Twin Turbo
    51
  1. Hi and welcome to AL,.. Good project you've started,.. what is the current status of the car? does it run/drive? you just need a good mech to inspect the car and give you a list of the things needed to be done. upload some pics for a start,.. TT.
  2. This came with a petrol V6 - does the rev counter work? do the gears change normally?
  3. Some sirens have a switch to disable it,..
  4. Save your self headaches,..take tour car to TL,..and just say oil service,..and don't forget the transmission,..
  5. At 17 years,.. it's not new in any way,.. and maintenance plus replacements due to age and usage will have to be done.
  6. This part don't look Jap. ?
  7. Hi, Welcome to A/L, good job , cleaning the fuel system. did you replace the fuel filter?
  8. Don't remove the dash, nothing for you to clean that is worth cleaning .besides don't you want to keep the A/C working?\
  9. Most important,.. turn the wheels to full lock, and check the CV boots,.. and the condition of the ATF.
  10. Hi, and welcome,.. Is it correct to assume you are thinking of getting one ? Yes, it's a good car, but at it's age, you'll need to do some work to keep up with neglected maintenance to safely use it. get it inspected and you'll be good. Cheers TT.
  11. Hi , maybe the float getys stuck at 'E-' W hen you continuously keep next to no juice in the tank,.
  12. The moisture in the air within the tank condenses into water,..keep the tank full is one way to void air from the tank,.
  13. One word,.. condensation,..
  14. p.s. Was the cap replaced? Wish you cool runnings,..
  15. You should've made a vid,..?
  16. Better put a rad pressure cap in the shopping list,.. And top up the brake fluid,.. Cheers,. TT.
  17. your battery is fitted the wrong way ,..properly mount it and extend the ground(negative) cable,..
  18. Hi, Good show bro,.. Cheers,..? TT.
  19. HI, STOP DRIVING ! get the wheels removed and brakes checked .. before you loose control of the car.
  20. Replace the spark plugs and airfilter3 TT
  21. which is your car?
  22. IF I am not mistaken your car has all 4 drums. and your pics don't show a booster,.. If drums allround, you'll have 8 shoes,.. A major job in it self,..the stoppers . pay good attention to rubber parts like the flexible brake hoses, and the washers. As for the rad,.. post a pick of the core with the cap off, and how are the hoses? + the cap? And for safety,.. check your t belt,..
  23. HI, First, don't think the last owner ever serviced thetrans. As our locals run till the tranny rests in pieces . So, stick to a maintenance schedule and get the trans serviced , at your local garage, or at a specialist,.. Cheers. TT.
