Everything posted by Uditha88
Help To Buy
Hi Ripper, Went to agent today. (AM*). They don't have. Thanks for the clue. Others, please send some other places/ options.
Help To Buy
Hi Friends, Please tell me a place that I can buy "Oxygen Sensor" for Nissan car. (1996) Either new or used one. Sensor plug into "exhaust manifold" which is used by "catalytic Converter" Thanks.
Car For 2.5m
Go for 110 with Crystal Lights...
Things To Do When Buying A New Car
Don't go for this. Too much n useless. Try used Toyota 121 for 2.8M to 3.1M instead. OR other Options, Vios 2005 Mazda Axela Triptonic
Car For 2.5m
Corolla 110 is a good car & may be maximum of 1.8 M. My advice is if u can go for 2.5 M, without bother about the "Diesel" go for a new car with new improved Technology despite whether it's Patrol or Diesel. Isn't it ???
Good Saying though. 1. Change ATF, Engine Oil 2. Change Air Filter if n only if it's dirty 3. Go for Test drive with a experience, trusted guy and get to know the condition of car, any further maintenance, replacement needed. Wish U nice & safe Journey with Ur New Car ...
Car For 2.5m
1. Vios => 2003 2. Mazda 3 => 2001-2003 3. Toyota 121 => 2000/1 4. Toyota IST 2004/5 5. Toyota Vitz 2005-2007 6. Toyota Passo No idea of availability of "Diesel" models.
Nissan Fuel Economy Survey
Thnx for advice... But I would like if u friends help to keep this thread only to publish ur Nissan cars fuel efficiency according to format I gave. Please open threads as much as possible to state fuel saving tips n all... Thanks All..
Catalytic Converter
Hi Hiran, Just go through the following thread initiated by me for ur information. Check whether it has any clue for ur problem. http://forum.autolanka.com/index.php?s...mp;#entry128252
Catalytic Converter
Arh. U got it removed? Hmm.. I heard that some do so. Btw. Does this increased ur fuel economy or any significant change in fuel econ? Can this be safely removed if not in good condition? Doesn't this affect to emission test to fail?
Catalytic Converter
Exactly true.. I true read so.. But what I understood was 1 is located in "Exhaust manifold" and other 1 is near catalytic converter. Both sends commands to ECU(Computer of the Car) to help it decided how much air to be issued according to current situation..
Catalytic Converter
Hat off for ur descriptive advice n appreciate ur technical explanation... So I would hve to get two sensors and catalytic converter itself checked right?
Catalytic Converter
Any place to get this done? (Other than agent) The garage should be a place where all these instrument are available right? Any good place to get this done?
Catalytic Converter
Thanks all for replies, hi harshan, This is Nissan Presea CTII 1996 It has catalytic converter (Don't know it's because this is a Japan domestic car) It indicates this warning light. Car bit bad in fuel economy. Is there any relationship among them? Or Presea by default bad in fuel?? Any specific reason or fix please? BTW. Cat Converter is also not 100% good. As it opens to water n mud, bit week (Thing normally happened to silencer barral ) Thanks...
Catalytic Converter
Hi all, What's the reason to "Catalytic Converter" warning light appears in dashboard? What's the fix has to be done? Thanks
Triptronic Vs. Auto
1. Manumatic most often refers to an automatic transmission, with some elements of manual transmission control 2. Different car manufacturers have been using a variety of labels for their manumatic transmissions, such as 'tiptronic', 'Geartronic', 'Touchshift', 'Sporttronic', and others. 3. Like a manumatic, many modern semi-automatic(another type) transmissions can operate in the same manner as a conventional type of automatic transmission 4. Despite superficial similarity, manumatics differ significantly in internal operation and driver's "feel" from semi-automatic transmissions 5. A manumatic, like a standard automatic transmission, uses a torque converter instead of clutch to manage the link between the engine and transmission 6. Tiptronic is a registered trademark, owned by German sports car maker Porsche, who license it for use by other manufacturers, such as Land Rover and the Volkswagen Group (Audi, SEAT, Škoda and Volkswagen). How 2 Use In ordinary driving, the Tiptronic transmission functions like an automatic transmission and can shift gears without driver control. When the driver activates the Tiptronic system, the transmission ceases to shift automatically and relies on the driver to change gears. Usually the driver controls the gears with paddle-shifters, which are small levers located on the steering wheel. One paddle shifts gear up to a higher gear, while the other shifts to a lower gear.
What Is The Best Coolant For You ?
No issue in the sense?? Hmm.. My opinion is very hard to find the quality of a coolant. U think that u don't have any issue but U don't know it really does the job. U know even water will do the job inside radiator n cooling system but we use coolant(Anti freeze) to change the nature of the coolant & make it more heat absorbed and not getting freeze in cool condition(Cool countries. Not in SL). corrosion protection is another advantage we expect from coolant(This is what we really want in country like SL. Not anti-freezing). But very hard to measure 1st property I mentioned above and so that always better to buy famous brands though expensive. Else u may buy water with some coloring. Pls suggest good brands for benefit of all.
Cvt, Automatic Or Manual Transmission?
Silly Misunderstanding... Cannot expect from a one who ever driven a vehicle.. sorry...
Well Said... Little suggestion: "wear of break pads" Put automatic to 2nd or 1st or Low when going down a deep slop....
Need A Big Help
1. Asanka Ganepola - MACVUD car Styling - http://macvudcarstyling.com/ 2. Dumi##a - BodyKit.lk - http://www.bodykit.lk/
Pls Help
Hi Shan, No that thread totally for effect of bad "Silencer Barrel". This focuses on Where 2 buy n How to select. Let me remove question number "0" or all friends, just ignore question no "0" many Thanks n kindly seek ur help.
Pls Help
Friends, If car's "Muffler"(Silencer barrel) is damaged, 1. Is it ok to re-install local made one or used original one? 2. Where can we buy this from? 3. How to select a one? Please be kind enough to give ur help!
Looking For A Car
Good suggestion. Try for Year 2 000 Presea Refina Manual one..
Toyota Vios
We even cannot see. Means problem is not vth ur PC. Where u found this link? May be the vehicle already sold n autolanka has removed it from the site...
Car Modification - Toyota
Try "bodyk**.lk" of Dumi##a or "macvud" of Asanka(Malabe)
