MkX
    5
Everything posted by MkX
  1. I wasn't talking about the people who got registered there in A/L. There is a huge difference between the general public and people who comment here on forum. So take a look at the road .. you know what I mean .. (Even without looking at the road I know.. you know what i meant)
  2. At least good that you consider getting EK3 when Majority of Sri Lankans stuck with this typical Corolla and Sunny mind set.
  3. EK3-Vi is an exception compare to other cars in same class. (Edit - comparing two other cars in subject and similar cars during mid 90s)
  4. Yep Nice look ????? Any way FB-15 is the newest car among these and also the most common in the road I guess. With my experience FB-15 is the most comfortable among the 3 cars in comparison. However EK3-Vi. You can get avg fuel economy of 12Kmpl-13Kmpl without compromising the performance. Where as FB-15 give you some where around 7Kmpl - 8Kmpl if you wanted enjoy similar kind of driving pleassure. No off hand experience to comment fuel and performance of the 110. However as a passenger in back seat had little more leg room compare to both other cars but seat was not comfortable as fb15
  5. That is the standard procedure to any RC or any other equipment to do with Radio signals. Also technically we can't bring any mobile phones, etc without TRC license. I faced similar situ when i got a Nokia mobile phone, but they release it with advise not to bring directly. Then again I know people bring so many phones and stuff these day via other channels. Its always person who wants do it properly or small scale has to go through all the trouble and taxes. But big shots will always have the short cuts.
  6. Survival from this kind of accident will not much depend on the type of vehicle. May be some thing to do with your "Karma". If you drive too fast without respecting your life or people around you.. you can't expect some thing good in return.. can you?
  7. Some songs that I call real music
  8. Does loose of grip cause oversteering or oversteering cause to loose the grip on road? Any tips to overcome the situation? Or thare isn't any connection between two? Any racers comments?
  9. Congratulations..
  10. There can be a relationship between these. And i think there should be a protective mechanism to avoid overheat of the compressor due to the excessive use. How you operates you A/C. Do you put minimum temperature when its very hot or when you drive after you parked in Sunlight. Why to reduce the A/C temperature control little by little. Out office A/C trip switch used to get off in hot days and we keep on using it again then compressor got burnet.. same happened two times.. then we fixed another A/C because the load is too much for single A/C. Problem solved.
  11. In most of the cases our road not nore ready for high speeds. People used to speed up in outstations when they come across these nicely carpetted roads. However in a narrow road when a huge lorry or bus comes and they also speeding its just a matter of second to loose control.. may be one big stone in the road or one tyre goes off the road can end up with a tragic.
  12. MkX
    Getting To Know About Bmw
    The 318is and 318ti you mentioned here.. is it without the one that waiting for full restore at Kelaniya?
  13. Check classifiels, papers many available. You'll be able to find good 96 - 98 none VTEC model easyly.. But if you lucky enough will be able to get hold of VTEC model also. However If the car is in very good condition VTEC models might be little expensive.. may be around 1.45M - 1.5M
  14. MkX
    Guys.. isn't BMW M3 or M5 different to same model with IS code. Ex-520is and M5. How many M5s in Sri lanka. Saw an adv in another site saying 520is M5
  15. Guys.. got this images few times through email. Any body knows what happened here. And one photo shows that a lorry also turned around and laying in the road. Place should be some where around Dambulla area. P.S. Hope i've not violate forum rules here.
  16. MkX
    Honda Civic-Ek3
    I've experienced similar thing when TPS doesn't give correct reading. When did you do the last tune up?
  17. ah Yes this new trishaws are gonna be a killer. Those head lights are mounted same level as car drivers face.
  18. Yes I never thought it'll be NO SIGNAL for UMTS mode. I am just 8KM away from Kandy City passing Katugastota. I have Mobitel 3G all the time, but its my official sim so i don't use if for heavy downloads. Got Airtel because of the 1.5GB download thing. Looks like I have to wait some more days..
  19. MkX
    That makes it 2 X5s..
  20. Took airtel connection today. Came home plugged in to the computer.. Guess what NO SIGNAL !!!!
  21. Why Honda and VTEC came in to this? If we leave Honda aside.. There are both SOHC and DOHC engines isn't it. Having VTEC or any other variable valve timing system again a different matter as some of the focused on economy and some power.. some times both together.. But in general if SOHC engine that equipped with valve timing system that focuses on high power out put in high RPMs will some times can equal as some DOHC engines.. isn't it?
  22. Yeh.. and looking at the number of auto trannies in new car market .. it'll be hard to find good manuals in future.
  23. Guys any update on latest market trand for used cars. We saw increase in the price for some of the Toyotas, and no much reduction in Hondas (civics mainly) and Nissans. Any change in last few weeks.. seeing so many Axios in the market as predicted earlier.
  24. I have come across so many Hiace/Caravan Van drivers in Kandy area in genaral. that is really annoying. No respect for road rules at all. And some of the just stop the vehicles middle of the road and talking to people, buying things in road, etc.
  25. nice change.. only issue with quotes are difficuilt to identify.. any way waiting for other changes...
