Az
Everything posted by Az
  1. Sorry, typo, the cost was Rs. 1050 not 1500, too expensive anyway.
  2. I got 3M clear crystalline tint on the front windscreen & doors, and dark tint at the back, at KP. It cost me about 32k 1 year ago.
  3. Does your friends name happen to be Chinthana?
  4. Thanks. I went to the Crescat stationery place yesterday & they were out of stock. I managed to get it from Innate Graphics on Saranankara Rd., Dehiwela anyway. I was surprised that it costs Rs. 1500 whereas on eBay, the same thing only costs $3.
  5. Hi folks, From where can I buy 3M double sided tape in Sri Lanka?
  6. Fuel savers suck!
  7. Az replied to MeanGreenZ28's topic in The Lounge
    Once In You Should Take Alcohol With Whatever that lobsters cooked with parippu,Butter and beer mug which holds Massive amount of Guinness. Ripper enjoys cuddling his huge soft barf bags with lotsa Intrest. Car Drinks because it enjoys SHAI's tiny nipples and really loud beefeater farts That smell nice. Christmas is coming. Not for naughty hand job related activities but Instead hardcore mud wrestling babes exposing tight pumpkin juice jugs. MasterDon needs some of those juicy melons, otherwise he might go obama on dine-mor donkey racing hippo kebab making buttock inspectors. Meanwhile girl on wheels too need some kind of extra vibrating piston which reciprocates the rubber ducky up her tailpipe with Devinda's black thong wearing fantasy boobies banana hammock. Why virensti likes punany rubbing maruti Indians butts we'd love to kick into Peri's cerebral software license expired rectum. Honda hobbits love Supra_Natural's pink onion flavored buns and bananas bonanza making achchaaru based nuts. MeanGreenZ28 floods Carburretors with Strenuous circular mango chutney mixed mousse' Pink yogurt not without eating camshafts grilled piston-rings, onion-rings, valves and grease filled bearings Jammed solid waste. The reality Bugatti has no hair at the tip of his left Balljoint but pradfred likes little balljoints with greasy flecks of oil on chapathi batman kaboosh with Hydralic Shocks bangkok. Nismo performance Hiace would accelerate infinitely like the devil's urine. Unless Ripper goes wild and becomes a bootylicious babe with big babbylons from hustler. Boost of Turbocharged, intercooled morons increases their marketing or propaganda licking their Manifolds Dry. Cows crank that long hard crank-shaft bearing Smurfs sucking lollipops smurfette angrily poked it down Mani's throat gagging on thick steel rod.AMG's lovely tail-pipe butt can distract a horny Leprechaun clone chewbacca chewing chiwawa from chupakabra chooti-putha choo kolla without his miniscule thingy dangling around. Charitha19 and goldilocks perera Sirimanna are tying paddy cultivation using urea from Stingray's John-Deere tractor painted balls. Coilover springs, peanuts, vodka mixed with Shai's Nintendo GameBoy playing Wii Panties. It's BACK to
  8. I guess not
  9. Az replied to Uditha88's topic in General Automotive
    2 years ago while I was pursuing the idea of fitting a nano saver in my car, I called Mr. Lal Alawatte who was the agent for it at that time, and he told me it works, but I was skeptic & continued with some research & figured out that it does not work.
  10. Az replied to Uditha88's topic in General Automotive
    Sir, With all due respect, I contacted the author of fuelsaving.info two years ago inquiring about the nano fuel saver. After much analysis, he sent me a detailed email about how it does not work (cannot work). These snake oil gadgets are do not work, and if they do, the companies selling these devices would have become multi billion dollar ventures & vehicle manufacturer would have fitted these in the factory itself. So get over the illusion, stop wasting your money and stop promoting these useless pieces of crap. The nano saver is a piece of foil not worth more than a couple of hundred bucks, but it is sold for 4500 Rs! It is a crime! Thanking you, Yours sincerely Az
  11. Why isn't Basketball on this list?
  12. Az replied to Uditha88's topic in General Automotive
    Sir, Re: Fuel Saving Devices With regard to your interest in fuel saving devices, please refer http://fuelsaving.info/ Thanking You Yours sincerely, Az
  13. The problem was traced down to a muffler tip. This has been around for a few months but only since recently it has started giving out a turbo whistle sort of sound
  14. Aha! Belts might be the culprit. Those were replaced recently. I will look into it thanks. I wished a turbo had been installed though The whistling sound is a bit similar to that of a jet engine revving up.
  15. Since recently I have started noticing a whistling sound from the engine bay on kickdown at certain RPMs. It goes off after a few seconds. What could be the possible reasons? Thanks Az
  16. I repainted the boot & spoiler in my car about 10 months ago. The cut & polish was done about 24-30 hours after the paint job. I don't see any problems in the paint so far.
  17. Most probably the engine is overheating & the coolant is overflowing from the reservoir's overflow hose/outlet. Overheating can be due to a faulty radiator, most probably. The coolant level never drops drastically, even after several months. You could run the engine for about 20 minutes and check whether there is an overflow.
  18. Coolant level does not go down that much even after about a year. If the level is noticeably dropping, it may indicate other problems. Most of the places that do vehicle servicing top up the coolant with distilled water, if required. When I was in the US, I bought a coolant density meter which gives an indication about the cooling/freezing properties of the coolant. In my case, if it is below the desired level, I used to add a little bit of concentrated coolant & top up with distilled water, if required.
  19. 100% coolant as in using only concentrated coolant (which is supposed to be mixed with distilled water) or 100% premixed coolant? Using only concentrated coolant without mixing it with water doest not make sense & may not be appropriate.
  20. Az replied to Senaratne's topic in General
    I also changed my tires to larger tires for the sake of comfort, and now there is an error in the speedometer reading. Do we have to change anything in the ECU or is this a mechanical adjustment? Where is Adv#nce Car Audio located?
  21. Hi folks, When I switch on the A/C in my car, there is (quite a loud) clicking noise which is coming from under the bonnet. It sounds as if something is engaging or a relay noise. The car is a Vios, aand I'm not sure whether that sound has been there throughout. Is this normal or can this be due to some issue?
  22. But Mr. Silvy Wijesinghe will be thrilled to find out that even in this era, there are mechanics who can repair these items instead of replacing them/ LOL
  23. Yes, that was the problem. They managed to repair it, and didn't have to replace it.
  24. It is a Bajaj Pulsar, a regular bike I use for commuting to work, nothing fancy Yes, it was vibrating even when revving it up on neutral... the bike become really shaky after 60kmph. I gave it for repairs today, and will be collecting it in the evening. They say that the clutch balancer had to be replaced. I will update this thread once I get the bike back. Thanks Ripper & Yala
  25. Admins, please remove the repeat posts. When I submitted the form, there was a server error. So I submitted it several times, which has resulted in duplicate posts. Sorry about the inconvenience.
