Ripper
Everything posted by Ripper
  1. if you google or even go through rainbowpages or any similar business listing...it's quite easy find these suppliers. USS services is one famous place. there is another joint in mt. lavinia but i cant seem to recall their name. working with fiber is messy and requires some level of experience. I'd get some practice on simpler projects before venturing into more fine work. resin mixing proportions, amount of epoxy to use on particular weight or cloth etc all take some getting used to. good luck
  2. It's not about what you own and drive...it's all about how you behave here. Hybrids got a bad rap thanks to a few google heroes who took on people who actually have hands on experience with cars. In real life and not only on cyberspace.
  3. Ripper replied to Le Sabre's topic in General
    when it comes to making music with cylinders....nobody does it better than them Italians. Be it ferraris, ducattis, fiats or alfas....all of them sound so damn awesome! This is one of the reasons i find newer cars so damn boring. especially the electric motor driven ones!
  4. i buster the a radiator on my sprinter sometime back. used radiator off a delkanda joint was 10k...with the fan assemble too mind you. So i took my chances with a used radiator cos those was in better overall shape than my busted radiator. the fans, core etc etc. If you're getting the top tank done...i'd get it done at one of those big name places cos they will have lot more experience under their belts and also have a lot to loose if things dont work out right. having said that...some smaller places too do a pretty good job A friend fixed a busted top tank on his v35 skyline...he managed to buy a new top tank from "pioneer motors panchi" and get it fixed at A*W. I saw it after the repair and it was nearly impossible to spot that the top tank repair was done.
  5. Ripper replied to Le Sabre's topic in General
    hell yeah!!!! same here. listen to that engine as it accelerates!!!! that's how cars should sound!!!!
  6. many people have done the upper plastic replacement with success. you can either use a copper tank or even put another plastic top tank without too much of an issue, if your radiator core is aluminium alloy, you cant get a copper tank done afaik. But you can get another plastic top tank done. Having said that...i too busted a top tank pretty badly and replaced it with a breaker yard joint replacement radiator instead of repairing it.
  7. super. it about time we have some build threads here...
  8. you really cant say for sure but chances are...it will too creep up a bit. especially on more popular models.
  9. yes pls truck quantity though...
  10. gotta say ravi k didn't really take him to the cleaners which i thought was a real shame!
  11. ah bummer. i too was gonna do the same over the weekend! Panchi shops it is then!
  12. there are lots of DIY vids on youtube mate. some of them have nifty little tips to get over little hiccups. like not having specialized tools!
  13. running 6400km without an oil change is not advised but that can't be the reason for your friends predicament. Black smoke means, unburnt fuel... Not really familiar with that model but if it's EFI, you gotta check up the whole system and see what's wrong with it. Start with simple things like the air filter, sparks and if nothing is wrong with them...you gotta check the others as well. ie. delco, ignition wires etc etc Once my car was running very poorly with black smoke and the garage bugger couldn't find the problem. I finally tracked it down to faulty knock sensor wiring. Simple the connector pin had come off. Put it back on and everything was perfect!
  14. that's defa a car sale chap! a series of ads are there with same contact details! I know we shouldn't diss AL ads but i doubt that "custom made to order by toyota" thing is true I mean those cars are not available for customization from the factory...at least not to my knowledge
  15. but you clearly knew what the actual model was right?
  16. No idea about prices but the models you speak of are pretty decent vehicles. I'd lean more towards the Vitara. Pretty decent vehicle and it has a decent second hand value. Obviously, since both are not mainstream models in SL, secondhand value can't be compared to mainstream brands like toyota, honda, nissan etc
  17. MG is not in SL, Ace might not have that excuse though
  18. Happy Birthday Boys!!!! Heres to a super duper year ahead!!!
  19. Hmm...ace seems to be a real bkk expert
  20. Ripper replied to mensoft's topic in General
    those fake turbo scoops are there for sale in darley road shops. i'm guessing "sun lanka" type shops should stock them.
  21. maybe taking pics either on a phone, tablet or printouts might work.
  22. maybe he is twelve machang...you'd never know
  23. If your not using the car for longer periods, best bet is to hook up a small float charger aka battery tender and keep. I bought mine from ebay uk and got a friend to bring it down. I have kept my mo-bike battery in good shape for 2-3years with "once-a-week" float charging. It has a sealed type battery and i start the bike once in a few months. After 2-3years....battery will not hold charge though.
  24. http://teakdoor.com/bangkok-forum/88853-bangkok-auto-accessories-secondhand-parts-another.html googled that out... will try and see if i can find a few thai auto forums... that might be the best way to get proper info
  25. something similar happened to me sometime ago. managed use a punch to carve out enough material from the broken bolt and stick a flathead in there. with a lot of wd40, hammering and turning at the same time...managed to pull it out luckily for me,,,the hard bit was to get the initial cooperation from the stuck bolt and once it moved a bit...the rest came out without a fuss I did soaked it with wd40 for like 2 days i think Since that day....very careful with these engine bolts
