Everything posted by Ripper
Engine Oil Changing Problem On Service
Your engine cant get seized up by using non toyota oil unless you used something that wasn't never meant to go in your car engine in the first place. As long as manufacturer recommended grade oils are used, things should be absolutely fine. Personally speaking, i believe these car companies putting out their "own" oil is nothing but and additional revenue base for them using gullible vehicle owners
Toyota Oil Filter Housing Wrench
was doing the screwdriver thing myself but leaking oil from the filter after the puncture made a mess of things. And once the oil is all over the filter, it's a really slippery affair to take the thing out of the engine bay without dropping it. I once dropped it on my garage floor and it wasn't pretty Went for the chain thing purely to keep things clean AFAIK, filter installations are meant to be tightened by hand only. no need to use tools to tighten it hard with a speciality tool. And handling new filters minus oil is pretty easy by hand than with a tool And as for the chain vs the wrench... personally, i find the chain thing easy to use than the adjusting wrench cos the latter needs a socket driver to be chucked in there.
New Mark System For Drivers
#2 and #8 are very dodgy ones cos sometimes coppers have their own interpretations. Unfortunately both those carry high negative points
- Toyota Oil Filter Housing Wrench
Happy Birthday Supra _ Natural
Belated wishes mate! Hope you had an awesome one!!!
Pioneer Power Lead
Places like Pet#o, advance or any half decent car stereo joint should stock them. Even sunlanka should have them I'm assuming what you're looking for is the power socket. generally, "lead" is a cable/wire....
Decorative Paint
Considering one wont be painting a home that often...i would prefer to go for the best brand i could afford. Dulux or Multilac would be my choice... Have been using fair bit of their product range and personally speaking...none of the other competitors comes close. Making up your own paint at home is not worth the risk imho. Paint labour, prepping, time and hassle etc too doesn't come cheap. Why risk it with crappy paint!
SB 14 Engine Overhaul
I would start with basics first.. condition of the air filter Diesel filter Condition of the injectors, have they been replaced recently etc Injector pump service Clutch If it's an auto.. gear oil quality etc If all those basics checks out ok...then you should think of an overhaul of the engine. Usually when an overhaul if due...you'll start burning off engine oil too... THat too should be a dead giveaway if the engine truly has come to a stage where it require a full rebuild
- Triumph T R Restore Project
Ford Mondeo Spare Parts
dont really know much about the mondeo but generally ford parts can be found with asiri motors, rainbow motors etc... Some parts are somewhat generic too. I drive a ford truck and admittedly, parts dont come as easy as it was for more mainstream models like toyota, nissan etc, Also finding even simple things like an air filter while you're out of colombo is hard... Body parts would be even more challenging. I would assume since we have a ford agent here now, things should be better for models imported by them. As for parts costs...genuine ford parts will always be more expensive. this is not something that applies to fords alone. Even genuine toyota parts are pricey compared to aftermarket parts from 3rd party manufacturers like 555 etc, For instance...i dropped a clutch master pump repair kit last week or so.... Seiken brand was 675 bucks, Genuine ford was 3750bucks. I ended dropping the original kit in. Front brakes, genuine is 36k, FBK is about 4K
Importing A Super Bike To Sri Lanka
Honda XR400 ftw! This is great news!!!
12 Led Car Blinking Triangle Rear Tail Brake Lamp Bulb Flash
darley road should have em. pretty fugly to have on cars imho but each to his own!
Racing Cars
So anybody importing go karts already? once that gets going...track days might be a lot more interesting... possibly privateers running karts can be a another category of racing altogether...
Modified 11 Sri Car
I have a different way of looking at this. Despite my taste and judging by almost all posts on this thread seems to lie elsewhere... whoever the owner of this car, put a lot of heartache, money, time and effort into building these things. They have horrible design taste but you gotta appreciate the sheer effort to get something like this done. We all know how hard it is to get something simple done here. So i'd say kudos to the effort! Just wish they had the exposure to learn about proper styling
How To Wire A Welder? Electrical Wiring Tips
So finally i got some time to play with the wiring in me garage. Hooked up a dual pole 40A breaker switch straight off the mains after the meter and ran it through a 32A dedicated breaker. Now it's welding fine got a bit of time in the morning to do the final connections and i welded up 4th setting. Was getting burn through the pipe i was testing on so dint go beyond that power level. My auto dimming welding mask has finally landed in SL according tracking site so hopefully once i get that to me hands...will do some proper welding thanks everyone for the support The problem has been my main distributor box and switches that were only 20A. Dint see that until last evening...
How Can I Install Gps Maps Software To A Gps Unit Bought From Ebay
the 4.3" unit in sl with map costs about 35k Buying a 6" unit online is 10k or so...adding the map makes it 23.5k that's still over 10k cheaper than buying from SL.... and people still want it cheaper? then best is to stick to a foldable, printed map... Even if you do research, you can't buy a gps unit with local maps, not detailed local maps anyway. cityguide gps even have watering holes marked on it fuel sheds, atm's, hospitals, pharmacies etc etc you gotta pay for those value additions cos maps dont make themselves...
so what?
Driving With High Beam On- So Irritating
i suppose people with either poor vision or wanting see more should use a pair of auxiliary light aimed low and wide. I had a pair on my truck that would light up a wide area, say a good 30ft of the the vehicle. Unfortunately the bloody thing went missing after i removed it for a quick refurb... I've noticed many lady drivers seeking added safety behind their high beams 90% the time i hit my heads to get an approaching car to dip theirs... there's a lady driver both pissed off and shocked behind the wheel
talk to either sala or cityguide.. as stated earlier...if it's win ce, has a sd slot...it can run one of these mapping apps developed by local chaps.
1+ I just dont follow with heads on...but also flash it randomly... Once trailed an ahole in an allion from armor street to peliyagoda until he finally pulled over. Douche was on his hi beam HID right behind me for a long time and wouldn't even overtake me even when i slowed down to let him pass. Some sorta mental condition i feel. Then once i got behind him finally, he had to deal with 400watts of hella
it's not really necessary imo. As long as it can take a micro sd or sd card you should be ok. but the unit has to run win CE... If not it wont work.
Another thing they should quickly do is take out those irritating escort vehicles of V*P's and at time choka fellows. The other day a black, fully tinted defender drove straight into me with like 6 high powered lights on. The road was only single lane so i too switched on my lights and drove into the moron. The laws can't and shouldn't apply to only the masses whilst some high powered monkeys are having a ball breaking them
Tnavi aka CityGuide using it myself on a unit bought off online. software was 13500 at the time... Updates are free and if your unit can take a SIM card...you get live traffic updates as well. My unit doesn't have that facility so dunno how effective that feature is though.
