Everything posted by Riz
Maruti Cv Joints
I bought a Maruti recently, i tend to hear a CV joint " tak....tak" noise while driving straight, while turnong t wheels i dont hear any funny noises, any ideas pls.
Nissan Fb14
Overpriced.....perhaps for another Rs. 50 K or 100 K ur friend cud buy a FB 15. I reckon max price is Rs. 1.3 - 1.4 mio
Engine Tends To Stall
Thnks guys for the advise / replies. 1) FB 14 runs on electronic ignation, hence no ignation coil 2) I cud not locate the Air Flow Sensor, where is it located pls
I run a FB 14 car, engine runs smoothly and suddenly tends to stall (rpm reduces) and subsequently ok and again tends to stall. This cycle continues but engine have never completley stalled. What may be the isuue pls. I have cleaned and readjusted the spark plugs, cleaned distributor and throttle body. Air filter too looks ok.
What Are The Advantages Of A 4Wd Car
Yes FB 14, which came with the chassis No FNB 14
FB 14
Hi, I intend purchasing a 4 WD car (1995 model), purchasing Rs. 50 K less the the normal market value of a 2WD vehicle. Any advises pls, with regard to the followings. - Whether 4WD could be converted to a 2 WD - Disadvantage of a 4 WD vehcile etc ...pls
Suzuki Every Wagon
Price perhaps Rs 1.6 - 1.8 ok, i'm really a mini van fan, istnt it a real beaut. Mini's are excellent on petrol
Buying A Seized Car
Bro, no legal implications or potential problems, as far as i know genereally Banks and Finance Co do not lend for vehicles with disputed title. I have bought vehicles, few things to check. 1) If english no vehicles, chk with the co whether VIC in possession (certain co's do not retain the VIC) 2) Chk whether revenue lic available 3) transfer papers in order Even if 1) 2) are not available, duplicate could be obtained Basically thats it, As i'm a bit of an expert in finance/recovery field, answeres for quotes 1) Normally a finance co cannot auction or sell a vehicle which is under a court bond or in police custody if they do its illegal 2) Previous owner cannot claim title. But vehcile should be seized after terminating the agreement (agreement terminateion is a matter of forwarding a letter), if the agreement is not termintaed legally a company cannot repossess. But to my knowledge vehicle owners have never claimed. ..........but person like me will claim ---------------- 3) Of course vehicle seizers replacing / removing parts are very common, so buyers beware when purchsing
Dashboard Meter
Hi, I drive a Pulsar CJ 11, auto, since recently the car dashboard meters speedo, rpm, fuel and heat and also mileage (digital) gives an irratic reading but all lights gear shift lights, turning lights etc.. are working. I assume this may be due a minor electrical defect, any idea good souls where i cud repair this (around Colombo). I have another option to replace the entire meter unit, but prior to that i thought exploring this so that i cud save a little of $$$$$ Thnks
Engine Vibration On Gear Engagement
Archon - No i have not checked the colour of the oil, i shall check it tomrow... Don - Accelaration ok, when the engine is hot the vibration tends to reduce a lot, vibrates a lot during first cold start, another one more minor issue the engine too vibrates (gear disengaged)in the morning and once hot idle ok.
Well jdnet, actually i did a minor tune up cleaned the plugs resetted the gaps throttle body clean etc, which actually gave a little bit of a quick start and accelaration. But vibration (gear engaged) reduced after ICV valve clean up, Is there any other things to clean.. reset etc. other than mounts.
Thnks a lot for ur advises, yes ICV valve and spark plugs were cleaned as Elvis said, the vibration reduced a bit, but not completly, vibration was terrible earlier. Although Gayan's prediction was gear box screwed, i was pretty sure since vibration reduced after ICV clean up gearbox was not at fault. May be perhaps as other advises, shall go underneath the van and check the conditions of the mounts etc..
Thnks guys for ur answers. Elvis - engine vibrates , idle ok. Anjula - ????????? Nexus - Yes Honda Acty,a/c on or off same issue
I have a mini van auto gear. Problem the engine tends to vibrate a lot when gear is engaged to either D or R. On neutral / parking engine idles smoothly. Any ideas pls
Warning About An Agent And Some Advice
Jdnet superb work, hats off for posting the thread, its basically an eye opener for those who take their vehicles even for a very minor repair / check ups (replacing even a fuse)to garages, which invariably, maka basses make a meal out of it. I never take my vehcile to the garage unless i check first, let me explain my recent experience, my Mini Van early morning / first start idle was very iratic and engine tends to vibrate a lot, but however this tendency goes off when the engine is hot, took it to a nearby by Garage for an opinion, there advice - replace al spark plus - throttle body Full clean up / service - Full injectors clean up - change Air filter. So i worked out approx cost Rs. 10,000/- bucks, since we dont have time on weekdays, i on my own chekcd on a weekend ....no wats the problem was......... a slight leak from the manifold Gasket.so simple i bought a cellastic tupe and didnt even remove just applied over it........problem solved. My total cost Rs. 250/- bucks for the cellastic. So my kind advice to all vehicle owners pls atleast get a basic idea of vehicle mechanics, cardinal principal - don't take your vehciles to the garage for evry small thing, if the makabasses get to know that u guys knowledge on vehicle is zero, they will take ull for a ride over the moon
Engine Misses During Morining Start
No not at all.
Tks Sumth for your reply, but i dont think overnigt parking is the issue, since parked under a shed. other thing this doenst have a distributor, the coil is conneced to the spark plug (distributorless ignition systems)
I have a Mini Van Honda Acty 650 cc Auto, 3 cylinder. Problem is that the first accelaration in the morning is very difficult, engine tends to misses a lot , very low pick up. however this tendancy ges off when engine reaches the normal tempreature level. I have cleaned the sprak plugs and throttle body to no effect. Any ideas pls
Duplicate Car Registration Book
I too had the same issue, a remedial action, try to get a computer prinout from RMV and c whether the Duplicate CR No and the computer printout Last CR No are identical, if it is so ok. and also if possible get hold of a peon a check the car file in the RMV to c whether any police report is available But its very difficult to convience the buyers sometimes. i have heard of many irregularities taking place with originals being used for tampered vehicles and same duplicate CR used for the original vehicle. But honestly what happens if a book is genuinely destroyed or misplace, hard luck for the owner
B 14 Service Manual
Does any downloading experts know from where i cud download the service manual for my B14 (1994 model) basic car.
B 14 Engine Tempreature Gauge Not Working
Bought a B14 (1994 model), 1.3 car recently, the temp gauge seems not working, Also another aspect the radiator fan is connected directly to the ignation, i cannot come to a conclusion whether this is done to avoid overheating, since tempreature gauge is not functioning Any expert advise on both the matters pls - How i cud check the tempreature gauge, also one of my friend told me to check the sender unit, if so where is it located - How i cud connect the fans to work automatically when tempreature requires the level
Engine Speed Flctuations
Engine stalling problem resolved - changed the CAM sensor Speed fluctuations resolved - Throttle body flap even on closed position slighty gap evident , temproraly done by covering with silicone. Is there any other way to change only the flap rather than changing the entire throttle body. For the entire thing costed around Rs. 8K, but totally cost around Rs. 25K just to diagnose the problem. Van runs fine now, does around 13/14 km per litre Colombo runing.
Ae110 Catalogue
Boy, very difficult to get catelogues , even i wanted a cateloge for my previous Corolla , No Luck! Better ask from SANTA!
Cold Starting Issues - Engine Idle Issues
I have a mini van 650cc, EFI, 3 cylinder, starting the engine when tempreature is zero is somewhat difficult, even if engine starts the speed increases and decrease on its own for some time and when tempreature reaches a certain level engine runs fine. Can this be due to the folowings - Overfuelling , since when plugs are removed are completley black , is there any why i cud reduce the amount of fuel distributed to the engine - can this be due Cold start injector fault OR - wheather injector needs to be cleaned Throttle body totally cleaned Any expert advise appreciated
