Express-Way Updates
Damn... looks like a Hyundai H100. Wonder what caused the fire.
Autolanka Funniest Moments
Traffic lights at Malabe gone haywire (captured last Saturday):
Air Is Going Out Quickly From A Front Tire
There was a thread exactly like this created a few days back. You might want to run a search for the word "wind" instead of "air". Edit: Found it: http://forum.autolanka.com/topic/13930-how-to-find-and-fix-leaks-in-your-tubeless-tires/
Mitsubishi A72 1400Sl 5Fwd
Any update on the tail lights? If I were you, I'd lose a lot of sleep on that.
My Car Makes A Clicking Noise But Won't Start (Starter Motor Not Working)
The clicking is the sound of the solenoid switch which is within the starter motor. It feeds the armature of the starter motor onto the flywheel to turn the engine. The solenoid does not require as much power as the starter motor, so I’m guessing that your battery has a little bit of power to activate the solenoid, but not sufficient enough to crank the engine. First thing to do is to get your battery and terminals checked from a battery shop or auto electrical workshop. If the battery is faulty, you might have to replace it. They should ideally check if the battery is being properly charged by the car as well. Hope this helps, Good luck!
Tesla Motors - Cars That Will Change The World
I'm sure Madz and the team will be happy seing autolanka.com on that screen.
Old Cars In Highway
For the 4G33 engine which is 1439cc, it's 92hp @ 6300rpm as I remember.
Old Cars In Highway
Drove my Lancer A72 on the expressway from Kottawa to Dodangoda and back a couple of times. Stuck to the speed limit most of the time but put my foot down a just once to see how far I can push it and it touched 150 km/h. The ride was fairly OK because the drive was after overhauling the engine and most steering and suspension components were new. This car has a 4 speed gearbox and the engine revs high when it catches speed.
- Triumph T R Restore Project
Car Catalogues & Brochures (Warning: Graphics heavy)
Toyota Altezza Catalog Continued...
Toyota Altezza Catalog Continued... Continued...
Toyota Altezza Catalog Direct Download Link (PDF): http://www.4shared.c...a-3_200208.html [Thanks for the PDF c1nder] Continued to next post (exceeded max number of images per post)...
Banning Of Mp3 Players At The Workplace - Your Experience
Ah the "Global Team"... Worked there for over 3 years and my observation was that it became strict by the day. And as someone has already pointed out, it has to do with Information Security. The aforementioned company deals with a lot of global clients who need their IT service provider(s) to adhere to strict guidelines when it comes to dealing with their data and business processes. So they are at CMMI level 3 and adhere to most Intellectual Property and Information Security standards. As a result, they are able to label themselves as a company with high standards, thus attracting a lot of clients. I'm not aware of other local IT companies which are at CMMI level 3 or above apart from this one, so it's unlikely that most restrictions imposed by this company are followed by others as well. It is the employees who suffer great inconvenience due to these high standards and I can definitely say that this particular restriction is just one of them. There are so many rules and regulations implemented internally in order to adhere to the security standards. We can't really say whether it's a growing trend or not, if a certain company decides to adhere to some sort of information security standard, they will be compelled to implement these restrictions.
4Wd Rally Accident
I was wondering the same thing. The Dinamina news article says that it was the chassis; had a good look at the photo, and you're right - it's the bumper.
4Wd Rally Accident
I guess you’re right. Just read the Dinamina article; Who on earth would have thought that the chassis of the truck would come off? To the victims it might have felt safe at the time. It's just unfortunate.
Vehicle Badge Riveting
The desperate kudda boys are very smart and they use a sharp tool like a broken hacksaw blade to remove the badges because they don't care about the paint. Some idiot while trying to remove my "LANCER" badge had ended up breaking it after the "L" and left me a badge saying "ANCER" + a badly scratched trunk lid for a few months. So if you want to have the badges up, I guess the only option would be to rivet them.
4Wd Rally Accident
Oh man, that's just tragic! So there were two victims (video shows two)? Excitement aside, these kids do need to be more careful. Anyway, may the deceased rest in peace.
I was under the impression that it was L light because of your post quoted above. If I were you, I'd do a clean sweep of Panchikawatta and every place I know of to get hold of a tail light set before doing any of the other modifications such as the dual carb and so on. If you fail to find a set of "Flat" tali lights, then it would be better to switch to either "L", "Tube" or the other type for which our Sri Lankans havent formed a local name. Oh and yes... drag the friend who rear-ended your car as well.
Break Not Work In Hill
Was typing an answer when Watchman's reply popped up, kind of what I wanted to say as well. amilaart, If you ever wondered how you're able to stop such a huge pile of metal just by the use of your toe on the brake pedal, you'll begin to realize that there is an underlying mechanism to assist you do the job easily. That's what Watchman's link is all about. This underlying system (servo brakes) works only when the engine is running. Therefore there is a significant difference in the pressure that needs to be applied with and without the engine running. This is normal. Since you're new to driving, I suggest you use the hand brake if your car starts to roll downhill. The hand brake works regardless of whether the engine is running or not. It comes from the intake manifold. I modified the brake system with a servo in my old Lancer and the vacuum line was fixed to the intake manifold. There was even a "tap" on the manifold to connect the line (I assume that the same manifold was used by Mitsubishi on models with servo). I think the system is different on diesels, they have a vacuum pump, not much experience there since I've never owned a diesel. I'm not sure why the brakes stopped working when the alternator got jammed though. Hope this helps.
Good heavens! Those tail lights have got to go... So this is "L light" right? I captured the photo below from the Panchikawatta scrap yard in 2010 when I was looking for a wire harness for my A72. There are many scrapped A72 cars out there and you can find a lot of used parts which are removed from them rather than do what you've done to your car. I bought my front disks, wire harness, steering box, servo, tailgate spring, front grill support brackets and many more parts from this place. If you're lucky, you will find a good set of tail lights. If you don't know the area to look for, let me know. I will PM you the details.
1979 Lancer A72 Restoration
That's a nice car. First gen Lancers with a beige interior is pretty hard to find and your interior looks like it's in great shape.
- 97 replies
- lancer
- a72v
- a72
- restoration
Great car mate! The engine looks like it's in great shape! Did it go through a complete overhaul? Love the set of rims, I was looking for a set like that as well, but after the bodywork and paint, I couldn't afford a set this good looking. The three spoke steering in the SL looks a lot sporty and I was looking for one of these for ages but couldn't find one. The station wagon has a two spoke steering with 2 horn buttons on either side of the spoke instead of one big horn button in the center. The air vent at the center doesn't look like it's the factory fitted one, did you add in the AC later or was it factory fitted? And any particular reason for taking off the front bumper? I see that you've done a bit of a change there. Great to see your determination on the carburetor conversion. As for me, I wanted everything to be according to original specs, so I did not tread into the area of fabricating parts for the engine or anything of that sort apart from the modified air intake, and chrome water lines. Hope you find the necessary parts. Good luck! More photos please!
Restoration From Hell!
Two thumbs up for deciding to bring it back to life. Please capture as much photos as possible and share with us. Good luck!
I sure will. I assume you haven't had the chance of going through this thread (didn't see a post from you in the thread): For Old Lancer Lovers The A72 catalog I have is not among the ones shared on the above thread.
