VVTi
Everything posted by VVTi
  1. You are correct, Propane has a RON of 110. So like you said, this could be the reason in itself. I think the main fault lies in the fact that these engines may not be suitable for LP conversions.
  2. Ok, but why only on 2nd gear then?
  3. Why on earth would anyone do that to a Subaru? I am not sure, but the Boxer engine needs high octane fuel... LPG is not exactly higjh Octane if I am not mistake. Someone who knows more about the Subarus might know more.
  4. Most of the 90s Japs cars, the cluster itself holds the data. Its the EU cars that shares inform between the cluster and the ECU.
  5. Duka thamai machang... Considering that some agent's staff will actually tell you how to do it too... I know of an agent revered by some people here who resets the mileage on all their demo cars... Not by a lot... but by a few hundred sometimes... So who do you trust?
  6. BTW... there is another cheaper way of messing up a car's mileage without you ever finding out... That way, one can never own a used car with out ever wondering... 'what if... ?' If you have the time, find a matching cluster with a lower mileage and swap it. You can do it at home and will not cost more than 3-4000... Doesn't that really rattle the monkey cage a bit, eh?
  7. Ok, best thing will be to get them all checked and replace if necessary. Not sure how the set up in in the CK2. If you have been running the AC low gas, then the lifetime of your compressor will be shortened greatly. If not already. Better take the time and the effort to get it all done ASAP. I wouldn't put it off for too long, becasue if the belts fail in the middle of the night, you will be without an alternator and most of all, your water pump. Your call, dude.
  8. The most commonly used belt is a brand called Mitsuboshi. Also BANDO is another brand. Mine's an Alfa V6. It has only one serpentine belt driving all the pulleys. Belts, if you get a good brand and the correct type, width and length is fine. Also Check it matches the number of ribs on the pulleys. Sometimes even if one rib is not there, the belts make all kinds of trouble. If you are getting it all the time, a common culprit could be your AC compressor. What is your car make and model? I had a P11 that ate up belts regularly till I found out that compressor was seizing up and causing it to slip. Changing the belt will only be temp fix if the pulley are getting seized up. Check the pulley one by one and see if anyone of them are tighter than they should be.
  9. Loose belts or worn belts will cause these squeaks. Also a bad bearing on a pulley will cause teh belt to slip and wear it off faster. Best thing is to check all belt conditions, and when replacing, replace according to the spec and check the bearing conditions. I am changing mine today as the loose belt causes the water pump to work inefficiently, overheating the engine. Constant sound was the first indication I got that it needed replacement. There is a temporary remedy, buy a tube of Rubber grease and use a little amount and coat the ribs of the belt. Just a bit is enough. That's how I drove to the garage.
  10. Think that was a bit uncalled for.. Sylvi actually gave some good advise there. If you open a thread asking for opinions, you have to take all opinions with an open mind and then use only what is good. IMHO, Sylvi did say something valuable.
  11. Why would you want to do that? Would you want to buy a car where the clock has been turned? How retarded can you stupid morons can get? Whats with these stupid newbies? Are they all products of inbreeding? are all your parents related to each other????
  12. Actually, it might be the other way around... you might have to stick the car in the engine... Saw the Torque figures for that 12L engine... as Jeremy Clarkson would say, a Planet Mover...
  13. Great Idea. Been dabbling about the notion myself, but then the capital outlay has always been an issue. Start small. My advise is, don't outsource the mechanics unless you can rely on them with your life. A friend has a garage in Seeduwa, Ripper and I were there today also while he was trying to sort our another friends Alfa, and that should be the ideal example. he does 99% of the work himself, has only ONE assistant and takes only 1 or 2 cars at a time. But is equipped with everything you need. All my cars has been fixed by him, and that will not change. My former BMW, the Alfa, my Primera, all cars I had. He is the only one I will trust my cars with. The main issue will be the proper, trustworthy mechanics. Unless you plan on being there 24/7.
  14. Ok, start from the beginning... what exactly is your problem?
  15. Dang JD, that Magnum looks mean! Wifey and I once actually wondered how cool it would be to get one of those with a tricked out 40' container at the back and travel around the country.
  16. Yes, check first if you have enough money to buy. Very important. Then check if you can park the car at home. If car is longer than garage, don't buy. Pays to measure before you buy. Then, since you are buying a Maruti, it really doesn't matter. 6 months later you will wish yo never bought the car...
  17. Yes, check first if you have enough money to buy. Very important. Then check if you can park the car at home. If car is longer than garage, don't buy. Pays to measure before you buy. Then, since you are buying a Maruti, it really doesn't matter. 6 months later you will wish yo never bought the car...
  18. Mitusibishi Canter.... you can keep your garden chairs at the back and fix a set of umbrellas too... The ultimate SUV. You will be the envy of your neighbors and the neighborhood sand mudalali.. Come on, isn't that why most of you buy vehicles? To be the envy of the neighborhood?
  19. Riddle, unlike Ripper I am too lazy to hit the Gym at all.... I have other pursuits to keep me occupied though... And yes, taking the mickey out of people like you can be quite entertaining...
  20. Riddle, mate, we are not bullies... we are really nice people... But you get caught with BS, then you tend to get, err.... err.... reminded that we don't forget With your ABS issue, if you know anything about cars, (basic cars, not the hyper cars like the GTRs you are used to) all you have to do is lift up the skirt of the 110, check inside to see if there is a ABS module, (It will be a small gadget with 6 brake lines connected to it) somewhere inside the engine bay. If its there, then you are screwed becasue its not working or disconnected. Contrary to popular belief, you can survive without ABS, mine doesn't have as it is disconnected due to a failed pump and brakes work fine. But if its not there then don't sweat it. Your car never meant to have it and that's just how life is. Either way, ABS or no ABS, you really need to toughen up a bit mate... stop whining like a little girl all the time about whose bullying you. At this rate you will end up having to breast feed children actually. Now THAT my freind will be quite a spectacle...
  21. Man, we have such wuss's on AL now! I missed those heady days when all we did was talk about Horsepower and 0-100 times. Now all we have are she-males who have ovaries inside their scrotal sacks and are more sensitive than menstruating woman's nipples. Dude... how old are you if your mom is still nursing babies? Of all the places, why inside a car? Dunno about you, I have many friends/family who have children who are still being breastfed, BUT never heard of such a situation as you have... I have had friends and my own sister breast feed their babies in the car while being driven or being parked, and Nope, never had your issue again... In fact it is such a non-event for many that no one cares two hoots. Dude have you been in a public bus? How many women breast feed inside buses??? And no, I never check the profiles before I reply... Should I? Do you come with a warning? 'Handle with Kids Gloves'? All I can say is, sell your 110, and get a life. Also suck it up a bit, Girly Man.
  22. I really think you should sell your car... you have been having serous issues with that car, leaky Steering, leaky Brakes, perverts peeking in while someone inside was nursing a baby, and now ABS failure... sheesh! That's a bad deal, even for a 110. If you went through this trouble over a Euro or at least a Indian, one can understand, but, dang, a messy 110???? Who would ever imagine that there is such a thing as a messed up 110! Aren't those cars supposed to be bullet proof or something, considering the hosannas sung about them by so many people?
  23. Dang! Did the previous owner mention anything? Because he may have disconnected the ABS light if the ABS unit was malfunctioning. ABS must have been broke in the first place. I am sure the previous over cheated you, with the heavy unnatural demand for mediocre cars like the 110 it is easy to fool the new eager buyers. Machang careful when you drive, sometime the modulator might give the wrong signal to the ABS pump and the car might lock up at high speeds. Bad scene, but then since you drove a GTR before, you might be able to handle it, right? Also At such speeds and nursing mothers in the car might find it uncomfortable.
  24. Woo hoo!!! More Allions, ISts, Bists, Beltas, Deltas, Bultos ect... ! Just what this country needs, more Allions and Axios than 3 Wheelers!!
  25. Tightness when turning could mean that the pump has a drop in pressure while at full load. In any ways, a removal and checking will be required. My Alfa had the same issue and a full service and replacement of oil seals in the rack was needed.
