jdnet
Everything posted by jdnet
  1. Just out of curiosity...wouldn't the reverse gear not working be a sign of a blow tranny rather than just a solenoid?
  2. BTW while we are on this topic anyone know where I can by an air compressor at a decent price? Just need something large enough to run my pneumatic tools such as the ratchet and hammer. My shoulder which I injured during an accident has been acting up lately making it harnder for me to be spinning wrenches.
  3. Well I'm not looking for a torque wrench just looking to get it recalibarated. Already have 3 but the one I dropped was my favourite snap on digital one and I would hate to toss it aside. BTW if you are looking to buy em I do vaguely remember that the jubilee post place had em. Have to visit them for some bolts so I will try to get the pricve for you. What torque range are you looking for? Oh and thanks for letting me know the location.
  4. What do you mean the needle isnt moving? after you removed it or was it like that before?
  5. Well it would suck I I can't fix it since this wrench cost me quite a bit. BTW where's ac paul? never heard of them. If worst comes to worse I guess I have two options..... Ship it wout for repair or try to do it myself (although i'm bad at math and can see a lot of things going wrong with me trying to make calculations in order to get the right specs). Anyway let me know where those guys are located and I'll have a look there.
  6. Well I installed the direct fit LEDs on my cluster and have problems lighting up the gauge needles. They cost something like 350 each. They do light up the fact and the odometer really well but the only problem is the needles. Thinking of a mod to get the light to pass into the needles, will let you know what I come up with. Oh btw You could also put in the good lEDs and take a cheap ones to light up just the gauge needles. Basically you would be using a really small wire to tap into the socket holding the primary LED then move a secondary LED right onto the plastic thats used to deliver the light into the needles. This sounds more complicated than it is. HAven't had a chance to try it out yet as I got a few issues of greater priority to sort out before I move back into working on the instrument cluster.
  7. Hey guys, Quick question. Does anyone know of a place here that I can get my torque wrench recalibrated? I dropped my digital torque wrench and managed to knock it out-of-calibaration.
  8. jdnet replied to kasck's topic in General Automotive
    There's no need for multiple threads on the same question. I'm sure everyone can see your first thread. Do a search, there's a couple of threads on the car.
  9. hahhaha wtf dude? a used condom does not lool like that. Well......Unless you used a big one and blew it up....hmmm.
  10. jdnet posted a topic in OTHERS
    Hey guys, So after looking at tghings for a while I decided to go ahead and shop for a classic so that I can have a restore project that will keep me busy for an year or too. I'm new to the whole restore side of things so please do excvuse me if I have any stupid questions. Anyway I'm looking at a complete strip down and with a tranny and engine rebuild and will be attempting to restore it to stock or near stock specs. I will keep updating this thread as I figure things out and will be looking for advice from you. Anyway, please try to keep this thread on topic and no sylvi B.S. I have heard there are a few guys with the know-how such as Milindu I would appreciate your views. So here are my first few questions. 1. Finding a car. Here's where I need your help to begin with. Basically I'm looking at a classic thagt would be easy to find parts for either locally or internationally. Right now I'm thinking about a triumph convertabile (not sure of what the model is) but I am open to any other suggestions. The car needs to look good though....I'm not going to drive around in a restored VW bug. 2. Should I have the frame sand blasted? Is there ta place that does sand blasting in Sri Lanka?
  11. Heated seats. Atleast thats what the seat with the arrows symbol means....
  12. 1. The belta probably had a lot more KMs and the odometer was fixed. 5000KM is extremely low mileage for a car. 2. Just because the alightment went off twice doesn't make the Thai version better than the JDM. I am almost willing to bet it was the drivers fault. Not sure he/she needed a tire replacement but if it was due to a puncture or got torn up while hitting the curb then it's the drivers fault and not the manufacturer. 3. Some components in the JDM are of higher quality than the thai built yaris.
  13. It's simply a matter of unplugging the connectors. Once you pull the trim out you just have to unplug the connectors of all the accessories on the panel. After that you would have to remove the screws holding the speedometer and then unplud the cable/cables going into the speedometer. It's a pretty simple process and I wouldn't worry about mixing up connectors because they vary in sizes so can't really be mixed up.
  14. BTW Replace the light bulbs in the meter with new ones. Over time they tend to lose their brightness. You can even install leds, but it may cause problems in lighting up the meter depending on how your instrument cluster is setup. Not sure of your car but usually the job calls for the removal of the trim around the instrument cluster (It may come out with the a/c vents and the radio surroundings.). You May have two screws above the cluster holding the trim down. Usually you would have to remove those screws and then using a screw driver carefully pry the entire trim off. It would be nice if you clean the cover of the instrument cluster. I have used both rubbing compound and polish and they both do the job fine. If you are cleaning the guage faces take care not to mess around with the needles. You would not want to know then out of calibaration. Once again it would be a lot easier knowing the make, model and year of your car.
  15. it would help you you let us know the make/model/year of your car.
  16. I'm going to have to agree with VVTI. You may want to check your plugs and make sure you have the correct ones. A plug with the wrong heat range would cause the problems you described. On my tribute at the moment I have the wrong plugs and can really smell the gas at start up.
  17. Bwahahahahahahahhahaha Touche Sir, Touche.
  18. Huh, first i'm hearing about this. Do you suppose it's from the landfill in the rajagiriya area?
  19. I haven't heard of an major model specific problems with it. Either way if you can pay a mechanic at a garage to have a look at it before puchasing that would be great but if not just check the major thinks such as coolant leaks and engine oil color. Did the car shift smoothly when you drove it? how about any noise at idle? BTW after you purchase it take it into a garage and have all the maintanence and oil change done and check the important parts such as the brakes. Also if you can and you don't trust the seller on when he changed the timing belt, just get it done for peace of mind. BTW as with all used cars expect to spend a little on maitenance. Usually owners tend to not maintain their vehicles right before selling em and doing it right after getting a car will help you drive for a while before needing any work done. BTW what color is the car? I saw a black one with chrome chrome wheels that looked really cool. Be sure to post some pics on this thread.
  20. Sorry I missed this question. You want to know the whole process of shampooing the seats right?
  21. For those of you who requested a before and after pic here it is. Sorry for posting it so late. BTW the part is a door sill I pulled out to check some wiring today.
  22. jdnet replied to Supra_Natural's topic in The Lounge
    forgot to mention this. Thats how it's pronounced in Germany. Nolt the rest of the world though.
  23. Well I did some research on CNG a little while ago. Until now I basically knew nothing about it except for those old volvo CNG powered cars. What I have found is that CNG IS economically viable and can be mixed with gasses produced in landfills and sewage treatment plants, but, the problem mainly lies in the fact the CNG cannot be compressed like propane and the engergy output is low. So basically you would have a CNG powered car with one or two relatively big tanks to carry around in the trunk, thus rendering the trunk space useless.Likw propane, CNG can be used with petrol as a back up while feeding the CNG through the air intake so I guess running out of fuel would not be a problem. However delivery of the fuel could be a problem as the per unit delivery costs of CNG is quite high. Now I think a better use for natural gas in this country would be to lay pipes and send it directly to homes like other countries, thus reducing the need for propane. From what i've been told the system was in place during the colomial days and we somehow lost it to propane. I would be suprised if we did not have large enough natural gas deposits somewhere in the country that would be able to supply the entire colombo for years to come. If we were to use natural gas instead of propane we would be able to put a serious dent in the money lost due to the import of gas. In all what I guess i'm trying to say is that for a nation like ours, a good start is using methane for our homes before cars.
  24. Nice pics but can you please stop? we can always google the pics and it's cluttering the thread, whereby making it difficult for me to troll sifaan.
