Dinukap4
    2
Everything posted by Dinukap4
  1. leave your kotthu beat at home and go
  2. So you are gonna buy a Hybrid ? Please don't
  3. wow
  4. RC's anyone ?
  5. Dinukap4
    Project E34
    Any updates on this ?
  6. Aren't AMG's double Digits ? like C63 etc. I've seen a couple of 3 Digit Mers that has got the AMG badge.. Correct me if i'm wrong.
  7. Oh god no its in dehiwala the owner used to be in my grade back then doesn't surprise me though.
  8. Thanks jdnet will look into that, but can a oil pressure switch cause a electrical power drop like this ? I was thinking a loose Ground well lets see got to look into this tomorrow
  9. Spending 15K for a set of Brake Pads is ridiculous especially when its a regular Saloon car, I would Suggest going for the aftermarket Pads there's not much difference maybe they will wear out a month or 2 early thats all . Lets see what the other have to say to.
  10. Why so many Petrol bemers out for sale
    1. maheshw
      maheshw
      so many ??? only 1-2 ??
  11. Well our good old 1994 Hiace is having sort of a odd issue.. Whenever the Head lamps/Signal lights/ or the switch the Air con to the high flow range the Oil level low warning indicator on the cluster lights up for no apparent reason because the oil level is at the dot perfect this only happens when the following things are switched on other than that there is no issue p.s- another thing is some times when the radio is on and the signal light or the head lamp is turned on the radio switches off sort of a power drop occurs ?
  12. Try JJ Lanka
  13. Yeah I guess so too
  14. Thank you
  15. Any one have any idea where this is ?
  16. Maybe your battery is crapping out.. Ohh no! Now spend all that you saved on Gas and put on a new battery.
  17. Octanehead, while you are studding at Malaysia are you doing a part time job ? As in the same field ?
  18. Dinukap4
    Ruined Bmw E28
    In Simple Sinhalese, Nodakin.
  19. Just listen to that !
