Everything posted by kush
- Buying A Nissan X-Trail
Permit Transfer
It is only for the poormans' permit.
:::help To Select Best Compact Suv:::
Ranger might be more reliable as it is built in Thailand
Need Help With My Suv
From the look sof it your valve seals are gone, STP will be a temporary solution
CRV RD1-3 or an early RD4 might be within your budget. Dont forget the vehicle prices have come down significantly
- How Many Smart Keys Does A New Car Comes With
Best Car To Buy For 2.5M
Go for a Swift ZC71S (JDM) You can get a good 2007-2008 for that price. Easy and fun to drive, reasonably new model so you will not need repairs.
Honda Vezel
Had a look at one yesterday. Some sellers try to compare this with the CRV claiming that this is equally spacious “FASE”. It may share the same wheel base but that is it. Physical size equals Juke/ Terrios/ new IST. Interior space equals FIT (new one) with bit more boot space. When you sit in the front seat does not feel spacious (but roomy enough) you don’t have the SUV driving position (more car like) Rear seat has enough leg room but the seat is not tall enough for adults. It is a nice looking car if you need a nice urban runabout with bit more ground clearance than the typical JDM (reminded me of the old Swift I let go few months back). Not for anybody looking for a SUV or a soft-roader I was told the price will be in the range of Rs. 4.9-5.4 depending on the grade.
Best Sedan Car For 1.3 Lks
Used both CE100 and SB14 (diesel) each car 5 years over 100,000 km CE 100 no only the A/C was repaired SB 14 had several issues including a suspension overhaul I would recommend the AE100 over the FB 14 Besides it is a well-known fact that the AE100 is the best Corolla to date in terms of built quality and reliability.
Honda Confirms Plans To Discontinue To The Insight Hybrid
There is no reason why the CR-Z can’t share the new Fit drive train With total power of nearly 140 PS (110 engine + 30 i Drive) should be able the deliver better performance than the current car. And ofcause the 7 speed duel cluch insted of the CVT
Abs Light Won't Turn On
Worst case scenario could be removal of ABS indicator to hide an ABS fault. Cause if the ABS is faulty the light won’t go off.
Selling Vehicles Without Cr
I remember sometimes back one of my friends had a certificate from the government analyst to state his vehicle was genuine. Apparently when the vehicle was with the previous owner it was impounded by the police on suspicion and he had to undergo lot of trouble the get things sorted. If you have any suspicions about the vehicle don’t touch.
Honda Or Mitsu?
As i remember there were plenty of reviews on the Lancer in 2007 from USA,Canada, Australia, not the same engine but other features were similar
Bmw M5 In Sl
Saw this yesterday, look stunning even on light blue
Lancer Ex
Unfortunately some of us have kids, since these cars are supposed to be used by families asking to little bit of hardwearing materials in the interior is not too much to ask. Besides if Toyota could get them right I don’t think why Mitsubishi have an issue. They did have better quality plastics in the former CS series.
Lancer Ex
Toyota interior plastics are better, dashboard top, door inserts tops are padded whereas in the lancer they are hard and prone to scratches.
Lancer Ex
GLS has climate control, GLX basic a/c
- Nissan Leaf Launch In Sri Lanka
- 92 Octane Petrol
Suzuki Swift (Beetle) Indian Vs Japanese
My former 2007 (ZC71S) 1250cc (K12B) CVT used to do 10 kmpl Colombo and around 12-14 outstation. There is huge quality difrence and ofcause the price between the two. K12B is free reviving gem of an engine and the CVT gear box did not do justice to it. If you manage to find a manual it will be nice little drivers car.
- Best Suv To Buy For 5 Million
- Lancer Or Axio? Update: Bought A Lancer! (Aka The B.r.a.t.t. Thread)
When opening the LC be specific about the car with reference to your Performa invoice, usually banks do this. If you are opening the LC direct to Japan (not local LC) be specific about the LC charges, if not required as per Performa pass the overseas bank charges to the beneficiary this will be around Rs. 30-50K. U**Mo has a reputation for not sticking to dates given and after opening the LC make sure that you get a confirmation from them that the order is placed. And as for the fuel requirement for the 2007 EX with the 1.5 L engine 90 was good enough although recommended was 95 (According to the user manual 90 was ok if 95 was not available) On my 3 year ownership of the vehicle i switched to 90 when the price difference was widened and did not experience any loss of power, knocking or fuel economy. Now that you have 92 I guess that would do cause most of the engines require 91 and higher.
Go for the GLS if you can afford the Rs. 400,000/- you will never be able to retro fit them at that cost. Are you sure about the Audio being touch screen (in 2007 the diffrence was only pair of tweeters and the 6 CD changer insted of single CD) Dont go by the New Zealand spec check line by line on the U**Mo specs. Get the full specs on your performa invoice, in the past there have been instances where the delivered car specs diffreing (2007 Monerto Sport) Do all the dealings with U**Mo on writing you might need them if you have issues later, they are also known to not keeping to time lines promised so make regular inquires and get updates. Good Luck
Honda Fit Hybrid Maintenance
Viscosity Viscosity (a fluid's resistance to flow) is rated at 0° F (represented by the number preceding the "W" [for Winter]) and at 212° F (represented by the second number in the viscosity designation). So 10W-30 oil has less viscosity when cold and hot than does 20W-50. Motor oil thins as it heats and thickens as it cools. So, with the right additives to help it resist thinning too much, an oil can be rated for one viscosity when cold, another when hot. The more resistant it is to thinning, the higher the second number (10W-40 versus 10W-30, for example) and that's good. Within reason, thicker oil generally seals better and maintains a better film of lubrication between moving parts. At the low-temperature end, oil has to be resistant to thickening so that it flows more easily to all the moving parts in your engine. Also, if the oil is too thick the engine requires more energy to turn the crankshaft, which is partly submerged in a bath of oil. Excessive thickness can make it harder to start the engine, which reduces fuel economy. A 5W oil is typically what's recommended for winter use. However, synthetic oils can be formulated to flow even more easily when cold, so they are able to pass tests that meet the 0W rating. Once the engine is running, the oil heats up. The second number in the viscosity rating--the "40" in 10W-40, for example--tells you that the oil will stay thicker at high temperatures than one with a lower second number--the "30" in 10W-30, for example. What's really important is that you use the oil viscosity your car's owner's manual recommends.
