Az
Az last won the day on August 12 2014
Az had the most liked content!
    Not Telling
My Vehicle Details
  • Vehicle Make
    Toyota
  • Vehicle Model
    Hilux Surf KZN130
  • Engine Type
    1KZ-TE
  • Mechanical Mods
    Full suspension upgrade, front & rear off road bumpers, winch, rock crawlers, heavy duty off road mud flaps, mud tires on steel rims, Jerrycan, Hi-lift jack mount.
  • Future Plans
    Roof rack
3,537 profile views
Az's Achievements
  1. Was this a black Allion and did the accident happen close to the Bellanthara junction?
  2. Yes, that is correct.
  3. I don't exactly know, but it used to have hard & soft suspension modes. However, I don't have that anymore after upgrading with an off-road suspension & lift kit.
  4. Toyota/Emperor Surf owner here. Fully upgraded, and take it on serious off-road trails regularly. KZN130 which comes with the 1KZ-TE engine. Would not hesitate to recommend but you can't get one in the region of 2mil.
  5. While seatbelts can be used in situations where you have no other option, they are not a good replacement for snatch straps. Snatch straps are specially designed for recovery situations, and extend by about 20%, and displays an elastic action which aids in recovery.
  6. Is this a tow strap/rope or snatch strap? 8000 lb may be ok for towing, but may not be sufficient for snatch strap recovery. My snatch strap & tree trunk protector are both rated 12000 Kg.
  7. On a related not, automatic 4x4s not being good for off-roading is a myth. Autos do just as well, or sometimes even better off-road. This is a general comment, and I can't comment on the Y61 though.
  8. Thanks for the info. I will go there & try to get it done.
  9. Yes, seat belts are used in recovery situations where you have no proper recovery gear. Does the job, but if you are into off-roading as a hobby, it is best to have proper recovery gear.
  10. Today I noticed that the chrome in certain areas in my headlamp reflector have peeled off. Is there a place in Colombo/Dehiwela area, where I can get my reflectors rechromed?
  11. AC Paul Panchikawatte has rated lifting straps. Those serve as good towing ropes & winch extensions.
  12. Ah, got the windscreen damaged during the annual trip? BTW, the contact given is none other than our forum member, Sylvi.
  13. +1. One of my friend's had a Steinbauer Power Module which increases the torque output, on his Hilux, and it really works, as @Yala has mentioned. It is quite expensive though.
  14. Yeah, in your case since you are only looking forward to replacing your shocks, you can stick with that. To get more details or advice, you can call up the guy who does all my 4x4 upgrade work. Asela Gunatunga - 777714504.
