AMG
Everything posted by AMG
  1. Thanks fuzzo, but do you want me to drive all the way to Tissa alone I was talking about the journey starting from CMB machan.
  2. AMG replied to Rastima's topic in NISSAN
    jump
  3. Know that. When I bought the Vehicle I didn't realise that and the main reason which I sold the vehicle is the engine. But I never had any problems or repairs with it only the lack of power and the infamous engine.
  4. I owned one in the UK, same 1800cc, YOM 2000. Had it for few months and sold it. My opinion is don't go for it. It has all the comfi things and all but the 1800cc engine is not power enough to pull the vehicle. It takes ages to get 0-60. And I hate that hydrolic powered clutch too. Others are ok. The engine is made by Rover. If you want to buy a Freelander go for a Diesel. Or if you really want to buy the 1800cc, have a test drive for few kms and when you are satisfied go for it.
  5. I can figure out how are you feeling this morning.
  6. As far as I know there is no EK3s holding YOM north of 1998 so you can't find an EK3 YOM 2000 and the EKs came only AT,MT and CVT. Correct me If I am wrong.
  7. 10W-30 is fine. Cos 30 is bit thinner than 40. But never use 50 as it will ruin your vvti system. Pitstop has the original Toyota Oil Filters too. I always use the original oil and air filters even if they are quiet expensive. Used to use the Japanese oem filters and once I found out a huge performance difference on my FB15 with the original Air filter then changed to original and stick with it. And I take Mobil Oil from out side to Pitstop as they don't sell Mobil as they are the agents for Castrol and BP.
  8. Yep. It will be fine to stop when the blue light goes off or a couple of minutes after that. I also do around 2k mileage in in three months and change the oil in every 3 months. I never used synthetic oil. As far as I know Toyota oil is good but I don't have any personal experineces as I always stick with Pitstop even for Toyota car. What's the grade of the Toyota oil which you used? For my vios I used Mobil Super XHP Plus multigrade mineral oil having viscosity of 15-40 and never had any problem. I use the same oil to FB15 too.
  9. There is no way to check when to change the oil. If you are not sure about when was the last change and the mileage, the best way is to just change it and keep records for future. (Some people see the color of the ATF but I don't know how reliable it is) BTW What is the best PAS oil brand in town? and Which is the return line to the PAS oil reservoir, Is that the one connected to the pump? or the other?
  10. Is the Team AL going this time. I am interested as well. I missed a lot of events as I wasn't in the country. Really want to make this. I know the place but I don't want to drive alone all the way to Tissa as it will be boring. Or if I can get a passenger also I will be fine. Any suggestions?
  11. Most welcome bro. To avoid getting sludge best way is to do the oil change as often as you can. ( atleast by the end of three months) It doesn't matter whether you reached the appropriate mileage, the time interval too make sence. And Never Ever start a cold engine and stop it in few seconds. (ie: in a morning you have to move the car few yards to wash it) If you got to start a cold engine make sure you leave the engine running until it gets the operating teperature and then stop. This will avoid the sludge as well. Don't count the cents for the petrol as when you get sludge you will be spending rupees.
  12. Thank you for the quick responce machan. I am going tomorrow and hope not much crowded.
  13. No problem machan
  14. True. Was thinking the same.
  15. Huh..I used call reface as well until i saw Pila's post on this topic and thought Phase must be correct as I know Pila has got more knowledge about the cars more than me do. So I was correct then. Thanks for correcting us Maithri. Just took my car maintenance file and checked the invoice of Viskam brothers and found it also has been printed as Reface. (I had done to my car few months ago)
  16. AMG replied to Rastima's topic in NISSAN
    How much an iridium plug cost machan? And what is the change interval for copper set?
  17. What you see is not sludge machan. For Vios engines, when you remove the oil caps you cant see anything as there is a flat metal surface is blocking the view. (Don't really know the technical name) That is always in brown sladgy color and also it comes to the finger too. The main reason is when the engine is running the oil will not come to this part. You can open the cap and start the engine and see. When you revving only a few small spray type drops will come to that part and get dried and looks as sludge. To find out is there a sludge You have to see a part where the oil flows normally when the engine runs. Trust me. I had a Vios in Thailand. One day when I removed the oil cap I found the same brown color and got shocked as the car was only One Year old at that time and bought as Brand New. Then I found that nothing to worry as the oil doesnt flow through the part you see when you remove the cap.
  18. Also its advisable that when you phase the disks also phase the rear drums too and you should change the brake pads and the shoes. Don't ever put the old worn pads on the phased disk. If you have brake pads in good condition you can phase them too but most of the lathe shops don't phase the pads. You can do it your self with a piece of sand paper and an at least 1 square feet piece of glass to make sure the surface is flat. The best place to get phased is Viskam Brothers (Pvt) Ltd which is on Bloemendhal Road behind Sugathadasa Stadium. They have all the latest machines and well trained people. Also Royal at panchikawatte. (opposite Tyre House Building). Wiskam charges Rs 475.00 for one piece so if you want to phase 2 disks and 2 drums it will cost you Rs1900.
  19. I was just mentioning about the specific link and the you tube machan. I have seen shut up and drive by rihanna video on tele. Also it's bit old song too. I remember it was released in late 2007.
  20. Just wondering when a filling station owner delivers a tanker full of 90 into the 95 underground sump and sell....how much will he make?...lol..... Is that true that both the IOC and Ceypetco are from the same refi? cos I see some one mentioning ona a post some where. I can'd figure out whether the IOC or Ceypet which is good? I always pump at Alexandra IOC and noticed last time that a Ceypetco tanker is unloading there.
  21. Checked the Drive Green web site and it doesn't say that they have a station at Bamba. Can any one tell me where about this Drive Green station in Bamba. Want to get my car checked as my RL is expiring next month.
  22. AMG replied to Rastima's topic in NISSAN
    I changed my plugs with Platinum as soon as I bought my FB15 on May 2006 at D*MO and it cost me Rs1795 each. After that I did tune up at A*W twice and when they check the plugs they said those are Platinum and can drive 100k with them. So I didn't change the plugs yet and the car has done 50k with these plugs and fine. Thinking of changing after 75k as don't want to run 100k with them. What do you guys prefer: 1) Doing 100k with Platinum plugs? or 2) Frequent change with copper plugs? Which is better?
  23. But the link doesn't work in sl.
  24. I guess you can rent a car in SL and drive with the normal full UK DL machan. My friends did. When your visit to Devonshire don't forget to visit the Lands End and St.Ives beach which the most beautiful beach in the UK with white sand and all. Cos you don't normally find white sand beach in the UK. The londoners normally go to Brighton and Portsmouth as they are closer but for me those beaches are crap.
