Sumiya
Everything posted by Sumiya
  1. Hi 3) Back out on the idle speed screw until it justt doesn't touch the throttle linkage. Then screw it in back about 11 turns (what this does mean actually?) This is to keep the engine idling without keeping the leg on accelarator padel, 7) Now turn in the A/F screw until engine dies. If this happens, turn out the A.F screw half turn at a time to bring it back. (try to start the car of coz) (what this does mean?) when turning Af screw in you are leaning the mixture (means you reduce the amount of fuel to a given air intake), when you keep on turning it in engine will die means there is not enough fuel passes throught idle circuit,so that is why they wanted to back it half after engine die, if not car will not start it back 8)Continue to turn out the A/F screw at half turns every 3 seconds. Engine will pick up speed. Continue to screw out until the point engine runs worse. When that happens screw back in half turn every 3 secs to the point engine runs smoothest.(do this by ear or watch engine vibration) (what this does mean?) turn the af screw out , then engine will start increaing it's rpm , each and every turn you must give few seconds to engine to adjust itself for new settings, stop it somewhere when you feel engine has sufficient rpm and doesn't shake it self or stumble (if you have a rpm and vacumm guage you should get maximum vacum and your normal idle speed) as a tip because you are new do this , Keep a full glass of water on the engine bay and watch it should not spill or shake much then try to gas it at once hard it should not stumble or jerk , asssume this is fairly good black smoke also caused by KO piston ring (what this does mean?).. check the compression you got worn piston or rims or leaking valve seats or guide , keep the finger inside the tail pipe and see if it is oily then you have a engine repair to be done if you have oversize carburator main jets none of these will work better you got o reduce them to a lawer size thanks regards sumith
  2. Hi Guys i think ,eventhough by Local Registration Number is old , Komis one is the latest dash and the other is older model that came from early b110 thanks regards sumith
  3. Hi Guys Few updates on the last week end http://imageshack.us/photo/my-images/51/6tzq.jpg/ http://imageshack.us/photo/my-images/692/t6e5.jpg/ http://imageshack.us/photo/my-images/138/hi7t.jpg/ http://imageshack.us/photo/my-images/708/9vgi.jpg/ http://imageshack.us/photo/my-images/29/cqs9.jpg/ http://imageshack.us/photo/my-images/22/tjon.jpg/ http://imageshack.us/photo/my-images/9/0hek.jpg/ http://imageshack.us/photo/my-images/10/l3hc.jpg/ thanks regards sumith
  4. Guys do you have an idea about what is the exact model of the carburator which came with Lancer A72 1979?
    1. Davy
      Davy
      Replied to your PM.
  5. Hi Guys After a long time back on the project , Just had a color code on air cleaner and rocker cover an top grille, happy the way it came for the sunshine it is bright an when dark it looks gloomy,Planing for the first base coat on this week end http://imageshack.us/photo/my-images/577/cueq.jpg/ http://imageshack.us/photo/my-images/854/3gpb.jpg/ http://imageshack.us/photo/my-images/836/9hc2.jpg/ thanks regards sumith
  6. Hi OctaneHead thanks dude , the car that you posted is already my desktop background i love it's color and it is little buffed out and modified a little to give it a sporty look here is the factory specs car enjoy it http://imageshack.us/photo/my-images/837/originsl.jpg/ thanks regards sumith
  7. Hi Nzer Thanks, So far have lot of dudes helping me from datsun community all arround the world since that i came so far good because this is ever my first rebilding project and this is not my job just a hobby , i will not be able to take it perfect to 100% but i will try to be somwhere 90% but from my next rebuild i will try to be 99% on because i have gathered so many expierienc have done lof of mistakes made and corrected ,probebly next will be my b310 or Morris 1100 MKii thanks regards sumith
  8. Hi Nzer I am doing them my self along with the help of my father as i am free on the week ends,My Father is sound with Mechanicle stuff and we both did fabrication together as none of us was very good on them , all the rest will be doing my self except Upholestory work thanks regards sumith
  9. Hi NZer Thanks for the ideas , yes i have noticed them already , i got to to do a lot since it has major fabrication on it , Just going on to those areas slowly with smoothing the pannels, this is just a basic filler code to identify minor imperctions and so ,Most pobebly i might finish alignment pannels and extra filler coat on this week end. Brought Few Littres of Base coat to match with Debear (Toyota 8L5) top coat plus debear clear coat, i cant linked photos direct to the forum as earlier it says " you are not allowed extension on this comunity" i don't know what it is and don't need to bother about even http://imageshack.us/photo/my-images/577/81411523.jpg/ http://imageshack.us/photo/my-images/545/26268167.jpg/ http://imageshack.us/photo/my-images/11/21589619.jpg/ http://imageshack.us/photo/my-images/20/90153493.jpg/ thanks regards sumith
  10. Hi Guys Few updates on the last week end stuff http://imageshack.us/photo/my-images/203/13675309.jpg/ http://imageshack.us/photo/my-images/15/29315937.jpg/ http://imageshack.us/photo/my-images/32/47868724.jpg/ http://imageshack.us/photo/my-images/163/37430046.jpg/ http://imageshack.us/photo/my-images/90/70200800.jpg/ http://imageshack.us/photo/my-images/585/37095820.jpg/ http://imageshack.us/photo/my-images/521/91006345.jpg/ http://imageshack.us/photo/my-images/706/94654526.jpg/ http://imageshack.us/photo/my-images/834/26813120.jpg/ thanks regards sumith thanks regards sumith
  11. Hi Guys Thanks a lot for valuable info guys, actualy i am not doing that stupid thing for my cars, my father in law wanted some info about converting his petrol lorry to diesel , thanks regards sumith
  12. Hi Guys Just need some info about procedre price of documentaory work to be done ete etc to convert petrol car to a diesel car thanks regards sumith
  13. Morris 1100 MK2 -5 Sri for another project or i will give a enthusism for a cheap price
  14. Hi Guys Brought these stuff from pioneer motors Ignition coil with resister ignition condensor spark plug wireset spark plugs Contact point carburetor repair kit fuel filter Reassembled the Starter Motor Cleaned the stator and armature and will be installing a new set of brush set soon,and found viper motor was in good condition i used it sparingly it used to stuck the moving arms always and reassembled the carburetor with rebuild kit with factory specs jets. Had to put little putty on minor scratches found on the behind and behind doors together and wet sanded them to the smoothest possible,found that the filler primer was not enough thick to keep it strong enough when sanding and found my gun tip was smaller than paint manufactures specs ,no problem there will be another complete filler coat later on,so had to put a little oil primer on those areas to avoid them get rust by next week end i got pics but there is no way that i can upload them today i will see whether i can upload them later, No other way to show them here they are http://imageshack.us/photo/my-images/201/11608463.jpg/ http://imageshack.us/photo/my-images/687/34537151.jpg/ http://imageshack.us/photo/my-images/203/86937126.jpg/ http://imageshack.us/photo/my-images/33/57048537.jpg/ http://imageshack.us/photo/my-images/833/11650744.jpg/ http://imageshack.us/photo/my-images/823/77828462.jpg/ http://imageshack.us/photo/my-images/405/79517959.jpg/ http://imageshack.us/photo/my-images/96/50220899.jpg/ http://imageshack.us/photo/my-images/9/91925378.jpg/ http://imageshack.us/photo/my-images/402/85540395.jpg/ http://imageshack.us/photo/my-images/713/94722270.jpg/ http://imageshack.us/photo/my-images/827/63334772.jpg/ http://imageshack.us/photo/my-images/163/33251585.jpg/ thanks regards sumith
  15. Hi Guys As Per the Car Documents it is originaly metalic Blue, i am also hoping the same as that thanks regards sumith
  16. Hi I saw this advertistment on somewhere , that time i called the owner he did not pick the phone,since that is 2 door i gave up the idea,i have seen only one datsun 510 4 door sedan with yellow color at kahathuduwa ,then after this is the 1st time i am seen a 510 here ,good one rocks thanks regards sumiya
  17. Hi Guys Time has gone far a lot ,but i am behind the time as of restless life, meanwhile my projects is also going slowly,don't blame me taking so long time,all these suspension parts and leaf springs differentail have been fitted to the car . and also new Brake master Pump.brake pads brake washers brake pistons caliper etc in. and painted radiarator front grill fuel tank and also managed to oil primer coat and half of surface filler to the car , Next finishing target has been set to april, will try to sytrict to the schedule Rebuilt the engine with new set of bearing and ring set with Standad size pistons and new set of valves and guides along with a head refacing , by the way there is another morris 1100 Mkii is waiting as the next project on behalf of the b310,B310 has to runabout another 1 year without a rebuild I can't Upload Images to imageshack is it not allowed in the forum now ??? http://imageshack.us/photo/my-images/855/71814754.jpg/ http://imageshack.us/photo/my-images/832/04022013226.jpg/ http://imageshack.us/photo/my-images/22/04022013227.jpg/ http://imageshack.us/photo/my-images/341/10022013232.jpg/ http://imageshack.us/photo/my-images/407/10022013233.jpg/ http://imageshack.us/photo/my-images/571/10022013235.jpg/ http://imageshack.us/photo/my-images/825/10022013236.jpg/ http://imageshack.us/photo/my-images/849/10022013237.jpg/ http://imageshack.us/photo/my-images/577/10022013240.jpg/ http://imageshack.us/photo/my-images/692/31012013204.jpg/ http://imageshack.us/photo/my-images/16/abcd0001nc.jpg/ http://imageshack.us/photo/my-images/90/abcd0002ov.jpg/ http://imageshack.us/photo/my-images/46/abcd0003aq.jpg/ http://imageshack.us/photo/my-images/835/abcd0009hw.jpg/ http://imageshack.us/photo/my-images/543/abcd0010t.jpg/ http://imageshack.us/photo/my-images/801/abcd0011p.jpg/ http://imageshack.us/photo/my-images/825/abcd0015l.jpg/ thanks regards sumiya
  18. Any Body know a good guy who can do a good puter welding in colombo area
  19. Any Body know a good guy who can do a good puter welding in colombo area
  20. I am looking for dump ass who drove QJ-6639(Red Color Threewheller)if any body notice call me on 071-9254547,that asshole banged my mother to injuries and ran away
    1. Show previous comments  19 more
    2. Davy
      Davy
      Damn... Hope your mom will be alright soon and hope the cops get to the three wheeler driver as well.
    3. NRX
      NRX
      machan, the vehicle currently belongs to someone in Dankotuwa, it might be on open papers :)
    4. Crosswind
      Crosswind
      Open or closed papers don't matter. The current owner/driver can be traced thru him by the cops.
  21. Hi Guys Hunting for Nissan OEM 55044-H5001 (BUSH-FRONT UPPER LEAF SPRING ) part no all over the Colombo still no luck it seems no body brought them down there are enough of 55046-H5001 instead of but little smaller in size, so finally decided to go for them and do some modification to make them suitable . thanks regards sumith
  22. Hi Carboy i have maximum 2 days for a week to work on this Hopefully within 2 other months,mine AC is factory fitted and there are some after market model too , AC is not a primary concern right now , but later day it should be .. thanks regards sumith
  23. Hi Don Since i need 8 more bushes of that measurement i would better try out a little more ,If hopefully have Nissan OEM no i think i will find them at panchikawatha,It is not so easy to make them suitable since i need to cut out some rubber from inside bush so that i can insert them into the leaf suckle. thanks regards sumith
  24. Hi Guys Prepared the differential with new Oil and Started rear suspension work with leaf spring bushing etc,Had issue of inserting upper Suckle Bush on Top Mount on suspension,Was struggling with hell of work whole day work got stuck in middle finally went through the Repair manual ,damn 8 bushes were 1 mm differ from original specs, Useless day of sunday !! Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us thanks regards sumith
  25. Damn I Lost My Car Key, where can i buy a Good Key Tag for the spare key ? what about Super Market? do They Have them ?
    1. Show previous comments  1 more
    2. Sumiya
      Sumiya
      ThX i went there ,They are avialable nice looking for my opinion those are are too heavy for the Key Holder will be having unusual wear out,anyway Found good looking Leather Key Tag from closer book shop
    3. Schiffer
      Schiffer
      yeap they were a bit heavy tbh.. cool mate.. congratz :)
    4. Magnum
      Magnum
      lol i need to get a good key tag! :D
