nano31
Everything posted by nano31
  1. Just gotta know that the pump is available at reputed automobile spare parts shop and the price said to be Rs/7000~10000/=. Have u all got any info about the good brands?
  2. [http://imageshack.us/photo/my-images/99/59491206.jpg/] [http://imageshack.us/photo/my-images/716/17052574.jpg/] [http://imageshack.us/photo/my-images/840/70924413.jpg/] "I was not that lucky" It is from the water pump; as u can see it the photo's I have uploaded (Taken today it self during my diagnosis process, just see that white marking, u can see green coloured fluid). Luckly it starts leaking fluid after 2 weeks. So I will be replacing the water pump during the next week. Lesson here to learn is that; if cold stage coolant leak ever noticed the number one is to exclude any water pump problem.
  3. @riddle, Thanks for reply. But the leaking spot is quite unusual to be from a tube but I too hope it would be from a tube lol!!! U too had the same car? leaking from the same area? only in the morning?
  4. I too now realize it is from water pump. Since it is from the water pump area and it is just cold leak only. Though it aint leaking every day only once or rarely twice per month, since it is related to T belt I think it should be replaced asap & otherwise it would cost me an arm and leg!!! T belt was repaced less than 8000km (at 159000km by the previous owner and it was mentioned in the maintain book with all bills and all and I have confirmed it ) back so I think I might reuse it aint it? Have you got any idea about the price of recon/used water pump?
  5. @ harshansenadhir, Thanks for the quick reply. Just for my clarification, Is the water pump/pump's pully inside the engine side cover? Is it better to replace with recon/used one or is there anyway of repairing by replacing the bearing?
  6. @ jdnet, Yeah, I should but my problem is why it is happening when the engine cool or not when the engine is running or when it is hot?
  7. @ nexus, Nope my friend, It aint from the radiator. Leaking spot is away from that and atleast no chance of tracking the fluid via the plastic covers.
  8. 1997 Corolla CE110 (Diesel) Facelifted, Automatic Transmission. The car had it radiator replaced 3months back due to leaking fluids and was replaced with used but very good condition one and I got it checked professionally by pressuring it up with water and installed and by far it works okay; no over heating, no coolant level reduction. But I have noticed nearly 10ml of coolant under my car early in the morning soon after starting up the engine (before starting the floor is completely dry). This happen only once or twice per week and no apparent reduction of the coolant level noticed. It was from the side of the engine where all those pully are attched (Side Engine Cover/ the T belt side). I checked several times with vehicle parked and engine running at hight RPM, after long journey, etc but then it was not leaking. This only happen early morning (engine not heated up well) soon after the starting up not there after but no apparent reduction of fluid level over few weeks even after journey in to the hill country. Unfortunately I have no chance to check when I was under the car and some one starting it up for me!! It is definitely not from the radiator as the leaking spot is some what far away. My problem is why this only happen when the engine is cool not when it is hot!!! Is there any possibility of it is from the water pump (it is at T belt area?) if so why it aint leaking when it is hot where leaks are prone to happen when hot. "It is just like the engine coughing out some coolant in the morning!!!"
  9. My personal advise is to go for AE100 SE Saloon, Limited. Dont go for the Sprinter as it has low resale value comparing with the corolla and the body parts are bit hard to find but actually there is nothing tecnically wrong with Sprinter actually it has better trim level as well It is just low resale value and body parts!!
  10. It was not my car friends; but this happened at my brother's service station so I was there. Wat they did was they just did some hot-wiring and "unlock" the system and reinstall the barrel. it works fine there after but I am not sure if all those security functions did worked there after. That car had the finger-print identification function yet it was never activated or used They said this might happen then you try to switch off the car while the auto gear not in the "P" position. The place is Sujith Electricals Matara (0412229016) (@ godwinAmila, I think you are from Western Province so this info might not useful). I think Passo if famous for this key problems!
  11. I too have seen this problem in a passo of one of my friend. When u put the key and try to start it feel like the key cylinder is stucked and a red coloured indicater (a small car with key inside) is on and the auto gear knob also stucked. They call for an auto electrician (Sujith Electricals-Matara)and they removed the key cylinder and it was unlocked by doing hot-wiring. It was just 15min job but I felt they charged too much (Rs4000/= might be because they had to travel 30km but i feel it is still too much, but their works are very good )
  12. keep the 121D
  13. Brandnew one cost around 12000/= at "Samarasingha" u may give a try at Delkanda for used one
  14. I am not an expert on this field but what I should advise you is that it is going to be some expensive project and would definitely lessen the second hand market value (when comparing with CR51 4WD). I personal advise is to sell the CR51 and buy CR41/42 or 27 "lotto".
  15. Thanks a lot mazdaspeed, LashNeo!! I would keep those info as i might need them in the future!
  16. Could anyone help on this please?
  17. Sorry for the delay, I my self removed the auto box's oil sump and ATF; the filter is almost clogged, Cleaned and dried with petrol and reinstall and filled with new ATF, problem is solved!!
  18. I saw one Mercedes Benz (E) and Land Rover with it number plate "JAZ (XXXX)" recently in down south Sri Lanka ! What are these number plates?
  19. someone is asking about the radar detector yet ppl are talking about prius , speed and kmpl!!!!
  20. My car is CE110,auto 1997 (crystal light), I usually drive less than 10km per day and with that km, it does only 9~8kmpl, I too shocked with that figure yet I myself confirmed that it does 15~16kmpl in long run with AC on
  21. @ Ripper, Dear friend thanks for your help! I myself contacted the wheel alignment guy (I personally know him), he told me just not to worry about it if there are no problems like uneven tire wearing, poor handling (car prone to move either right side or left side). According to him, if there were major accident causing this problem, they wont be able to do the proper wheel alignment an all. So I just forget it, (actually there is less than half inch difference between center of the front wheel and the center of the rear wheel, comparing with both sides)
  22. A word regarding "Batta", Once I myself checked a batta's head lights thinking that they might not be having low beam but surely they have. I noticed few problems with batta, 1.Most of batta are owned by the peoples who owned vehicles like tractors and they just don't realize about the low beam. 2.When the batta is loaded it's face goes up and then the low beam no longer effective. 3.They are equipped with high wattage super white bulbs. Most of the peoples who are driving three wheelers are low educated, so we should not expect much from them; the same apply to those cheep Indian motor bikers (shifting from push bicycles to motor bikes) as well, all of them are deserved to have big damage when they face an accidents. By the way I have noticed some car advertisements indicates HID lamps for some axios, allions, hiaces, do they only have hid for the low beam only?
  23. A word regarding "Batta", Once I myself checked a batta's head lights thinking that they might not be having low beam but surely they have. I noticed few problems with batta, 1.Most of batta are owned by the peoples who owned vehicles like tractors and they just don't realize about the low beam. 2.When the batta is loaded it's face goes up and then the low beam no longer effective. 3.They are equipped with high wattage super white bulbs. Most of the peoples who are driving three wheelers are low educated, so we should not expect much from them; the same apply to those cheep Indian motor bikers (shifting from push bicycles to motor bikes) as well, all of them are deserved to have big damage when they face an accidents. By the way I have noticed some car advertisements indicates HID lamps for some axios, allions, hiaces, do they only have hid for the low beam only?
  24. A word regarding "Batta", Once I myself checked a batta's head lights thinking that they might not be having low beam but surely they have. I noticed few problems with batta, 1.Most of batta are owned by the peoples who owned vehicles like tractors and they just don't realize about the low beam. 2.When the batta is loaded it's face goes up and then the low beam no longer effective. 3.They are equipped with high wattage super white bulbs. Most of the peoples who are driving three wheelers are low educated, so we should not expect much from them; the same apply to those cheep Indian motor bikers (shifting from push bicycles to motor bikes) as well, all of them are deserved to have big damage when they face an accidents. By the way I have noticed some car advertisements indicates HID lamps for some axios, allions, hiaces, do they only have hid for the low beam only?
