Everything posted by Kavvz
- Auto Car Moves Forward When On Neutral
I disagree. I flick my car into N all the time at stop lights and in traffic. I hate having the car in drive (D) and having to hold it in check with the brake, so I just flick it into neutral (N) which is right next to D. Its a lot less annoying than shifting it into park (P) and going through the gears to get back into drive (D).
Engine Oil Smells Petrol
Fair enough. You might as well inspect the spark plugs when you service the car too. As far as fuel system cleaner's are concerned I use STP super concentrated , but I know "Ripper" and some of the other members have recommend Wurth so you might as well go with that. (If the engine is missing due to clogged injectors, a cleaning additive might not be able to clear them out as the cleaner is more of a preventative measure to be used every other service or so. You might have to consider removing them and getting them cleaned.)
Oh okay. A miss isn't as bad as your engine knocking. Knocking is a continuous,high-pitched, metallic pinging noise, that almost sounds like a rattle in the engine note. It speeds up as you rev the engine making it seem like its coming from something like a timing chain only its caused by the pistons firing erratically. Not the best situation to have, as it usually ends in engine failure if unchecked. A miss is just that; a missed firing cycle in one or more cylinders now and then. I'm not sure what could cause the misfire. If your engine light flashes or a check engine light stays on you might be able to pull an error code off it via a scan tool which would help narrow it down. If not, it'll be tougher and I'm not knowledgable enough to tell you what it might be based on your description alone. Based on the scenario you outlined, it could be a number of things: As you mentioned a bad fuel / air mixture (either lean or rich) could certainly be one of the causes, but it could also be bad spark plugs, or even dirty injectors etc. The car being one that was newly purchased complicates things further. I think the best thing to do would be to try and pull an error code. Even if your engine light isn't on, plug a scan tool in. You might get a historic code which the previous owner might have unscrupulously deleted without rectifying, before selling you the car. Otherwise well, you'll have to bite the bullet, and take it into a trusted mechanic for a bit of poking and prodding. Let us know what it was, it'll be interesting to see what the issue was.
Having the car knock as you drive is pretty bad. Its possible due to the 'tuning' the previous owner did that the car is running lean... I'd curtain driving it and get it looked at as soon as you can. (As for your oil: Maybe its just contaminated oil? First thing I'd do is to get an oil change to establish a baseline and monitor the situation from that point on; but that's besides the point really as initially you need to figure out why your engine is knocking. Hopefully your mechanic will sort things out for you. I'd go over everything on the car carefully for if the previous owner didn't even monitor his oil properly, goodness knows what else is wrong with the car)
Help! I'm Hoping To Buy A Prius
Ah. Things are back to normaI I see...
Steering Wheel Vibration, No Noise, No Movement, But Feel It
Isn't that just your wheels going over the bump? Vibrations when going over pot holes and bumps occur in the steering wheel when your ball joints (control arms) or sway bars are worn too, but there's usually a clucking noise associated with that scenario. Based on your description as far as I'm concerned: No noise and a slight feel / vibration for a fraction of a second in the steering wheel is just the motion of the wheels going over the bump and its not a cause for concern.
lol!! The wonder of all wonders, we have a member of the fairer sex in here!! And lo and behold! Everybody's on their best behaviour I didn't think it was possible but well done: Nice one Gents, nice one!
Ecu Function
The manager may have been referring to something else completely. Did you fail your E-test (smoke test) ? And was the manager trying to advise you on what to do to, perhaps pass it? Catalytic converters only work properly at high temperatures and if you don't warm the car up properly this may cause you to fail your E- test. Usually you need to drive around for about 20-30 mins or so, to get the car up to the proper temperature. Maybe he was trying to express that when he said what he did, as highlighted above? If so, he was kinda right. You don't however, need to drive at 100kmph to ensure you're at the proper operating temperature. In a car that's in good working order, driving around conservatively for about 20-30 mins should ensure your exhaust system is at its optimal operating temperature AND ensure that the ECU is in its 'economical' mode so as to give your car the most probable chance to pass its E-test (smoke test).
Ecu Function
Partly true. As 'Ripper' stated, resetting the ECU will cause the ECU goes into a default setting. From this baseline setting it will try and recognize how you drive and recalibrate itself to your driving patterns. Driving conservatively means it will align itself with a conservative profile that leans towards fuel economy rather than torque. Driving aggressively will cause the car to go into a 'sport' mode where the ECU will calibrate the engine settings so as to provide more torque (pulling power) to be available- unfortunately this does cause the car to consume more fuel. As the outlet manager told you, resetting the ECU triggers this process of 'learning your driving habits' that the ECU is capable of. Where he was mistaken is that: As 'fonfe' mentioned the ECU is always monitoring various sensors and constantly changing your cars settings as it tries to optimize the car's performance. Therefore as pointed out by 'fonfe' it doesn't take much for the ECU to notice your change in driving and shift between a 'economical / conservative' mode and a 'sport' mode/setting/profile. The ECU will in fact alternate between the 'conservative' and 'sport' settings on its own, based on your driving. If you drive conservatively comparatively more that you drive aggressively it should, without you having to reset it, chose to stay in the 'conservative' or 'economy' mode and vice-versa. Resetting the ECU is a short cut to speeding this process up- think of it like hard rebooting your PC instead of patiently waiting till the hour-glass icon does it stuff and stops flipping and turning. How quickly the ECU changes between a 'economical / conservative' mode and a 'sport' mode/setting/profile depends on your car. More sophisticated cars will have more elaborate monitoring and adaptation to driver habits and switch faster between the modes. In more sophisticated cars features such as adaptive dampening (adaptive suspension), adaptive steering based on vehicle speed, traction / anti-skid control, turbo activation, variable valve timing, variable cylinder management etc. will all come into play during the 'sport' mode the 'economy' mode (and in-between-modes) to change the characteristics of the car dramatically between each setting. If you want to see the change in ECU profiles and you have an automatic transmission its relatively easy to experience. Go ahead reset the ECU by disconnecting the car battery and pumping brake pedal 3-5 times. Upon a successful reset you'll see a marked difference in transmission shifts. For the first couple of shifts the transmission might even be a bit awkward and not as smooth as usual, causing you to think something's wrong with it. By driving around conservatively for five or ten minutes or so you'll see that the transmission will smoothen out and start shifting much lower than what it started out at. Keep driving like this and the car will stay in its economy / conservative mode. How quickly it will shift between 'conservative' to 'sport' and any other 'in between modes / profiles' is as mentioned specific to the car.
Ecu Function
I've done it that way, and it works. (Reseting the ECU: Do this by removing the battery terminals and pumping your brakes 3-5 times to drain the current from the electrical system- be warned though that unplugging the battery is going reset everything electrical in the car including your clock, radio presets, trip data, etc. so things will be a bit weird for a day or two.)
Check Engine Light
Not something I can help you with I'm afraid... It might be helpful to get the error code number off the agents when they run the scan as that way you might be able to read up on the issue via forums, technical service bulletins etc. Its interesting that this happens after a long journey. I mean if it was a faulty sensor etc. I'd expect your ECU to throw the error code out all the time. Weird. Either way let us know if you DO pin-point what the fault is. It'd be cool to read up on it.
Petrol, Diesel, Kerosene Prices Go Up
What war in Libya by NATO? You mean the conclusion of the civil war that ousted Gaddafi? Oil prices (world oil prices) should go DOWN 'cos of that, once the Libyans start exporting oil again.
Check Engine Light
Did the agents tell you what the error code was? If you haven't gotten it read / checked I'd start there. [Even if the code has now cleared itself the code scanner the agents use should be able to pull up historical codes. Anything that triggers the ECU to activate a 'limp home mode' should IMHO be looked at as soon as you can.]
Mazda 323 Automatic Transmission
lol !!! 'Lancerfiore' : It depends on how you drive as well as the mileage and the wear your transmission has on it. For a transmission in good repair: Scenario 1: If you go easy on the throttle the car should shift smoothly with a minimal 'blip' or interruption in rev's. You'll certainly feel it if you pay attention, but to your passengers it shouldn't be too noticeable. This is normal. Scenario 2: If you drive aggressively and accelerate hard from a standing start depressing the accelerator to more than 50% of its travel the car should hold its rev's and shift at a higher RPM giving you more time in the torque band so as to give you better acceleration. This will level off and return to a less aggressive shift pattern once you ease off on the accelerator, but if you don't, the car will keeping shifting aggressively at higher rev points throughout all the gears. In this type of situation the shifts will be more noticeable. The gears will shift with an audible change in engine note and will engage in an abrupt manner which you and your passengers will notice and feel through the footwells as slight bump / jerk. This is normal. Scenario 3: During normal driving if you suddenly depress the accelerator to more than 50% of its travel (e.g. Overtaking, rapid maneuvering to avoid obstacles etc.) the engine management system / ECU will recognize that you need to accelerate rapidly and quickly shift down one gear so as to give you more torque. This should happen rapidly and you'll notice a quick change in rev's and engine note as well as a slight bump / jerk as the transmission shifts as quick as it can in response to your need. You and your passengers will notice and feel this shift through the footwells and the seats as slight bump / jerk. This is normal. If outside of the scenarios described, your transmission shifts noisily, with a noticeable bump or jerk or makes a loud audible thump (like you would hear when going over a large pothole) when shifting then you might need to have it checked. It might be that your transmission has a lot of wear on it- In that case there won't be much you can do. However it could also mean that a sensor or a solenoid isn't working properly in which case you might be able to get things fixed relatively easily. Before you take it into for a check I'd suggest you try resetting the engine management system / ECU so the transmission shift pattern resets in the hope that it recalibrates itself to a more gentle shift pattern. (Reseting the ECU: Do this by removing the battery terminals and pumping your brakes 3-5 times to drain the current from the electrical system- be warned though that unplugging the battery is going reset everything electrical in the car including your clock, radio presets, trip data, etc. so things will be a bit weird for a day or two.) Once you reset the ECU, drive conservatively; making sure you go easy on the throttle. The engine management system / ECU should then cycle your car into a conservative setting and you should experience gear shifts as outlined in senario 1. If you still have the hard, jerky shifts / or hear a loud audible 'thump' when shifting during conservative driving, you should probably head over to a reputed transmission place and have the car looked over.
What Will Happen When We Start To Drive With Out Realeasing Hand Breaks?
I suppose you drove around for a bit with the handbrake on and you're asking 'cos you're wondering whether you damaged your car or the braking system by doing so? Well rest assured you probably did no harm. You'd have reduced the life of the rear brake pads by a bit, but brake-pads are cheap and replacing them is a quick, low cost affair. Beside the rear brakes (which are what the handbrake engages) don't wear as much as the front set does anyway, so all-in-all, no big deal. If you want to check on the status of your handbrake after what happened: Find the steepest incline that you come across during your daily drive and pull over on the side of the road without impeding traffic. Engage the handbrake, while keeping your car in Neutral (N for automatics) and keep your foot over the foot brake without engaging it (just in case your car rolls back). Your car should stay stationary. If it does stay stationary you're all set, just remember to ask your mechanic to check on the brake-pad status when you get your tires rotated (every 10,000km or so). If your handbrake doesn't hold on the incline and the car tries to roll back: You should head over to your mechanic so he can check on your brakes for you.
Nissan Wingroad
Doesn't seem too bad, as in it doesn't seem like its something that would wreck your engine by driving further. (See here for details on the error code) I'd reset the check engine light and monitor it to see if it springs up again. If it does re-occur, I'd go to the local Nissan dealer or a garage with diagnostic tools. Reading through the error code write-up, by using a diagnostic tool you'd be able to figure out what's wrong pretty rapidly which I'd prefer over the trial and error method you'd have to employ at a smaller place that doesn't have it. However if, as you say, your chap is an expert; I guess you could tell him what you suspect is wrong or hand him a printout of the error code data off the web and let him loose... If you DO go to the dealer get them to give you a written estimate before doing any work, also make sure you talk to the service manager or the foreman in charge so you understand what they plan on doing. Sometimes dealerships (and I speak of dealerships in general) tend to go bonkers and try to replace every darn thing that could be triggering the check engine light without taking the time to diagnose things properly.
New Led Light Up Rims And Wheels For Bmw 7
As it'd be a distraction to other drivers. Having some idiot driving along side me with those light-up rims would kill my peripheral vision on whatever side they were on. Now what if there were a couple of cars with that crap installed surrounding you in traffic on a rainy night? It'd be like trying to play beer pong with a bouncy ball...
Land Rover Free Lander - Why Is The Market Low??
EBITDA £1,502m up from £350m; EBITDA margins 15.2% up from 5.4% WOW!! That's a massive increase for Jaguar and LR...What on earth? A change in management accounted for all that?Amazing margins too... I wonder how they pulled that off? I guess I'm going to have to read the financials after all Thanks for the links 'The Don'. Am much obliged...
Steve Jobs, 1955 - 2011
lol !! Apple co-founder or not the bugger's gotta be lacking some life skills if he needs SIX gps units / devices to tell him which turn to take. No wonder Tim Cook is taking over as CEO and not this dude...
Nissan Wingroad
What error code number do you have listed on the scan report? (Also how much did the agents charge to run the report?) It depends on the code really. Depending on the code you can usually decide whether its serious issue or whether its just a one off situation where you can clear the code and monitor things to see if it reoccurs again, at which point you can address it / replace the offending part.
Nightzconcepts - Night Rider
LOL!!! Yeap nice if you like providing light ( no pun intended ) entertainment to your neighbours!! Seriously, unless this was driven by a 16 kid I'd laugh till my sides ached if I saw this cruising around my neighbourhood
Cool. Thanks for the clarification there 'Gummybr' and the links. The bloomberg link sums it up well. Quote: "Ford doesn't disclose financial results for Jaguar and Land Rover, whose biggest markets are the U.K. and the U.S. Jaguar is unprofitable, according to analysts. Ford has said the Jaguar- Land Rover combination is profitable. Land Rover posted an 18 percent worldwide sales gain last year to 226,395 vehicles. Jaguar slid 19 percent to 60,485."
It didn't go under, but they were running at a loss when bought by Tata from Ford. Not sure of the state of affairs now. Where did you see the info about their profitability and the breakdown? Got a link?
