Everything posted by bpcd
An engine compression test will tell you many things about the mechanical condition of your engine. The test can detect, for example, pressure leaks through rings, cylinders, valves, or a head gasket without taking apart the engine. So you'll save a lot of time and money in diagnostics.
Nissan FB14, Toyota Sprinter AE100 you may consider
March k11 might be a good choice
Nissan FB 14 Car Shutting down issue while driving
bpcd replied to buddhika1234's question in Electrical problems
try with a new battery (temporary) and see if the problem persist. otherwise it might have a ECU malfunction. -
check your battery condition, terminals and charging. -
it is better to give more details than just giving your trouble. i hope this is Y12 is it cvt or conventional gears?
you do not need special permission or licence to go around with your foreign friends unless you work as a guide.
there is no doubt Vitz
yes, it is possible to get a driving licence for differently able people first you need to convert your car according to your requirement ( in Sri Lanka there are not much expert to convert vehicle for disabled as in developed countries ) then you register it as a invalid carriage vehicle next is go to Nugegoda and get a medical report from the consultant. ( if you are lucky you will get the report as a eligible to drive a vehicle, I am saying like this because we don't have specially trained medical officers or examiners so even if you can drive properly you may not get the permission due to thinking way of prejudiced) In Sri Lanka society where people with disabilities on the whole are regarded as less capable. so I wish you good luck..!
Don`t worry WagonR is Japanese
Please help!! Nissan Sunny B310 fine tuning the carb
bpcd replied to mr.ahamed's question in Mechanical problems
It`s looks like you have a rich mixture at idler, turn your idler/air screw clock wise to reduce fuel intakes at idler speed. hope this will help you.- 3 replies
- carb
- carburettor
- (and 5 more)
Will Taxes Get Changed With Upcoming Budget
bpcd replied to Aruna2002's question in Car Buying Information
If you like something just go and buy it, nothing to worry about budjet. it might get worse. -
Sylvi you keep this forum active
every thing clean and lubricate properly, inside the blead nut housing had lot of rust. normaly mechanics don't clean this they only clean the piston bore and apply grease to the caliper pin.
I gave another try by removing a tini layer from the pads (about half mm) don`t feel any change right side is sticky than left.
I would sugest to go for Japanes Alto
- 21 replies
- Unregistered
- car
(and 2 more)
Ok friends I will try to find a original pad set and see what will ahppen. I wiil post here the result. Sylvi looks a practical man might be useful his advice too.
their are enough room even for thicker pad. no record about original thicknesses. until you press the paddel wheels turns freely.
Thank you harshan,I agree with you shouldn't remove it. pads wer not localy repaired, thikness may slidly differ piston is travelling smoothlyI cleaned it properly.I checked the number 3 pads are hanging and moving smoothly. BPC
Thank you Sylvi, this is a vx model. not yet check the tandem master cylinder i haven`t seen such a thing as I remember. I blowed from one side to other to check for block of hoses and return, is it a good method to check it. I must say i am not an experience auto tech but I do miner things. BPC
Thank you Sylvi, I forget to mention this is a petrol engine. BPC
What Are The Things That I Have To Change On My Newly Bought Used Car?
bpcd replied to MiraOwner's question in Mechanical problems
Lot of advice for used car buyers. good question! -
Hi Friends I have a Nissan Vanette van YOM is 1990 recently I replace the disk pads since then front wheels are dragging disks are getting worm after 2 km I cleaned the callipers several time, check the hose all fine. is it bad pad or any other problem ex.master cylinder etc advice are appriciated. need more power to pull than before BPC
good work! thank you for your time.
Hi Sylvi, appreciate your post regarding construction method I am thinking to start much simpler as possible from the beginning, of cause we can improve and expand later on with the progress of the business.
