Everything posted by Sumiya
Katukurunda 2010 Racing Video
Hi Damith That is a great drive congrts dude thanks Regards sumith
New Suzuki For 18 Kmpl ?
Hi Guys Yes correct , i believe it will not do much as they says, and they had a statement below it "tested under certain conditions" so probably they might tell (below 2500 RPM between 20-40KMPH ) , for this you don't want a car either a foot cycle or even a good bullock cart with good bull will do the same thanks Regards sumith
Hi Anjula I saw it looks like a sedan , i doubt this is the car that was there in that hoarding, just i was passing there couldn't see it properly thanks Regards sumith
Hi Guys Yesterday saw a Hoarding near Gangarama Temple, there is a new car coming from suzuki sedan claiming that it will do around 18KMPL on , has any one noticed or bought this car,it looks to a suzuki Liana . i cant remember its model name , i guess it it is realy doing that KMPL that will definitely may have a good market here thanks Regards sumith
Quick Trivia Part 2
Hi Devinda Nope ,this is not Premier Padmini thanks regards sumith
Quick Trivia Part 2
Hi Guys Here We go another one http://yfrog.com/ju68322425p thanks Regards sumith
Quick Trivia Part 2
Hi Harshana Then for sure this is Mazda 1500 (mark 1) ? with in 1970's thanks Regards sumith
Quick Trivia Part 2
Hi Harshana peoguat 504 arround 1970 thanks Regards sumith
Engine Performance
Hi Peri isn't it too much dude ? might be a silly question without knowing what you drive thanks regards sumith
Engine Performance
Hi Navile good Luck ... ! any way your fuel figures were not bad at all,but when you seen it at once you don't want to reduce it , Would like to know how mush it was costed for Platinum spark plug new set ? thanks Regards Sumith
Engine Performance
Toyota Corolla Ce 110 Vs 114
Nope Dude that is for CE110 not CE114 thanks Regards sumith
Cannot Slow Down The Idle Speed !
Hi Hyundaisantro if you are not confidence about doing this,Best thing is that before you move Delco, mark it with the engine housing and turn it bit to retard, advance ,and you may feel engine become smoothing at a point, if it didn't work keep the delco to the original position and go to a mechanic Usualy delco cover or engine housing has A (advance) R(retards) mark on it.you may need to turn it to retard side a bit as ripper said (most probably it should be turned to right hand side). thanks regards sumith
Give Me A Real Answer By Experience
Hi Mate Actually Lancer Flat light and 1400 Wagon according to my knowledge will do between 10-14 Maximum(if your car is in mint).you may increase it a little bit by replacing Carburetor Jets with lower size ( for ex :- Main Jet 120 size to 110 , Idle Jet 95-85 etc). Actually i don't know what actual size yours carburetor jets. But it should be done with a good carburetor mechanic (if it is too low you may have engine knocking and pulling problem) Other than this Good spark plugs, rotor, distributor cap,air filter ,contact breaker point,ignition condenser , ignition coil + wires will simply increase you pulling power on it. Thanks Regards sumith
What's This Engine Bay?
Hi Mate any help ? is this Japanese classic ? thanks Regards sumith
What A Funny People We Have
yes mate But there are different models to suit those two different purposes Main purpose is avoid Pressured air which is called (external scoops) other one is for venting as u said keep in mind the main purpose is not venting (this is optional) as i guess all cars from factory have some sort of ventilation system too rather than a need of scoop ..even though it has Ac or not. thanks Regards sumith
Hi Harshana True thanks regards sumith
Hi Mate Yes it is i know, where in the world people fix bonnet scoop on the roof , the function of the bonnet scoop and roof scoop are different, roof scoop's function similer to a spoiler where bonnet scoop's task is different mate. i initiated this thread seem a buger who has fixed a bonnet scoop on the roof , not the particular picture there these fancy works are funny for me anyway for some people it might not thanks Regards sumith
Hi Skyline R33 Ha ha ha ,this is much more funny , this bugger is so so crazy thanks Regards sumith
Hi Guys Today morning i saw a maruti car having Bonet Scoop on the roof.I dont know whether that bugger knows what it is called (bonet scoop) if he knows this name he will not hook it there on the roof. Since it has been a trend fixing a bonet scoop here ,even though it has a task beyond that what a funny guys we have don't know whether has fixed it on the roof to get ventilation to the driving cabin thanks Regards sumith
How To Pass The Green Test?
Hi Mate Mainly Cleaning you fuel system New set of Spark plugs New Fuel oil and air filter new contact point(if you have contact point ignition rather than electric ignition) Mainly these requirement depend on the condition of you vehicle and smoke and make sure that you should keep your car on normal operating temperature while you are there (very important) thanks Regards sumith
Accident Repair
Hi NPrimera Yes , You may force Insurance to pay in full at the agent, as long as you have not under valued car for insurance once this happened to my uncles' swift he argued with the insurance fellow and got approval for agent price you need to be little talkative a bit so you may not give any excuse for insurance guy to avoid you thanks Regards sumith
Seat Belt
Hi Guys Always, but my classic doesn't have one, actually i am searching for a proper seat belt for it can any one tell me a place where can i buy a seat belt set for a reasonable price ? It is a must for me to have it on my classic since i mostly use it for cheaper running expenses thanks Regards sumith
Catalytic Converter
Hi Dilesh No O2 sensor sense(unburned fuel ratio) and give instructions to ECU to Lean in or Lean out air fuel mixture getting oxygen ratio of the exhaust , if it doesn't functioning properly(not getting correct voltage depending on O2 ratio) you get bad emission that is indicated through dash thanks regards sumith
Catalytic Converter
Hi Dilesh i guess air intake and level will definitely have effect on exhaust, because what ever air intake should be burned with fuel and final output is exhaust isn't it ? thanks Regards sumith
