Everything posted by VVTi
Car Steering Issue
Sounds like you need to recheck your rack and pump. IS the belt loose? Is it making any noise when you try to turn?
Help Me To Identify This Switch (Swift)
Dude, is that a used condom?
Identifying Genuine Toyota 121 G Grade
Monkeys demand peanuts... so there is a steady supply of peanuts...
Really High Fuel Consumption
First of all, change you garage. A mechanic who says white smoke = unburnt fuel should be shot immediately. Have you checked you plugs? Is there a miss? Like Peri said, is your tyres Ok, are your breaks binding? Before you even consider an ECU change, check the basics. It could be a vacuum hose that is broken, disconnected or cracked. Over the weekend, park the car in a well lit area and go through the engine bay to see if the are any loose wires hoses.
Whoa!!! Thats bad! my 3.0 V6 does better than that. Check your MAF (Mass Air Flow) sensor, the O2 sensor and your crank angle sensor. Is your GB in good condition? Get your injectors cleaned as well.
Warning About An Agent And Some Advice
What else did you squeeze to get in?
Car Ad Terms
Actually that is for the model that has the flip down signal lights on the B pillar...
Revenue License For A 2008 Car
It applies only if its brand new. Normally the first 3 years you dont have to go for a green test.
Importing Vehicle Parts
Of course. However, if you can get hold of a shipper with an agent in the country of origin, you can load it as SEA freight and have it cleared here.
Japanease Suzuki Swift 2008 Scoop Light And Fog Light Prices
What the hell is a scoop light? Are you guys making these names up? Or is it a broker's term for some uneducated buyer?
I got down a Alfa Booster and pump from Holland and GPO charged me only Rs. 960.
A Shot List Of Tips And Tools A New Diyer Would Need
Don't forget Jack stands. A MUST in every DIY mechanic's kit.
Volkswagaon Passot 2002 And Scoda/bora
Funny you should ask... its an Alfa... it loves Garages... Took 4 weeks to source a original Booster for the brakes. Was just about to pull out of the garage after fixing it and regaining 100% brakes, when the steering started screaming. Found a massive leak in the rack. So stripped it to to its bones. Tomorrow, scouring Panchi to find around 10 oil seals.... The rains are not helping too.
You really should buy a Fb15 shell whatever machang.. VW or any Euro is not for you...
My hobby blew a Steering rack O ring yesterday.... Shoots out red fluid about 6 inches past the left wheel arch... how cool is that??? Just after I got the brake matter licked.
Very bad on all points... stay away from them...
Celtron
The only thing thats is good for injectors is the fuel that you put in. You want better mileage from your car? Keep the tires inflated to proper pressures, have the alignment checked, drive sensible, keep your car light, don't carry unnecessary stuff in the car, keep your AC to a comfortable setting, keep your air filter, plugs clean, Service your vehicle on time and properly. Additives in the fuel disrupt the surface tension at the nozzle end of the injector, changing the spray pattern, this affects the performance in the vehicle. You will not get an improvement, the only affect will be the placebo effect and the lies you swallow from other gullible morons who think Soltron and everything else in the market are the magic potions. Whatever muck they put in the at fluid will seep down to your sump and only God knows what the it does to the oil quality at high temperatures. Keep it simple. Jsut pump the correct fuel and follow factory recommendations for everything else. If additives worked, cars will come with a list of all suitable additives, don't you think???
Celtron
Sorry to be blunt, but if you already swallowed the fact that these gizmos work wonders, you might as well sit and wait the 4 days till the dough rises... Meanwhile cath a bus to work or for your other errands until your fuel tank 'ferments'...
Converted To Diesel
The rule is that you need to inform the RMV first and get permission before you do any changes to the vehicle that requires paperwork to be changed, ie, New color scheme and engine/Chassis change. If you did it without permission, you are in a bit of a situation where they will not even bother t proceed and will find you at fault. They have put a restriction on conversions as Devaka said due to the habit of our people to go beyond reasonable limits. (Body Permit, Vigo/Navarra fiasco, etc) From what I know, they have stopped issuing 325- numbers as of last year. You are better off putting back the old Opel engine and running it the best way you can and sell it off to someone who will look after the car instead of looking at the economics of it or the 'Bigger car than the Jones's car' factor. I used a converted Opel for a while (2001) and it was a lovely car, black with 65 plates. Had a 2C Turbo in it and it used to behave like a smaller car. Solid drive. Great car. Plastics used to break all the time though...
So by your own admission, Sylvi, you would have slept with your own Sister... or Brother, depending on your orientation... Earn the respect you dumb old fool, without going around demanding it like a moron. Even when someone respects you, you are too dumb to comprehend.
Accelerating Issue
A friends 2000 Ek3 VTi had this issue. Its the throttle plate that sticks. He had to clean it every few months due to dirt accumulation on the edges of the plate and giving it a bit of sticky feeling before opening up. We oiled the cables and tried but in the end it was always the throttle plate. We later found out that the air intake had a small crack behind the filter and it was sucking in small amounts of dirt that sticks to the edge. Had it replaced and the problems stopped.
Daylight Extortion By The Traffice Police
I seriously doubt this happened... 25 motorist being copped at the same time would have equaled a riot... thats 25 witnesses to a gross miscarriage of justice. No way! Cops are bad in SL and most of them are stupid... but this cant be true, even by our standards. Did you count 25 cars? I doubt that parking of 25 cars on the side of the road between Senanayake Junction and Raymond junction would have created a massive traffic snarl s as well. Sorry mate... but I think you are just bored and wanted to create an 'interesting' thread... If you can tell the time it happened, we can call the OIC in Borella and ask him for clarification.
Vat
Unlce Sylvi gave a reasonable answer for a change... That's what it is... if you are registered for VAT you can use that for your refund later when you file for Tax returns. Good luck with that though....
Vehicle Tax To Increase In The Budget ??
That was a long time ago... before every monkey, his mother and wife wanted one... Besides, as you say, it was a 121... a better car by many standards. Also, I had a Platz too... long before people knew about it's merits too. I dont put down teh car mate, I ridicule the false following. Sort of a Paris Hilton fan club...
Toyota Axio Or Mazda Axela 2009?
Exrta large FHD...
