Cyclist
Everything posted by Cyclist
  1. Thats what I did too I had to do a quick stand and sit back at seat at the same time I release the clutch too. Thats adds some more weight on the rear tire for better grip. Guess that's the normal practice
  2. Thanks Ripper, I'll look for a genuine one. And here it is all mechanical / electrical parts perfectly working.
  3. ///i've been using armorall windshield washer fluid for a while. pretty cheap and does a darn good job. Rainy season, i use rainX as an addition. On heavy downpours it really helps./// Ripper , where I can buy rainX mate? I cant see sht on heavy down pours.
  4. I got most of the things fixed and it is roaring now Here are the costs so far, hope some one will find these useful when repairing there ax-1s. Many of the parts are from Panchikawattha breaker joints, I can give contact numbers if anyone requires. Anything on the ax-1 is so expensive as if its made of gold! starter motor armature - Rs. 5500 Starter motor carbon brushes - replaced with GS125 brush set - Rs.750 Oil filter - replaced with a Bajaj Boxer Oil filter : ~Rs. 60 Replace starter reduction gear wheel + idle gear + needle bearings + washers- Rs. 5000 Replace starter clutch + fly wheel + starter driven gear + needle bearing - Rs.15000 Repair radiator fan / thermostatic switch - ( they worked after cleaning and proper installation ) Lubricating and de-rusting Wires, fuses , insulating, bulbs and fixing cracks in the plastics New handle grips n chest guard pad - 1000 many other small parts such as nuts and bolts , washers Tires ( 15K) / Paint (?) / rear shock ( 18K!) / chain n sprockets (?) still to attend to. Loved when everything worked smoothly after all the effort. Had a nice ride about 20kms of Urapola - Ruwanwella road which is very close to where I live. Absolutely thrilled about the ride! Looking forward to a longer ride soon.
  5. Hi Ripper, got myself a AX-1 last week mate, its in a pretty bad shape as it wasn't taken care well at all and lots of things are not working! but the Engine and carb are superb , so I think rebuilding it would worth the effort and money. I will update here when its completed Things to be fixed Replace starter motor armature ( shaft busted) Replace starter reduction gear Replace starter clutch Replace / Repair Silencer Replace / Repair Rear shock Repair radiator fan / replace thermostatic switch Replace tires with Dunlops Lubricating and de-rusting ! Electricals, fuses , insulating (new paint and stickers) etc !
  6. Hi people, I'm planing to buy a comfortable diesel van than the currently using Vanette C22. My budget is 2MIL max, I found there are few good looking Mitsubishi L400 space gear vans in AL. I did some study about it on the net also. Please advise me , on the reliability and the running costs of this vehicle, know problems , spares availability etc. thank you.
  7. Thanks Ripper, I'll be watching for that. anything else ? any owners ?
  8. Hi Guys Im sorry if this is in a wrong section, Im planning to buy an Honda AX-1 motor bike.. I found a decent quality one for near 200K registered in 2009 with 14000 on the odo. If there is anyone here who owns one or knows well about this bike, please let me know what are the thing to look for before buying it? Thanks
  9. I think it still is a Cat with some kind of heating mechanism to get it to working temperature as soon as the engine starts.
  10. Yes,The majority of people in SL have middle or low income , so its logical for them to get a vehicle for fits the budget that fills the basic requirement.
  11. This type of accident can happen with any vehicle. its completely drivers fault and has nothing to do with any eco-friendlyness or being a hybrid or a prius. This looks like a bed time story written for Prius haters!
  12. Don't know about any seller in SL but you can get one from ebay at around USD 60 . check this one http://goo.gl/tSZDE
  13. Cyclist replied to Bugatti's topic in The Lounge
    Hey VVTi, I think I may know you ! Do you know a "sniper" by any chance? Sorry If im mistaken
  14. thanks man, I'll give a try in the weekend and let you know the results
  15. Very informative Jdnet, any idea on how to remove paint dust on a dash board ? my vehicle was painted long ago without covering the dash board properly. white paint dust has been all over the thing.
  16. those parts are getting rarer for these oldies. I think no more old vanettes there in Japan even to sell for parts now lolz
  17. hey, new drama today, when I went to the garage the mec has fitted the things after correcting the mis-align himself. He has removed the welding spots and re-done it himself ! Did a trial about 10 kms at various speeds and places , all seems to be ok. now I dont feel like I need the original parts , but feels like I've cheated the vehicle thats cool, its wonderful when you can select the drive, isn't it ?
  18. Yes Friend, as you suspected its the universal joints. Just one uni. joint was worn out. Bought a new one for Rs.1300 and had it fitted to the shaft by an engineering shop. Best part happened next, when it was given to the mechanic to fix it to the vehicle, he said its not done correctly by the shop. The bugger at the lathe machine (was in a hurry to go home see the match ), had not centered the joint to the shaft! Mechanic says there is about 2mm mis-align and would give a vibration at high speeds. if fitted like this. ( the problem I had was vibration at low speeds ) Then the time was 6PM and everything postpone to tomorrow. may be it will be needed to do everything from the start again as the uni-joint caps are steel welded to the propeller jaws to prevent it from coming out. This was done after boring the jaw to accommodate the new uni-joint using a seamer. The caps were fitted to the jaw using a hydrolic press machine. I think this is pretty messed up now. I'm Thinking of buying the whole thing from a recondition spare part place and fitting it. Hate travelling on bus and with the propeller shaft in hand its going to be a funny day tomorrow . All this trouble because my father is sick these days . otherwise bugger would get these done for me as he did all these years , anyway time for me to learn the trade now thanks all , will be staying around , there's lot to be learned from this forum and good people. cheers
  19. I will have to reinforce my vanette with some old "rail peeli" before taking on this express way
  20. Guys, Managed to show the van to a mechanic , the guy wants to remove the propeller and see the uni. joints and other stuff to diagnose.. nothing else to do, Im going to let him do it tomorrow. Thanks for the support.
  21. Ripper , Its a diesel engine. Will check the gearbox mounts. thanks
  22. yes, I had the injectors serviced about one month ago. Nozzles were good. Just 1 had lost pressure a bit, which was corrected.
  23. Hi nexus, it happens with ac too. its like more like "gassenawa". වෑන් එක පික් අප් කරන විට ගස්සනවා. බ්‍රේක් කරල නවතින්න ලන් වෙනකොටත් එහෙමයි. හරියට ක්ලච් එක දුන්න මදි වගේ. Sorry for my poor English.
