re-condition cars) 4. Engine temperature 5. Air condition on/off 6. RPM See this too my earlier post http://forum.autolanka.com/index.php?showtopic=4529 Sira
  15. Yes it is, if you want i can send you the factory service manual to you can download for nissanforums.com the ECU sense bellow items 1. Air Fuel ratio 2. Speed of the vehicle 3. Gear position (natural position or not, this is only got domestic model which is imported re-condition cars) 4. Engine temperature 5. Air condition on/off 6. RPM See this too my earlier post http://forum.autolanka.com/index.php?showtopic=4529 Sira
  16. Small Advice from me. I went to check my exhaust gas level coz I wanted to get my revenue license. I would not tell the plebe but they ware very helpful. I failed the first attempt and they said fix this and come again. I said wait, I know something to fix this What I did was simply turn the screw on the carb call mixture (not sure exact word). The screw located one bellow the white screw. That one is idle speed. Do not turn that. While the probe connected to the silencer and ignition (for RPM count). I saw the CO level is decreasing form 6.00 to 1 and it became 0.45. so the test was ok. another thing is after the adjustment the Pulling power became perfect. The FB 13 carb is electronically controlled and it has ECU too. Also FB 13 cars got Lamda sensor (O2 sensor). When I brought my car 4 years ago some body had removed the Lamda sensor wire. Then the carb get malfunctioned. So if you go for ECO testing make sure the all parts are connected properly and find that screw on the carb. sira
  17. sira
    Co Meter
    Thanks Mathev, I'm looking something Locally Sira
  18. sira
    Co Meter
    All Anybody know where can i buy CO meter? I have seen those in ECO testing places but need to know wheather it is cheap and avalable in Sri lanka Sira
  19. all, since last week dialog speed was very bad due to under sea cable damadge. but SLT still up . sira
  20. friend, dialog was band the torrents .few montha ago and now thay have open it. no restrictions.
  21. Hi My office purchased 4 Mb Dialog wimax line and first 2, 3 weeks it was very fast. downloaded 5 films per day. how ever i never reached at least 3 Mb speed and they telling it is shared bandwidth you cannot get maximum. but npw it is totall crap some times download speed is 20Kb which is less than dial-up. but my 2 MB SLT ADSL is better. i think the physical cable is better than wireless. dialog 4Mb monthly rental is 14000. but SLT 2Mb is 5500 per month. i think SLT is better. sira
  22. Hi I thinik it should be working. i not that much of experience person for PS2 but i think it shoud be Sira
  23. Thanks for all of you Contributed my Question. How ever after 2 weeks research i managed to fix my XBOX with out any mod chips or softmod. i think it is only work OEM CD bot bit a trickey to softmod. So if you want any advice just let me kow sira
  24. don, how much is the modchip if oyu in UK can you please letme knw.i found a place and thy ask me 8000 for repair.
  25. how long was that place located that bulding? i have heard too but some of them said that palce no longer avalable
