hatharasinghe
Everything posted by hatharasinghe
  1. dear ripper yes true the unit plus software in here too exp so even i can save 10K
  2. sorry fogot to mentioned HID consume only 35W so sure it has low current compare to normal so no current issues and i just installed for 6000 rs one year warrenty and so far good clear vision.
  3. Dear first do the proper alignment even the problem not solved , better to go HID 6000K sure clear improvement as i had this prob and started a topic sometime ago and end up with HID now so good.
  4. Dear Ripper checked at sala to install a map the cost is 13500 so its expensive than the unit.
  5. Dear Ripper yes it has WIN CE 6 it has sd slot but no sim so can i install software compatible to this
  6. Dear Ripper this unit doesnt have sim so sure live update not possible
  7. thanks Dragonfly send me the way to do it either to this post or my email [email protected]
  8. Dear All, i just bought a following unit from ebay. New 7" Car GPS Navigation Sat Nav MP3/4 so it has only european maps i want to install srilankan map how can i do it and the cheapest way pls update me.
  9. dear did you scan it from company, as i have one exp for my kia car i scanned some places and according to the error code did some works but the problem remained same then finally did it company and found out the exact reason and now its ok.
  10. I just checked Ajantha and Maruchi , but not available so checked the CAR PLAN so cost is 19000 brand new part is it available ebay ?
  11. Dear all, Pls let me know is there any place to buy secondhand console stroge compartment for KIA SPECTRA YOM 2001 or any good person doing fibre works pls update.
  12. Dear Don, MkX, Finally ,did the diagonastic test at Company, told me there is a problem at Air flow censer and ignition coil unit and sometime its doesnt take current correctly than i replaced both , Air flow censer 14500 and Ignition coil unit 9500 and now no problems one shot start and pickups and all really good so i think i replaced all untis from one end to other .Thanks for your helps.
  13. Dear MkX, no engine not start just the sound and vibration and even once started after several attemps even accelarated until some time at around 10second rpm not rising remaining same no engine race then it becoming normal
  14. Dear MkX , when i try to start the car its almost start but stops after 3 or 4 times then it start and normal so i think crank rotates and the mechanic telling for longtime parking there is a leak at somewhere either fuel pump or pressure regulator or else and all fuel return to fuel tank and thats why have to try several time until fuel come to engine but he couldnt fix the prob. Dear Don, sure i try first Vasantha then Indika so hope end of this month i do it normally i get use to pay the bill not finding parts so its easy.
  15. dear Don , i live at Kiribathgoda but until first of Nov i at Badulla - Office Work
  16. As i mentioned above (starting of this matter ) Starter mortor ,repaired and replaced pressure relief valve and total kit and the cost also given
  17. yes injectors cleaning done when this started and did all things i mentioned above
  18. Dear Don, Thanks for telling your garage sure i try and i know this place as one of my friend told me this place earlier and today morning i just check the diagnostic not at the company but there is a place at kelaniya but no error msg code appear they told nothing error it costs 1200 so it seems still this is a mechanical or elctrical matter not electronic so once i free go this place the thing is still no direct answer.
  19. Dear Don, The mechanic checked the crank and the thing is when the returning fuel line from filter to tank is closed then it starts one shot any time no any delay and then when its open again the same matter so mechanic told there may be small hole inside the fuel line and he replaced but the result same now he also have no idea and sorry i couldnt mention the early post he told there was a problem on starter motor ( he called mendis wheel and it was wornoff and magnett also not in good condition ) so replaced these parts also.now he has no exact answer and telling me to check ECU and to be reprogramme to do send to company but im not agree for this until sure the case is this.
  20. Dear All, i already started topic under Acceleration Delay and lot of discussion my again i just explain the matter i have KIA SPECTRA auto gear car YOM is 2001. My problem is the car is unable to start at firstime at morning after trying several time it start and even in day time park several hours and then again it cant start once.then the following done by mechanic 1.Engine tuneup 2.Replace Spark Plugs 3.checks coil and related things Same time replace Air Filter then he told the matter is at fuel pump so first he checked it showed me dirt in filter then clean it but the problem remain same.Then Mechanic told there is a leakeges of fuel pump line so once stop the car petrol come back to the tank as pressure regulator is not working.then , he showed me ,close the return line close to the pressure regulator then it start one shot even keep 24hr it start one shot then he did Replace followings 1.Fuel Pump cost 3620/= 2.Pressure regulator (Fuel Pump) Unfortunatly i had to buy from Company cost 7500/= 3.Filter Unit 3000/= (Not the filter comes with Fule pump) 4.Replace tubes 500/= So finally i thought its ok but today morning its the same so im now in fedup and no idea what to do next pls help me to recover this matter already wasted more money.
  21. Dear All, Yesterday mechanic checked the fuel pump and cleaned the filters actually its blocked but i kept the car at garage to check the start at morning but today morning also the same so what is to be check further this car already done ENGINE TUNEUP, REPLACE SPARK PLUGS, CLEAN INJECTORS , so im tired of this and mechanic told me there will be a electric problem so there may not enough current or correctly not passing current to spark plugs and its due to some loose connection so i told to check that also pls help me what else to be done.
  22. Dear all, I have KIA spectra auto car and has the same issue, did cleaning Injectors, tuneups but the same then oneday unable to start battery ok and Mechanic told magnet and the wheel ( they call MENDIS WHEEL)of the starter motor is wornofff so unable to connect CRANK and did the repair then its ok some period after one week it start again but after trying two or three times can start so still i couldnt sortout this matter. so im also waiting for good advice from our memebers thanks .
  23. As i posted on 2nd Aug , after doing manual oil changing ( Pls ref previous post) there is a remarkable improvement pickups and all so first find the suitable oil by checking the car manual or can find Net then do manual as once remove the bottom and do necessary cleaning then its good.
  24. Dear ,pls check the of the engine oil level sensor if the oil level below the crank shaft it stop the engine but if the sensor malfunction this may happen as similer case happened to me and replaced this sensor.
  25. Dear whats your car and is it EFI or Carb as you say if its considerable water drops from silencer there may other reasons so did you do any tuneup and is it hapenning everyday?
