Davy
Top Contributors
  1. Of course it can. The tag on the seat belt may not necessarily be as same as the YOM of the vehicle. The most reliable method to find out is VIN or chassis number.
  2. Agree with @Twin Turbo. It could be from the sensor o-ring or the cam cover gasket. That looks like the oil control solenoid for the VVT or the camshaft position sensor. The crankshaft position sensor should be further down the engine.
  3. I'm sorry I really don't understand the confusion here, isn't this the case with most vehicles? Take a van for example, you have short wheelbase, long wheelbase, delivery, passenger, panel, 4WD, rear wheel drive, and the list goes on. Cars have an even more complicated set of variants. You just need to know what you're searching for. Not all of them have specific names. As for pickups, there are no names for each of the variant's you've listed IMO. Names are highly region specific. Scotty might call it a Pickup truck, Someone in the UK will call it a pickup, Someone in Australia will call it a Ute (short for Utility). 4 door single cab? A "cab" basically refers to a row of seats. So you're not going to find a single cab with 4 doors. If you want a 4 door pickup, then you're looking for a double cab. So it's no surprise you ended up with no results. 1 row of seats and 2 regular front-hinged doors: Single Cab 2 rows of seats and 2 regular front-hinged doors + a smaller rear-hinged door: Extra Cab (Toyota Calls it Smart Cab) 2 rows of seats and 4 doors: Double Cab Depending on the make and model, each of these configurations may have short wheelbase, long wheelbase, long bed, short bed, 4WD or rear wheel drive. You just need to know which specific pickup you're looking for.
  4. This exact question has been discussed before. Threads merged. Read through this thread (page 5).
  5. I have purchased alloys from them several years ago. They used to be pretty good.
  6. Please search the forum. I have merged your thread with an existing one with answers to your question. Read through.
  7. In a hot and humid country like Sri Lanka, the AC should always be in recirculate mode. This helps the AC do a lot less work to keep the car cool. Fresh mode is meant to be used for colder environments. The only instance I can see where you'd want to use fresh air mode is when it's raining outside and if your windows start to fog up. If you've parked the car in the hot sun and are about to take off, rolling down the windows for a couple of minutes before letting the AC take over is the way to go IMO. This is much more effective than letting the AC cool the car down at full blast. Having said all this, in a climate control (automatic) AC, this happens automatically as the car detects the outside temperature and switches between fresh and recirculate. However, I've had to manually switch the mode to recirculate sometimes if there is dust in the air or a vehicle in front is emitting a lot of smoke.
  8. After a cold start, does the engine rev upto about 200 RPM and slowly come down to normal as the engine warms up? Also, when was your last fuel system clean up (tune) done?
  9. Agreed. Ricciardo has also decided to discontinue his contract with RedBull and switch to Renault. Just realised this thread hasn't been updated in a while. So many good races after Azerbaijan.
  10. Repairing wheels is safe if done properly. It's probably cheaper than going for a new set of alloys as well. But yeah, if I was OP, I'd make use of the chance to upgrade to a decent set of alloys. As for frame Damage, Car Checks does visual inspections. I remember Formula World in Seeduwa had computerised chassis straightening equipment, so maybe they're able to identify if the chassis has really sustained damage.
  11. Davy replied to lkshan's topic in General Automotive
    The cooling system is sealed except for the moments when the radiator cap opens up to let excess pressure (and coolant) out and into the expansion tank in a controlled manner. So if you are losing coolant fast, it's quite possible that there is a leak somewhere.
  12. You can't assume the thermostat valve is working just because coolant is flowing back to the expansion tank. 1. When the engine is cold, remove the radiator cap and check the coolant level of the radiator, if the expansion tank fills up with coolant, and the radiator has a low level of coolant, then it's possible that the radiator cap is faulty and releases pressure before it should (or there's a leak somewhere). 2. When the engine is cold, remove the radiator cap, switch the AC on and let the car reach operating temperature. When the temp gauge is at half mark (or normal operating level), rev the engine slowly and observe the coolant in the radiator. It should flow in one direction. If it doesn't either you have a faulty water pump or a faulty thermostat valve.
  13. Congratulations on your CS3. Suggest you get the timing belt, tensioner and oil seal from U n i t e d M o t o r s (they will give you the price over the phone if you ask. They will ask for the chassis number or licence plate of the car). The wheel bearings can be purchased from elsewhere Koyo, NTN and SKF are good brands.
  14. My point was to clean it during its lifetime and not clean and reuse it when replacement is due. Since its the cabin filter, it's not advisable to clean it using compressed air or dusting it. What I usually do is carefully take the filter out and use a vacuum cleaner to clean only the outside of the filter.
  15. That's a bit strange... Was your car involved in an accident? Anyway, if the wheels are bent as you say they are, you can easily find replacements or even get them straightened out. There are places that will straighten bent wheels. @trinity got a couple of buckled wheels straightened a couple of years ago and he should know the spot. If you search the forum, you should be able to find names of more places that straighten buckled wheels.
  16. There's no point in spending 11,000 for a cabin filter. Get a good aftermarket brand and clean it every now and then. Brands like VIC are pretty good. And no, using a cheap cabin filter will not destroy the AC. The whole purpose of the cabin filter is to filter out pollen and dust entering the AC system from outside in fresh air mode and to prevent occupants from inhaling them.
  17. Davy replied to MrCat's topic in BMW
    Sorry to hear about the Lancer. Yeah I was looking into a car that I could put some work into and restore and the cheapest ones I found were in the 50K - 60K range. I think @Crosswind had an E30 that he was restoring a few years back. What happened to the project Crosswind?
  18. Davy replied to MrCat's topic in BMW
    Sold the Lancer CH wagon? Huge fan of the E30 M3 right here by the way. Was looking for one (in VIC, Australia) in early 2016 or so, but gave up because I couldn't stretch my budget that far. I distinctly remember a red E30 in Sri Lanka with the plate 18 SRI 318 and that car was a regular sight on my commute to work. That was a 4 door though.
  19. Davy replied to Jbkumara's topic in General Automotive
    Why wasn't the problem addressed as soon as it initially appeared? You should have taken the vehicle back to Link Lanka and have them take a look at their installation. Anyway, yes, if you have a Check Engine light, get a diagnostic scan done. There should be plenty of places around Ja-Ela, Kandana, Seeduwa area that can do a scan. All you need to do is find what the error code is and proceed from there.
  20. Welcome to the forum! Could be due to low fuel pressure or leaking fuel pressure regulator (one that's large enough to cause a rough idle and stall, but small enough to not throw an error code). Start the car and while the engine is running, take the vacuum line off the fuel pressure regulator. Rev up the engine and if you see fuel coming out of the inlet, then the regulator is leaking. If not, get your fuel pressure tested. You can do this by connecting a pressure gauge to the fuel rail.
  21. 5W20 as per the owner's manual. https://techinfo.honda.com/rjanisis/pubs/om/ATK620/ATK62009OMA.pdf Page 253.
  22. Above? Of course you do because literally all vehicles except (some) mopeds fall into this category. If you mean below 49cc, then you still need a licence. http://www.colombopage.com/archive_11/Mar04_1299250483KA.php
  23. To clarify, cars with ABS don't have additional routine maintenance required. Most ABS components are not serviceable, so from an ongoing maintenance perspective, you won't be spending anything extra to maintain a car with ABS. Then we come to what happens if something in the ABS system fails. IMO it's pointless to be worried about having to replace something when it hasn't even happened yet. The Viva Elite doesn't have any known issues with the ABS system and as others have said, they're pretty reliable (has to be, as it's a safety critical system). So unless you're really unlucky, you wouldn't have to deal with ABS issues during the ownership period of the car. Finally, safety over cost ALWAYS. You might be able to buy an ABS module for about 15,000 - 20,000, but surely the lives of your loved ones is far more valuable than that.
  24. Could be due to a dead spot in the throttle position sensor that acts up when warm. You can get it tested quite easily with a multimeter. It's basically a variable resistor, so what you have to do is make sure that the change in resistance is proportional to the amount you've rotated the TPS. Any spikes in resistance or "dead spots" (i.e multimeter reads 0) means the TPS is faulty. If you don't have the equipment, reproduce the issue and take the car to a place that can do a diagnostic scan and observe the TPS sensor reading on the scanner. If it can be reproduced while in neutral and stationary, it's definitely not the clutch or transmission. Does the car idle smoothly?
