Everything posted by Ripper
- Ford Capri Owners Club
Diy Center Console Subwoofer Install - Double Cab
i've got plastic covers machang but trying to find a spare set in SL is not gonna be easy! i've tried ebaying too but so far no joy!
tweets alone wont fill the forntstage machang! Also i'm not a high frequency fan I'd prefer to have nice set of midrange speakers and maybe a set of tweets there going through a crossover! Which means i need a 4ch amp to run the door speakers and use 2 front outputs off the headunit to run the A pillar speakers. more $$$ and lot more time. Will have to learn to do fibreglassing too
Not a massive audiophile but i can't seem to pick up any clutter in that sense. Maybe because all the groundings etc are in good shape and i haven't mucked around badly with wiring bits. heh heh... unfortunately you're right machang! i want to setup some mid range speakers on the A pillars cos right now audio is channeled from side and the back and not really from the front.
Well I've Gone And Done It Again!!! Got Another Subaru!!!
you used a high speed polisher or a random orbital one? thinking of investing in one but the random ones cost a fair bit...a metabo branded one is over 40k here. so was thinking of getting a pneumatic random orbital buffer since i have a compressor! Also...how did you restore the roof rails? fresh paint? need to do the same for my truck...
yeah machang! need to get one shipped down cos you cant get decent ones here. ebay have em but shipping rates are a lil high.
Thanks guys!
What Should Care Of When Driving On Water/raining Days!
the logic in that thought is that higher revs will get the exhaust out faster and water wont be taken up through the tail pipe which generally sits very low. Also wading puts a lot more stress on an engine cos the water resistance is quite high compared to driving on dry ground. So the chances of a en engine stall is higher when wading. It's safest to be on low gears and at high revs. None of these will help if the water gets into the intake. Then it's lights out!!! If water gets into your air intake it will be sucked into the combustion chamber. Things will be worse on a diesel vehicle cos the engine runs at higher compression. engine will not only die but also suffer lots of mechanical damaged. con rods etc are known to bend and go kaput. Google "hydrolocking an engine" and you'd get a proper run down.
- Express-Way Updates
well machang there weren't really plans as such. I had to have 0.3cubic ft or more volume inside the box. The box had to fit between the two seats, couldn't be taller than a certain height cos that way it would interfere with shifting. The only thing i had some flexibility over was with the length of the box. within all those constraints, i rigged up the box. Also the internal air volume is different from sub to sub. The one i used is a shallow mount sub that needs minimal air volume. You might want to put a bigger sub than an 8". If i had the choice i would have done the same. If you want, i can just draw up how i fitted the panels. When you say noise suppression, if it's sound dampening within the box...i've used Polyfill. Right behind the subwoofer vent, i've used the supplied rubber matt thing too. But generally from what i've read, polyfill is good enough. As for the diesel thing. It really boils down to the amount of soundproofing a vehicle has. The Ford is prety good in this when compared to say a similar vintage Hilux. If i could add some soundproofing to the doors, , bonnet, firewall and rear panelling...i can knock down a lot more interference from outside. Having said that...i dont really any engine sounds etc when i have the audio running. No cancellation or anything of that sort. AFAIK..For the noise cancellation thing to happen, wave lengths should match and i should be in opposing directions. A very rare event imho! Thanks Machang! Thanks. The carpeting material i used is a good 3-4mm thick machang and it has a rubber/foam kinda backing. So it doesn't feel hard when you rest your arm on it. did a few drives after hooking this up and it wasn't bad. Dunno if it will be different on long drives. I measured the height and fixed it to the best possible place for me to rest my arm on it thanks machang
Adjusting input gain on the amp If all wiring bits are done properly, now your sub should be powering up when you power up your stereo. Like a new engine, subs too need to be "broken in" so be gentle the first few days. To adjust the input gain on the amp...play a dynamic track, say at 75% volume and turn the input gain up until you can hear distortion from the sub. Then slowly turn it down until the distortion goes away. There is a sweetspot where the distortion is not present but you still have enough power output. Do not play tracks in high volume if distortion is present. It can kill your speakers due to an effect called "clipping". In a nutshell, power signals to speakers go in sine wave pattern and this makes the excursion on the diaphram smoother. Distortion clipping is when you over power an amp to the point where the sign wave looses it's smoothness and become a squarish wave. And unevenness of this waves i what kills speaker motors. So folks, that's one way to install a subwoofer to your vehicle at home. things are a lot easy if you're not limited by space as i was. Disclaimer: I'm not an audio specialist nor a woodworking specialist. Just like to listen to good music and enjoy DIY projects over weekends. I've done a lot of reading before taking this project on. Easily over 6 months of research. There might be technical in-accuracies and this is in no way the best way to do a sub project. It just fitted my needs and works great.
When you come to install the last panel, cut open that new tube of silicon caulk and run thick beads of caulk on all inner seams. You can smoothen the edges with a finger before it dries out. After this you can install the last panel and use the subwoofer opening to caulk the edges of this panel. Once its done, all inner edges should be siliconed properly so that there are no airleaks. Leave the finished box in the sun to dry the silicon out. The caulk i used gives out acidic fumes while it's drying and if you were to install a subwoofer into it, those fumes can corrode the sub motors etc. Once the caulk is cured properly and you can't smell any fumes, you can start carpeting the exterior. Visited an upholstery shop closeby and bought some great color carpeting material to match my interior. You can cut the material with a box cutter and a straight edge like a steel ruler and then glue it to the wood panels. I made a little sleeve on the front end of the box to hold a charging phone or the ipod. My headunit has ipod compatibility and with a cable all the playlists etc can be browsed via the headunit. Standard on most mid to high-end pioneer units. After cutting open the carpet material, you can install the terminal cup and the subwoofer. I soldered a speaker wire to the terminal cup and crimped on spade connectors to the other end. Fill the enclosure with poly fill before installing the subwoofer. I bought a polyfill cushion from arpico cos i couldn't find polyfill for sale seperately. The cushion cost 500 bucks or something. Once that's done connect the wired leads and screw the subwoofer and terminal cup into place. If you have a sub grill, now is the time to install it. I dont have one so enclosure construction bit is done. I will be using a steel bracket that screws into the bottom of the box and then to the bolts that hold the seats down to the body. Connect the speaker wire from the amp to the terminal connector on the sub and you're done! finished enclosure
I prefer the use the circular saw to cut log straight lines and jog saw to do finer bits. Circular saw take some getting used to but it cuts wood really fast. Jig saw is slower and you gotta be good at it to make true straight cuts. I bought 1/2inch thick 4'by8' sheet of plywood from a hardware shop. Dont need so much of wood but they don't sel cut pieces. And i can always do something else with the other bits of wood. If your running a bigger sub in a larger box, you might have to buy 3/4 or 1inch thick plywood. "saw horses" to rest the plywood on when cutting Once all the panels are marked out, i cut out all the pieces with the circular saw. The opening for the sub to fit in should ideally be cut off with a jig saw before seperating that panel from the main sheet of wood. You can use a hole saw to cut out an opening to fit the terminal cup the same way. test fitting the sub Use sandpaper to smoothen out edges if required. I ran a bead of wood glue on all edges before fitting them together. It's easier to drive a few nails first to hold the panels in place and then to use screws to ensure a proper fit. the little red colour brush next to the paintbrush is my 3 yo son's input for the project he was pitching in to clear out saw dust
Enclosure build Since space is a huge issue for me i had no choice but to go for a sealed box. Each subwoofer requires you to have a certain volume of air inside the enclosure to work properly. The documentation that comes with the subwoofer generally includes all these specs. These numbers are different for different types of enclosures. The subs i got needed 0.3cubicft of air minimal in a sealed enclosure configuration. Depending on space availability, you can do the math an figure out the box dimensions. I'm guessing that most of these audio shops don't really custom make these enclosures for obvious reasons. So building your won enclosure means has this huge advantage of having the perfect box as it was intended by the sub manufacturer. I made a mistake in my first two sealed boxes. After finishing both the boxes, i realized my measurements were off and i couldn't get them to fit under the front seats. Even with spacers to lift the seats a bit. Since the seats need to be able to slide back and forth and the cable mechanism under the seat too is eating out space, i had to throw away the under-seat sub idea Test firing the under-seat sub ensloure. The only other place to fit my sub was between the front two seats, where you'd get a center console in other vehicles. So the new plan was to use only one 8" sub and somehow make an enclosure to fit it as a center console. This time i thought of making a dummy box with corrugated board first and test it for size before taking the saw to plywood. cardboard replica I had some formal training in architecture and that came in handy. Set squares etc were all there at home so managed to quickly draw things up on board. After all pieces were drawn and cut, a bit of tape is all it took to make the panels into a box. It fitted perfectly to the space i have between the seats so i used those panels as templates to cut the wood. You gotta keep an allowance for the thickness of wood when you make the patterns on wood. Measure thrice, cut once
Audio wiring – headunit to amp Most headunits these days have a direct sub drive. You just need to wire this output to the input of your sub amplifier. Cables are included in the sub wiring kit. Easy stuff Audio wiring – amp to speakers Amps come in different specs and types. “full range” amps can run full range speakers, meaning that they can reproduce both high frequencies and low frequencies. “Monoblock” amps are specialized sub amps and they run low frequencies. Ideally to run a sub, you should use a monoblock amp. But in my case, I got a full range amp that has the option to be run as sub amp. So if i do upgrade later to a monoblock amp, i can use this amp to run door speakers. Amps have a power rating compared to a particular impedance. Say you have an amp that's advertised as 1000w. It will only give out 1000 of power at a certain speaker impedance. Usually that spec is in the finer print If the amp was designed to give out 1000w at 2ohms and you end up connecting speakers that are 4ohms, the power delivery will be a lot less than the rated 1000w. Simply you gotta read all instructions, detail about an amp before wiring it up with speakers. In my case the amp was a 2ch one. And it's gives out it's max performance in bridged mode. Amp bridging is simply combining the 2 channels into single channel. Not all amps allow you to bridge them. Bridging usually lowers the impedance and increase max output. Say a 4ohm 2ch amp with be 2ohm, 1ch after bridging. It will be using more electrical power and will be generating more heat this way. And this is why you should never bridge an amp that was never designed to be bridged. You can visit www.crutchfield.com for amp wiring diagrams to see how impedance can be matched how you can wire 1 or more speakers to an amp. They have nifty little diagrams for different setups. Once you figure out your setup, connecting wires from the speaker to the amp is dead easy. make sure to use proper connectors, crimps etc from the wiring kit. Amplifier mounted behind the back bench seat. Enclosures This was the trickiest bit for me due to space restrictions. Just to detail a bit about enclosures. There are three types of them. 1.Sealed enclosures As the name suggests, these sub boxes are fully sealed with zero air leaks. They take the least amount of space, easiest to get right but needs the highest power from the amp to be driven to it's max. 2. Ported enclosures These seem to be the most popular in SL for some reason. They have one or more "ports" open to the outside. When the sub is pumping, you will get an airflow out of this port. They take more space than sealed boxes and are more difficult to perfect. But in terms of power delivery, they are superior to sealed boxes. 3.Bandpass enclosures. Very rare these days cos they take more space and are a lot harder to be perfected. They offer best audio quality and best power delivery. Hardware 2nos JBL GTO 8" subs JBL GTO 2ch full range amp Bullz audio wiring kit, 4gauge 1/2" thick plywood Silicon caulk and caulking gun Jig saw, circular saw, drill, hole saw to the size of your terminal cups straight edge or long steel ruler, builders square and or set squares. screw drivers, hammer, woodworking screws, nails, wood glue Polyfill carpeting material of choice to cover the enclosure, box cutter to cut the material glue, i used "grip" brand Sandpaper, file, Soldering iron, soldering lead wire Terminal Cup
Power wiring Depending on power output, an amplifier needs a pretty decent supply of current from your electrical system. You need to run a heavy duty + power wire straight off the battery to your amp. The negative terminal of the amp can be grounded to the body itself using a heavy gauge power wire. I used 4gauge power wire. Most headunits have a switching power wire that supplies a bit of current once the headunit comes on. You need to connect this output from the headunit to your amplifier so that the amp will come on only when the headunit is on. It’s a low power circuit so you can use a normal 12v power wire for this. You need to have a fuse on your main power line as close to the battery as possible. Within 18inches from the battery terminal is general rule of thumb. Buying an amp wiring kit really comes in handy here cos all the power wires, speaker wires, crimps, fuses etc are all part of this kit. I bought a Bullz audio wiring kit off ebay. Not the best quality stuff, but for my purpose it was good enough. I did use speaker wires that I bought from SL cos the ones in the wiring kit wasn’t good enough. The fuse on the main power wire chanelling the power wire through the firewall and under the floor carpeting
Hi guys. Hooked up a subwoofer to my truck over the holidays and thought I’d share my experience with you guys. Hopefully it will be of some help to somebody who is planning on doing something similar. Its a fun DIY but if you're on a budget, best is to get it done by an audio shop. I wanted to do it cos i lke DIY despite the time and financial costs The patient When I moved to a double cab from a car, the single biggest trade off was not having good acoustics. I had a decent audio system in the car and except for the headunit I couldn’t transfer anything to the truck due to sizes not matching. I ran clarion competitions series 3 ways in front and alpine type R 6x9’s at the back with tweets on the A pillar. All powered directly off a pioneer 6950ib. I didn’t like the sony headunit that came with the truck so managed to swap that to the one I had in the car before I put it up for sale. The “new” headunit made gynonamous difference to audio quality even with the rest of the system being the same. But bass response was almost non-existent. The truck has 4 speakers in all four doors with fronts with 6” 2-way pioneer’s and rears being 6” 2-way JVC’s. The door thickness doesn’t allow me to put better speakers cos almost al good speakers have large magnets and are deep. The only way to get some decent bass out of the system was to hook up a dedicated subwoofer. And this is where the problems begin. Unlike with a car, double cabs have very little space for a sub. And subs generally tend to take more space. Even smaller ones. The only space I could possibly fit a sub was either behind the back bench seat or underneath the front two seats. I took the front seats out, measured the distances and thought I could fit a sub there. So went ahead and got two JBL GTO 8” subs and a JBL amplifier. Also a BULLZ audio amplifier wiring kit off ebay. wiring kit space under the seats under-seat enclosures that didn't workout Just to get into a bit of detail about powering a sub. There are generally two types of subs. “Active subs” and powered subs that have an amplifier built into it and doesn’t require a separate amp to run them and are fitted into an enclosure from the factory itself. “Passive subs” on the other hand needs an enclosure to be built and also an amp to power it. Passive subs offer more performance and can be customized to suit a particular vehicle or your needs. I opted for this option cos there was no space to decent active sub to fit into my truck.
Another Crash In Southern Highway
Peri deleted those two threads i think. that bugger was having a bad case of verbal diarrhoea... so much of filth in one single reply
Buying A New Car
Harshan has a 406 and knows a LOT about pugs. I doubt all 406's have loads of issues...if that were the case...i doubt Harshan would be owning one.
- What Should Care Of When Driving On Water/raining Days!
Express-Way Updates
I think it's best that you boys dont "encourage" Cali on non-hybrid threads
- Triumph T R Restore Project
- Bmw E 32 7 Series
Hid Xenon Lights
nope. a relay cant "increase" the power of a battery. All it does is operating a high power circuit with a low powered electrical switch. It's good when you dont want to burn your switches out by having high current flowing through them. It has no effect on increasing power. Most people use relays to get power directly off the battery but operate that circuit with your normal switch. A relay is nothing but a electromagnetic switch
Fb14 Cv Joints
if they are making sounds, it does mean they are already worn and needs replacement. If your gaiters are not torn and there is grease in the joint, you should be able to drive that distance without a problem. These joints are made of pretty hard steel and it wont give in that soon. Better be safe and keep the speeds down just in case anyways. If you plan on holding on to the car, dont replace with cheap CV's. If gaiters are good, joints are lubricated a good set of CV's will last a very long time. It pays to check the condition of your gaiters once a week so. main reason for premature CV joint failure is damaged gaiters.
