Outdoor Car Covers- Is That Good?
There are several threads about car covers on the forum. Covering A Car-Good/bad? Car Cover There were several others as well. Hope this helps.
The Best Roads For Driving
Looks great! Thanks for sharing. For a second I thought that first photo was from some other country.
Hand Held Vacuum Cleaner For A Car
I have to agree. Underpowered plus the one that I used to have (Optima VC 300) couldn't even stay alive until I cleaned the entire car... not even after a full charge.
Best Wiper Blades For Summer & Winter In Sri Lanka
About the look, well I think that’s subjective. I think they look great. But you’re right; it depends on the car as well. There was a noticeable difference (maybe not ‘exceptional’). I found it to be much smoother than the traditional blades. Probably because the extra flexibility allows them to hold on to the windscrren much better. I think I recall my dad telling me about this. Will try it out. Thanks!
Same experience here. I have a set of Wurth aero blades and I thought it would be more durable. (after spending over 5000 bucks on wipers! ) But the good thing about aero blades are that they're "refillable" - you only have to change the rubber blade; and it's a DIY job.
Another Crash In Southern Highway
Says HERE though that the fire had erupted following an accident. http://www.youtube.com/watch?v=KCjY7jRCduM
- Best Battery In The Current Market.
And a sports steering as well. Damn, What a wreck! Glad everyone survived though.
What Should Care Of When Driving On Water/raining Days!
Moisture/Condensation buildup on windshields can be a real pain sometimes; especially if you’re driving a car without AC or if your car gets a little crowded. Unless of course you have heated windshields and stuff like that onboard. Turn on the defogger on the rear windshield if required. Most vehicles have a defogger as standard nowadays. Maintain a good temperature inside the car so that moisture doesn’t build up on the inside. If the front windshield still gets foggy, direct the airflow of the AC towards the windshield using the AC vent controls. (works faster than cleaning with a cloth)
- Headlights
Diy How To Change Disk Brake Pads And Rotors The Correct Way
Thanks for the tip Ripper. Will remember to do that next time I get stuck.
Abandoned Cars ?
The story behind the abandoned BMW 5 Series: Apparently the owner of this car is some big shot at a reputable insurance company in Sri Lanka and went there were some discrepancies with regards to their assets and so on, the owner had taken off the engine off the car and dumped it in this land which also belonged to the so called "insurance company". A recent photo I managed to capture. (This time I didnt even bother to erase the plates ) What I saw a few days ago... The security said that a truck came and took the car away and thats all they know. All I wish is that someone gets that car back on its wheels and not turn it into scrap metal.
Car Ac Not Cool Enough
I sent you a PM. Hope you get it sorted out. Good Luck!
- Motorque
Coolant
Interesting topic. I have some concerns though. The previous owner of my car had replaced the original plastic radiator with a copper tank + aluminum core radiator. (due to a crack in the original) I’m using tap water as well. I see a lot of rust forming up, sometimes making the water brownish and I think it's because the car sits at home during most of the week days. I did a couple of radiator flushes at home so far but it just keeps coming back. Would the situation have been different if the radiator was the original plastic one? Can this be a possible drawback of using tap water instead of coolant? Thanks!
- Quick Trivia 3
Revenue Licence @maligawatte
Damn... That kind of defeats the whole purpose of having a website! I guess you'll have to do it the old fashioned way then. Please go through THIS thread as well.
I was able to find Brake Cleaner ("Brake and Contact Cleaner" it says on the can) and I used it to clean the front brakes. Works pretty well! I replaced the front brake pads on my Lancer CS3 last weekend and it was a success, thanks to you. Had a little trouble pushing the piston back because I didnt have a c-clamp so I hooked up a nut and bolt (with a washer) to push it inside. Thanks again blkr6!
You can renew your revenue licence online. 1. Visit http://www.srilanka.lk 2. Create an account (free) 3. Login using the credentials you provided 4. Go to "e Revenue Licence" Everything from that point onwards should be self-explanatory. The payment should be done online. Once you finish the renewal process, obtain a printout of the temporary revenue licence copy and keep it in your vehicle. The original will be posted to the address of the registered owner within 14 days. Hope this helps. Good luck!
Previous Owner Deceased Before Transfer
Hi Guys, So happy to let you know that this went through!!! :-) You guys were right, the system was not smart enough to figure out that the previous owner is deceased! This was such a headache off my head. Luckily the transfer papers were signed before the previous owner's death. Thanks for the help and advice guys! Davy
Side Skirts & A Spoiler For Lancer
Thanks for the info machang! Will definitely have a look as I have to paint my Lancer within the next couple of months.
Mitsubishi Lancer Cs3 Clutch Not Working
Hey Gayans87, I have a CS3A and I did a clutch replacement a few months ago. I'm a bit confused here as you have said that the clutch pump is within the gear box. My clutch pump is located right next to the brake master pump and is directly connected to the clutch pedal (the pump which is on top as you have mentioned). The component that's inside the gearbox is the clutch release bearing (fork) which cost me about 18,500 LKR (agents) when I replaced it, and yes it's sealed and the entire unit has to be replaced. This is the only hydraulic powered "pump" sort of component within the gearbox that I am aware of. Clutch release bearing (what the mechanic is holding): Hope this helps. Good luck with the repair bro. Keep us posted on what's happening.
Thanks a lot blkr6, I was waiting for this! :-) Brake cleaner and Disk Brake Quiet - can I purchase them from an ordinary auto spare parts shop?
Abandoned Cars ?
Well this neighbourhood is enclosed and guarded by a security point; no outsider can enter without permission. So I guess if anyone steals parts out of it, it'll definitely have to be an inside job (or the security guys themselves)!
Abandoned Cars ?
The first time I saw this BMW like this I went.. "woah...!!!" I moved to a new home in Athurugiriya about an year ago and this car has been lying there since then in an empty block of land in the neighbourhood. I believe it has been there for over 2 years now. I don't know who the owner is or why the car is left abandoned. My thinking was that "some people are too stupid enough to realize that the BMW they left to rust is worth so much more to someone else" Sometimes the wild grass in the land grows so high up that the car is barely visible...
