Twin Turbo
    51
Twin Turbo last won the day on September 23 2024
Twin Turbo had the most liked content!
3 Followers
  • Interests
    All things Automotive, kick-ass car stereos.
10,475 profile views
Twin Turbo's Achievements
  1. Doesb the engine over heat?
  2. Hi there, First, get your mechanic to do the needed chedcks (ie, compression check) and confirm your engine needs an overhaul. Next, get a quote from him. Good Luck. TT.
  3. Can you upload a vid with clear sound? Q: was the engine bay de-greased/washed ? TT.
  4. Hi, Get the entire cooling system checked out and pressure tested + hoses checked before you do anything and replace the pressure cap Good Luck ! TT.
  5. Hi, get the auto chokeee trested. \ TT.
  6. Hi, The short answer to the long question is yes, but the chasssis must be lengthened with additional strengthening. plus the rear prop shaft, brake lines,wiring and you'll need to mbuild a cab. The legal side of the vehicle may have to be adjusted with the authority incharge of it. Good Luck. TT.
  7. Recommeend a KE50 - better suited for A/c installaation
  8. Hi, It's a good starting point , but would be better to gett a 4 door saloon for it willhave better resale value TT.
  9. Hi, You'll need to check the timinng belt , if the mileae is correct, repplace the kit at 500.000 Would like to see some pics of the bodywork and engine.
  10. Hi, check if both cooling fans turn on. TT>
  11. Good car, get a manual
  12. Hi, top up with the engine on using the dip stick as a guide. TT.
  13. Many fuel stations have varying amounts of fuel dispensed for one liter.
  14. You have tolook inti mega rust andcorossion too.
