6208
Everything posted by 6208
  1. 6208 replied to 6208's topic in General
    What I heard was that if you were taken to the courts you must handover this sheet of paper or you have to stay behind the bars until it is handed over. Cops can also demand it as you should have it with you when you drive along with the licence. Anyway I went to RMV this morning and had to wait in two or three differents queues and finally was asked to go to the Werahera branch. Apprecitae if someone can findout the legal aspects and requirements of this paper.
  2. 6208 posted a topic in General
    I think I lost the paper given with the driver's license (endorsement sheet is it called ?) How do I get a new one?
  3. The usual life span of a O2 sensor is about <75000 Km and then it has to be replaced. http://www.f-body.org/oldfaq/html/tech/sect2.html#oxysensor
  4. 6208 replied to yisaam's topic in General
    found this URLS http://www.finishlineperformance.com/rx8/d...04-04-1374a.pdf
  5. 6208 replied to yisaam's topic in General
    sorry I wasn't taking about an after market unit, it was either Toyota or a Mazda technical guide I was reading. How can I upload a .pdf in this site?
  6. 6208 replied to yisaam's topic in General
    sorry I cannot remember the URL for where I found this information, but what I remember is that there is an electronic circuit that transmit a signal to a central control unit inside the car. The transmitter unit is mounted behind the valve inside of the rim. and it uses a small battery to work, which the site said will last around 10 years. The transmitter has a signature too so that you will not get signals off any other vehicles. low pressure level was 26PSI if I remember it right (for cars?) so as a result if you run on your spare tire (the small one) the warning light will still on.
  7. 6208 replied to yisaam's topic in General
    when you have low tire pressure indicators there is a sensor for each wheel mounted behind the valve assembly, so it has nothing to do with ABS.
  8. find some tech info in here. http://auto.howstuffworks.com/tire4.htm
  9. if you search the WWW you will find a lot of information on the OBDII. I found quite a lot of schematics for translating the RS232 and OBD signals and software that can read the registires in the ECU. But I am still worried to experiment with my own car. A*W has the diagnostic tools for Nissans, so should have one for Suzukis as well. There is a place in Col 10 http://www.mytools.lk/ where they advertise industrial OBD scanners and tools. please let us know if you find any trustful information on OBD II
  10. Here is the wiring diagram of Mazda 3 keyless entry system if it is of any help to you. KEYLESS ENTRY SYSTEM WIRING DIAGRAM -------------------------------------------------------------------------------- B3E090369000W01 1 Trunk compartment light 2 Trunk lid latch switch 3 Front door latch switch (LH) 4 Front door latch switch (RH) 5 Rear door latch switch (LH) 6 Rear door latch switch (RH) 7 Cargo compartment light 8 Door lock-link switch 9 Front door key cylinder switch 10 Trunk lid key cylinder switch 11 Liftgate latch switch 12 Instrument cluster 13 Microcomputer 14 Door lock relay 15 With double lock function 16 Double lock relay 17 Door unlock relay 18 Trunk lid unlock relay 19 Keyless control module 20 Front door lock actuator (driver's side) 21 Front door lock actuator (passenger's side) 22 Rear door lock actuator (LH) 23 Rear door lock actuator (RH) 24 Liftgate lock actuator 25 Trunk lid unlock actuator 26 Front turn light (LH) 27 Side turn light (LH) 28 Front turn light (RH) 29 Side turn light (RH) 30 Rear turn light (LH) 31 Rear turn light (RH)
  11. if I am not mistaken this is what I bought http://www.ngksparkplugs.com/products/cars...&country=US from Asiri Motors in Panchikawattte (some time back though)
  12. pls do that. Mine (2000 BJ5 with VVT) does little more than 8Km/L no matter where I took it or what I did. This is anyway in Colombo traffic during in the mornings and afternoons. I took it to DPMC and CarMart but they didn't find anythign wrong, so just replaced the plugs and filter. When you replace the plugs make sure that you replace them with what manufatcuters had recomended (mine has NGK BKR5E-II) tried platinum tips but didn't help me.
  13. What do you meant by "tune up". These cars just need a good cleanup and if not in good shape replace it, instead of a tune up. so familia's computer is not programmable or upgradable i guess, so just get the throttle and injectors cleaned and replace the spark plugs and the filters. this should do the job and the computer will adjust itself to the best performance it is programmed to. i recommend DPMC or MA**A Motors (Pepiliyana) for this and they have most of the spare part for your car.
  14. usually the petrol pump is mounted on the inside of the top of the tank so the motor is likely to be in the middle or the upper portion of the tank. so if you run with half tank will this lubricate or act as a cooler? do petrol has any lubrication characteristics?
  15. disconnecting the negative cable and turning on the ignition switch should discharge the ecu. most repair shops revs the engine right after connecting battery and i have experience very bad fuel performance after this. leaving engine run idle for a while (5mins or so) always had better performance.
  16. There is a place at Pepiliyana junction - MAZ*A Motors. Owner is a former employee of CarMart. But as far as i know only David Peiris and Carmart has the WDS (diagnostic computers)
