Everything posted by Sifaan
Led Bulbs For Vehicles
Just got it checked and there is ~8V across the terminals; which is not enough to light up the tungsten bulb but enough for LED to light weakly. The garage dude said this voltage shouldn't be there and he will check it out (unfortunately this car has had some goda wedakam on the main wiring harness)
Pamper Your Tires With N And Pump Xtra Premium
Hi Harshan, Are you still using Nitrogen? How is your long term evaluation? (from what I was reading online, the advantage of N is not that it leaks less, but will contain little or no water vapour)
Car For Wedding Hire
actually I (a "allion for wedding car" critic) am also one of the people who couldn't afford to spend much for the wedding. the idea of renting a car didn't even come up. we actually used an allion, borrowed from a friend. if that hadn't worked out we would have used boss's B15, or BIL's N16, or something... if we were going to PAY for a car, no way it would've been a Jap unless maybe Camry/Teana style of thing...
Hand Carry Services For Spare Parts
must be a little something in it for the customs as well slighly deviating, but I have twice seen people buying boxes of cigarettes at Colombo departure duty free (that's the box that holds 20 cartons - or maybe it was even bigger - so that's at least 4000 cigarettes per box), each person buying 6 boxes and stuffing it into bags; they fly to chennai, fly back, take the stuff thru customs and sell it in black market. at the time B&H was selling for Rs. 200/pack, the smuggled stuff was available for Rs. 160/pack. the point I'm trying to make is when there are rackets like this for large scale imports of heavily taxed items like cigarettes, no big deal for someone to get a racket going for car parts! To OP, I think I saw in forums somewhere a figure of Rs. 1200/kg mentioned. Anyway, in my experience euro car parts are cheaper in UK (dealer or ebay) than Singapore (water pump from a dealer in UK was ~9000 and was quoted ~16000 in Singapore) although might be harder to get parts down from UK. But if you are willing to pay tax (~40% of declared value, if you are able to get an undervalued invoice the effective tax would be less) then EMS may be quite a cost effective option (I got a PS pump from Isreal, cost 35$ for EMS and was in Sri Lanka in <4 working days). If you would get a lot of stuff at once, you could consider doing a trip yourself to Singapore (or Malaysia if they have the parts) on AirAsia and bringing it yourself - and you get a free holiday as well
Allions are indeed becoming so common (at least in and around Colombo) that it's not worth to rent at a premium price. depends on how rich OP is; my neighbour (rich bugger) was using a chrysler 300c for his daily running.
thanks for the inputs... it's going to be a bit of a bugger to add a resistor cos the bulb has the same fitting as the original, so if I'm adding a resistor might have to do it in the wiring I guess a voltmeter should be able to confirm if there is a leak? if the leakage is the cause, is it intentional or does it imply some problem (e.g. in wiring, ECU etc)? if it only came on at ignition I wouldn't care... if it even stayed on when the engine was on I probably could still live with it... but these are on (dimly) all the time :S
could this result in the bulb lighting up even when everything should be off?
Diy External Tire Pressure And Temperature Monitoring System
Not sure where this 500$ number came from... but anyway, do you mean to say that you don't use the TPMS to help maintain the recommended pressure? I just now measured cold pressure and found the readings vary from 31.5 to 34 - 34 is what is recommended and 31.5 is 7% underinflation which I can't detect visually or from handling. 7% is maybe no big deal but I doubt if I could detect at all unless it was about 15% down. (and air was filled to 34 last night, but from a place that had an analog gauge rather than a digital controller; so either 2 of my tyres are losing air quite fast or the pumping wasn't very accurate to begin with)
Getting To Know About Bmw
I think you mean the Insurance bands (which are defined by model) For Road tax, see http://www.whatprice.co.uk/car/car-tax.html and http://www.guardian.co.uk/money/2010/apr/1...arbon-emissions
I don't know if the higher taxes are really due to diesel subsidy, because there was a time when there was the annual diesel tax payable with renewal of revenue license that was supposed offset the diesel subsidy. now subsidy levels on diesels are much less (maybe non-existant) and that's why the annual tax was discontinued btw if taxes are for emissions it's better to tax on actual emissions rather than engine capacity. e.g. in UK the annual tax is based on emissions (Co2 g/km) and since emission test is already compulsory part of renewing revenue license such a system could come in place here as well
K11 Auto March Owners
we had a k11 auto (2001, cupholder model). didn't have a sport mode, but you got similar results by turning off overdrive (e.g. going uphill and overtaking was smoother) how do you turn on/off sports mode and how is it indicated (e.g. light on instrument cluster?)
Have an interesting problem with LED bulbs, hope someone can give some advice... I recently got down some LED bulbs, a pair of P21W equivalent LED bulbs (24 LEDs per bulb) to use as stop lights - these are meant to be used as direct replacements I first installed just one, to see how the brightness/color compared to the original, and was impressed then as soon as I removed the other original, the first LED bulb switched on (weakly). Even with ignition off and car locked, it stays on. Of course it only goes to full brightness if car is in reverse. When I inserted the 2nd LED, that also lit up weakly. Like before, no way to switch it off and only goes to full brightness in reverse Since leaving these on might drain the battery I put the original bulbs back in. Any suggestions on how to get the LED bulbs working?
hmmm.. i just tried to look as humble as possible and got a lower valuation (2000) than the actual (3500 for the item, 4000 for EMS) when I got down a pump. So paid ~40% (effective rates for car parts) on Rs. 2000 instead of on Rs. 7500. no offer or solicitation of a bribe in your case taxes seem to have been ~12.5%, so not too bad. btw one of the concerns I had about buying such a system was "what if some bugger nicked the sensors?". I notice your unit has some anti-theft feature... how does that work? is it a pain to take off when you have to pump air?
More like I've gone your way, considering that it was from your post that I found out that such things exist
I have seen "common" cars like sunny's and corolla's being used for weddings, but kind of assumed that they were borrowed from a friend/relative and not hired. In Colombo if someone wanted this kind of car it would be cheaper to get from a cab company than premium rates at a wedding hire service, but maybe it's a different situation in the area where you live (e.g. not many cab companies with decent cars)
I was thinking about something like this and decided I didn't want to spend so much for a real-time pressure read out (plus didn't want to clutter up the interior) so I got a pressure guage (http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160465216351) for 5 pounds + shipping. Just received it today, and will measure cold pressure tmrw morning to see (warm reading now was 31.5 to 32.5 so I'm low by a few PSI already)
Can We Trust The Auction Grades Advertised!
of course not; just that the meter reading doesn't mean much even if it was genuine (in extreme case a car with 50k might even be in better condition than the same model with 25k if the former was maintained regularly and driven carefully and the latter was maintained poorly and driven on redline rpms by a maniac), and since it's possible that it is not genuine you should trust it even less. and as for the "heard" post, my source was someone in the buying/selling business (I don't even know him personally) so I can't write as if it definitely does happen.
Honda Civic Es8
well, you don't know that it was sold for that price... maybe someone came and said "I have 2.6m and no time to waste; take it or leave it - decide now" if it was substantially better than any other offers he had got, he might have gone for it. (I have met couple of buyers like that, but in our case it was not much better than other offers and we could afford to wait...)
24v To 12v Convertion
as the vacuum cleaner originally ran on batteries (regular or alkaline) then rechargeable (NiMH) sould be able to handle that load. But unless you are using the vacuum cleaner very often you would be better off with regular/alkaline disposable batteries. also NiMH don't hold charge for very long, so you may find yourself recharging before every use. Sanyo eneloops can hold charge for a long time, but they are even more expensive and I haven't seen them for sale here.
Thanks Wijesinghe... so, one way or another, the only way you can really trust the odometer reading is if it's a brand new car
Transmission Help
Than that would be Sports mode; the horizontal shift is so you can switch to S (e.g. if you want to do some fancy overtaking) without looking at the gearbox (if D and S were vertical changes like the others, you might accidentally put the car into the wrong mode - maybe N - if you tried to change when you were in a hurry) I have a "S" button behind the gear lever and it's a pain to try to turn it on without looking at it... and if you are feeling the need for sports mode you are probably not in a situation to take your eyes off the road
Myths About Oil Changes Debunked?
Interesting article... I was actually reading up some old posts on AL about oil changes these days because I was wondering how badly Sri Lankan conditions affect oil change intervals... the car's manual has servicing every 30,000km (of course it expects you would top up the oil yourself if the level was going down) but the local agent suggests to replace the oil every 7500 km. is the environment in Sri Lanka so bad that the lifetime of oil is 75% less than in Europe? (btw the car manual explains how to choose oil according to the climate; but doesn't say anything about different change intervals due to conditions like dust and humidity... so I presume the temperature here affects the choice of oil but not the lifetime)
Transmission Help
Drive vs. Drive Safely? Drive Slowly? Drive Sportily? apart from P,N,R, B do you have D and D-S? Or D and S? or just D-S?
The guys with something to hide will definitely not disclose the auction certificates (will probably put some cock and bull story about having to pay extra to get it, or that it is not available for this particular car/auction, etc.) but I thought if they did show the certificate then you could trust it?? apart from the pamankada business I've heard that it's done before the car even leaves the port in Colombo (dunno if it's true). in any case no point trusting the meter in a car... even if it was displaying genuine mileage of 30k, the wear and tear depends on what kind of surface it was driven on (suspension), how it was driven (engine/transmission), how it was maintained(just about everything), etc, etc.
Most Suitable Vehicle (honda Civic)
+1 writing "kmpl" around here is as good as waving a red flag
