Everything posted by hatharasinghe
How To Polish The Alloy Wheel As Diy
Dear all Could you tell how to polish alloy wheel to look shiney what are the best chemicals or any things can use for this as a DIY project pls update . Thanks.
Fuel Economizers
thanks all its clear how they cheat by time to time here can sell any items without approval or any standard test carriedout and issue certificates so same item comes in different names thanks again .
Fuel Injector Cleaning Fluid
now i almost emptying the tank and there is a remarkable performance of engine specially pickup and smooth so B*4*K additive is good but nextime sure i add pure acetone to check .
Fuel Economizers
Dear all anybody use this kind of gadgets or any hand on experiance pls update it will help all today Sunday observer ADS there is a add here i attach it for referances. thanks all.
thanks dear sylvi im sure HENDRICK at Bang shall st co 11 can buy .
could u tell what is the pure ACETONE dosage (the amount u add for full tank ) what u mean of pure acetone (Industrial Acetone purity is 98% so is this not suitable or should but Laboratory Acetone it nearly 100%)
Performance Of Maintenance Free Battery
thanks lot Don for ur explanation ok i'll go for normal one thanks.
thanks but whats the best even normal battery
Hi all what is the differences between normal battery and smae capacity maintenance free battery if the vehicle drives low km per day suppose just 6 to 7 km then will there be low charging of normal battery and such conditions how about the maintenance free battery . Or suppose vehicle start once a week then normal batter surely discharge but what is a maintenance free battery does it give the relavent AMP to start.and if maintenance free battery is in low charge can we recharge it or should throe away pls update me it will great help to select next battery. thanks all.
Engine Check Light
hi there is a good garage just pass palawatte towards thalawathugoda "priyantha motors" priyantha : 0773128577 just tell the matter he will do complete job u dont worry to findings parts but before go make an appointment or else may not take u his prices and all reasonable.(im not marketing him ..)
i added BG for my petrol tank but still couldnt drive more km only around 75 but feel improvement of pickups and more power but until empty the tank sure still it cleaning the sys if more improvements i'll post.
Good Garage At Mathale
thanks all
thanks friend i want to do some engine and electronic jobs i'll contact him.
- Pedestrian Crossing Laws!
thanks any luck to get phone number
Suggest A Car With Following
sure he should go ind or china indian TATA nano or at least small car or hybrid then it cost so very difficult to fulfill all requirments.
Dear All Pls let me know good garage at mathale area to do all running repairs if any phone numbers pls post. thanks
Proton Waja Fuel Economy
Dear friend, you are wright its 4G18 but cant see it clear and i just seen the following web and it also saying the same. http://www.dailytorque.com/proton-waja-16-my-ride-part-4-fuel-consumption/ For normal driving style, the below is the statistics : Driving Conditions : City driving, drive time mostly less than 15 minutes to destination, depending on traffic. 8.1 Km / Litre Driving Conditions : City driving, drive time mostly less than 30 minutes to destination, depending on traffic. 9.2 km / Litre For more spirited driving style, the below is the statistics : Driving Conditions : City driving, drive time mostly less than 15 minutes to destination, depending on traffic. Constant pulling of all gears to 5000-6500 RPM 6.5 KM / Litre thanks you for ur valuble comments.
it is campro 2001 model auto if its 8 in city then how about long distances travelling
dear all if anybody use proton waja auto car could u tell the fuel economy as when i search on net it says 7.68l per 100km but is it practically ok let say i buy a use one then surely the above fig be less but the range i want to know pls anybody have let me know thanks all .
Car Cover
only matter is at night due to temp low some moisture on the car body and the day time due to the cover this moisture cant evaporate and it goes down and sometime settle in doors or other parts and finally corrosion starts so better to cover remove at day time to keep car warm then the moisture evaporate this happened to my previous car sometime ago .the other thing is some covers are not durable to sun (uv) and melting at heavy hot days and it will make patches on ur car and difficult to remove to when select buy good durable one.
- Service Station In Kadawatha Area??
Belts Sounds When Start At Morning
yes seems belt karavela when putting water no sounds so to be replaced belts.
Dear friends, pls let me know the reason for the following thing when start at morning there is a "kreeek...." sound just 5second and then normal its i think belts sound but after the first start it never happen wholeday but next day morning it happens what is the reason? somebody told me belt dried and put some water to belts before start i seen this some private busdrivers doing at morning. Is belts overuns and wearoff or loosen but it happen only at the morning. thanks you all hope me to correct this.
