Everything posted by Muditha420
How To Fix The Center Arm Rest Cup Holder Issue On Subaru Legacy's
This is what I’m referring to... Right got some chow and I am back!!! Step 1. Remove the cup holder. There are four screws holding the arm rest remove those plus another two inside the cup holder mechanism, almost forgot one other screw holding the cup holder rings to the front lid. This will allow you to easily remove the whole assembly apart easily. Step 2. In my case after staring for a while I found out someone who removed this console ions back had actually assembled it back in the wrong order and this was preventing the top latch of the cup holder from firmly closing. So I managed to fix it properly this time and abracadabra it’s all working okay. (Note: the cup holder unit should go from outside into the armrest unit and not the inside, this wont let the latch close properly) I hope this is helpful… Enjoy! Credit goes to [email protected] plus me
Now the fun bit, you'll need to take EITHER your old metal rod (IF you find it that IS) OR your paperclip (Have one more paperclip as backup). If using the paperclip, cut to size and bend both ends to match the above picture. Its length should be that one end fits in the small hole shown below, and the other end sit in the very end of the groove in the mechanism (lid fully open position). In my opinion have the end that fits to the mechanism (OR lid) just 2-3mm from the end and have it bent. Step 7: You can see what I am on about, the small hole near the bottom and the groove in the spindle where both ends of the rod sit. Step 8: Refit the small retaining plate. Now, the following picture shows how I believe the plate is fitted from factory, however, I tried this and found the opening mechanism wouldn’t work, so I ended up fitting it so that the whole plate sat ONTOP of the rod, holding it in place... which worked for me. Try BOTH ways before putting it all back together. (I am keeping this exactly same as the author coz it might work as he say both ways but I too had the plate fitted over. Step 9: Refit the larger retaining plate and again, try out the mechanism. If you've used a paperclip, you may need to experiment with the length to find what works for you. Step 10: Once you're happy with it, refit to the interior. Step 11: Try out your cup holder in a real world situation... marvel at your working interior as well as your handiwork. NOTE: before you do fit everything at its place have them cleaned without fixing everything like a spanner with years of dust and other whatnots. Now, I have another issue with my cup holder which you may or may not suffer from... the mechanism on the other side of the cup holder that controls the two 'flaps' working in unison. I finished my rather “Alwathura tea” now and gonna get something to eat, so that fix will come later as well...
Step 5: Remove the first retaining plate (darker metal) and you'll be left with this... hopefully. Now, there should have been a small shiny metal rod, no thicker than a paperclip (Sown below is what it might have looked like but this is the one replacing it now). I never found it even though I combed through the entire place so probably MIA. THIS was the offending item in my case as well, I can only presume due to wear and tear it became dislodged. Step 6: Remove the second smaller retaining plate which looks like this:
Found this thread on uklegacy.com http://www.uklegacy.com/forums/index.php/topic/130098-how-to-fix-gen3-jdm-cup-holder/ credit to this guy for doing this… I went a step further with all around images with his thread and images as well as my own. You will need: Cup of tea (I had to as well… what to do it was my tea time) Phillips headed screwdriver Paperclips (possibly) Pliers Step 1. Sip the tea Lol…. Step 2. Remove the center console area which is easy. 2 screws located under the armrest lid, a further 2 underneath the gear stick surround (Top most corner). Carefully remove the center console trim show below. IF it’s a manual tranny hopefully it should be the same technique. Start from the bottom corner of the trim and gently lift them up Step 3: Remove the cup holder and mechanism from the trim. 3 bolts in total underneath. Step 4: Yup I too had to stare a bit to wrap my head around how this was to be done. Sadly found that a piece of the cup holder was broken off (the bottom half of the lid) but for now needed to have the open flap fixed.
Why Vezel Is Bad?
This is some funny sh** i have read for awhile now "Btw not many JDMs produce 150bhp to be honest right" aiyye galak yatada gahak udada hitiye??? should not time travelso much it messes up ur mind... i have a JDM car machan should try to see if i can least keep up with a Weasel so i can brag to me mates...
Great Places To Eat When Driving Outstation
@KingSasanka - Well not sure if i did this correctly but here you go... the other place should be up the road a bit. https://www.google.lk/maps/dir/Moratuwa,+Western+Province/Mayura+Restaurant,+B254,+Matara/@6.3731001,79.9253265,10z/am=t/data=!3m1!4b1!4m13!4m12!1m5!1m1!1s0x3ae2450af2b3b63d:0x4bd5b87e09abb3c7!2m2!1d79.8912813!2d6.7880706!1m5!1m1!1s0x3ae13929f38020fb:0xec512ee5f06a87cd!2m2!1d80.549755!2d5.943251?hl=en
if you are travelling to Ratnapura and there is a place called "Concord" towards Dela, Nivitigala side... So far excellent food n service. Another place is "Mayura" in Matara (have to take the sea side road for this) ... no complaints yet on that too
- How To Get That Stunning Wet Look?
VVTI - not till the polish bubbles mate just enough to see that glow effect the polish makes when exposed to the tip of the candle flame.... if you stay till it bubble bauma thamai sapaththuwata... you can get a good shine n make it last with a bit of cotton wool soak it in water n rubbing it in circular motion
- Fog Light Bulb
Toyota Carina Gt
Yeah... the 1st owner has completely done her up at Senok and turned to a B4... service and maintenance all there at the agents
Toyota Carina Gt
Thanks guys... Will do, I guess will hijack my own thread or create a new and have the goodies posted. yup its a TT. Not fiddled about or anything as far as i can see n check, just the way i like it
Toyota Carina Gt
@Jor-el - Meet the new ride... http://
Toyota Carina Gt
@nsiva - In terms of body panels and interior panels its all the same the hardest of them would be to sort the lights to your specific model year. Coz both headlights (Black line outter rim of the light) and tail lights have a black base at the lower part of the light. this purticular problem you dont have in the 96 model. when it comes to engines, you can't except to walk in to a spareparts shop and get certain parts for the 4AGE. you can find these parts in an around Kurunagala and Nugegoda too had places to source them. @iRage - yeah she isn't with me now, moved on to another more different sorta animal
Top Gear/fifth Gear/jeremy Clarkson Videos!
and for those who prefer a link to say download this.... K**ka*s torrents do have the goodies
Hmmmm Sound From Razors
you might wanna do a bit more explaining on this matter.... if its the bearings can be done for about 3k
What Can I Use To Remove Double Side Tape From A Bumper
The Don has a point there.. had to remove and reattach the car window visors, hair dryer method worked
1968 Datsun 510 Sedan (Project Datto)
Adeee Finally some thing to look forward to n read i think i like the dusty images better now...it tells a story of sorts
- Obd Port Type
Getting A Full Diagnose Done For A Nissan Tiida
You can go to CarChecks or even the Agents like The Don mentioned. i did go to CarChecks once they went through a test drive and hoisted the car up, checked with scanners etc etc... i got a 5 paged report on the car so. cost around 2500 for the entire procedure. if it was me would check from both these guys coz a second opinion is always better when u dishing out millions to buy a car that might end up being a flop
New Car 2Mn Budget
you might wanna take the Viva Elite out of the equation, few cars that i know of n decently maintained seems to be falling apart, oil leaks, A/C problems. well might wanna have a double take on it just to b safe
- Katukurunda Drags '14
Best Toyota Hybrid
Mwahaha Weasel i always use the name when anyone wants to talk about it.... but in all seriousness that damn thing is kinda futuristic inside.... from my little dabble n test drive of the Prius...it is roomy n you can play a little softball match on the dash too.... eerily quiet except for the tires giving out a low hum aint all that bad. But, its not anywhere close to any sort of driving pleasure though...its like a monk humming its way along the road, compared to my 4AGE screaming the nuts off when caned
Best Toyota Hybrid
have to say both replies are good options... put a Aqua or in other words a Prius C in to your list
