7
Everything posted by MV-5
This is not true. if this engine has no other problem, then best option is to replace the head gasket. engines from this era probably has cast iron block and aluminium head, so overheat and/or sudden cool-down might cause to slight deformation of head surface. normally in gasket replacement process, head will be refaced.additionally valve seats will be cleaned up. this is 8+ hours task (full day). so best option is just to replace the head gasket.
i have been using a 323 (YOM 2000 ,ZM-DE engine, MT) for 11 years (from 2007). still it is my primary car.
probably it is bad starter solenoid. your ignition switch send the control signal/voltage, and starter relay/solenoid magnetized and do the mechanical movement, but still it does not connect the circuit. normally it is located with the starter.
- 7 replies
- 1
- starting problem
- starter mortor
(and 3 more)
Car loss power when after changeing Gear and Car Sudden jump
MV-5 replied to pradeepbuss's question in General
So the problem can be reproduced even without the a gear change, if you release the gas pedal and allow it to drop the RPM further down and then throttle it , then you might be able to clearly notice this. my guess is a miss fire (due to a problem in the ignition path). probably plugs, wires or coils.ignition coils related issue are more noticeable when engine is hot. fuel related miss fire also possible but not that probable. FYI: in a manual gear box just changing gear oil not solve this kind of problem , so dont do that, if it is necessary you may do it once your problem is solved. -
C*r checks vs agent , both have their strengths in different areas: Ex: Mileage = no one can (there are some European models that even we can find out the actual mileage) Structural damages and imperfect accident repairs = C*r checks Some internal problems like gear box issues = No one is good, but agent is better other critical components like AC compressor, radiator and cooling system,alternator,PS system = no one So if the car has been maintained at agent , then they have more information about the car history, that is an advantage. otherwise i would prefer c*r checks. there was an incident that c*r checks said the alternator is weak in a car (but actually what happened is there was a history error code which says battery voltage is low, so they assumed alternator is weak, owner has recently replaced the battery).
Range is not updated after fuel refill - Toyota Aqua 2015
MV-5 replied to mgtdan n9i8u's question in Electrical problems
how is this calculation done, is it based on the last minute fuel consumption,last five 10 minutes, or last hour fuel consumption or long term average fuel consumption? -
2000 MAZDA BJ5P 1500 AUTOMATIC CAR SUDDENLY GETTING STOP WHILE DRIVING.
MV-5 replied to cham094's topic in General Automotive
AFAYK is not important. -
first thing first. does your CEL work (you might think that CEL works properly but it might have been wired to another indicator to just to turn off when the car is started). If you are sure that CEL doesnt work (ex: it doesnt light when you turn the key to ignition position), then first thing is to rectify that.then you can perform a self diagnostic test using the CEL. if CEL doesnt work, then you have to find LED and a 1k (or up to 10k) resistor and perform the self diagnostic test. you may refer this thread to get some idea about how to perform this test in your case TEN should be grounded, no need to use an LED if you are sure that CEL works, then CEL will emit the error code. -
but never expect that just a cleanup (so called engine tuneup) will increase your fuel economy from 11 kmpl to 16 kmpl. lot of people think about thins engine tuneup when they feel fuel economy went down, but once they did this engine tuneup normally what they say is "now pulling power has been increased and idle is so smooth" but fuel economy is same.
I have test driven 2012 focus.shift shock is highly noticeable (might be normal for a DCT). sometime when you remove the foot from accelerator it quickly shifts down (if it is as designed it is a bad design, or might be a problem in the instance i drove). so when i came back (after test drive) i read lot about ford focus and most highlighted thing was unreliable Transmission Controller module. Handling is even better than Mazda Axela (very close).price was somewhere around 4.4 million , at that time 2011 (Spain) model was a better deal (price was around 3.2 million and it gearbox is not a DCT, so no need to wary about crazy shifting problem ). NOTE: I have never used a ford focus, so this is purely based on ONE test drive and internet reference so called car buying pre-study.8 months ago Softlogic had 2 used cars and same time probably they might still have few. anyway this was my preference based on test drives (and pre -studies) 2011 Mazda Axela > 2011 ford focus > 2012 Kia Cerato > 2011 Cerato >2012 Ford focus.
If i understood you , car boot door can be locked using the remote key but it can not be unlocked using the remote controller. 3 probable causes. 1. bad actuator (normally SL technicians say "return is not working"), so ac 2. Latch has a considerable resistance to unlock,so actuator can not unlock it . 3. There is unit which controls these signals,that unit might be faulty. -
- 10 replies
- 1
- trunk lock
- central lock
(and 1 more)
specially if it is a JDM i would also prefer Mazna. I doubt that Colonial even use the right fluid for CVT boxes.
i believe that that is as designed (for 4 speed gearbox,it makes sense ). but you better to wait till some member/s who use the same vehicle (at least same gearbox) give their input . speed is not the only parameter to decide the gear. but for me this is normal. other members who use a car with this gearbox , please add your comments and please help Ted to clarify this. again final drive axle ratio can be vary from car model to model , in fact it can not be considered as a fixed property for a gearbox model. but i don think that for you car model they have made FD ratio close to 4:1 which will produce this RPM at the top gear. but try to do some search and find out (FD ratios close 3 is somewhat common with this gearbox)
This gear box doesn't have any gear with 1:1 ratio , And AFAIK vehicle spedo meter doesnt know anything about tire size, it shows the speed based on axle revolutions and based on the preset constant which has been calculated for the stock tire size @Ted if your tire diameter is 24 inch (185/70x14) based on given values and this gear ratios still your gear box in 3rd gear if vehicle speed is 100 kmph vehicle speed in inches per minute = (100x 39370)/60 = 65616 number of tire revolutions per minute = 65616/(3.14 * 24) = 870.7 convert to engine RPM through 3rd gear ratio and Final drive gear ration = 870.7 x 1.296 x 2.655 = 2996 RPM @iRage please don't ask how on earth 3.14 came into this calculation.
engine is idle means engine does not transfer power to wheels, engine is completely decoupled from drive mechanism. so no relationship can be built in between vehicle speed and engine RPM. FYI, engine is idle doesn't means vehicle is stand still (shift gear to N when you travel, engine is idle but vehicle is traveling) and it is possible to keep a vehicle keep stand still with engine running but not idle (thats how manual gear car stay stand still at when you start to travel in a hill upwards)
if the ATF change has not been done (if it is due) , then that is the first thing to try. If ATF change has been done, then you may show this to a mechanic someone who is very good on AT boxes. There is a chance that problem one is due to a different root cause than the problem 2 and 3. but I also think that all 3 problems are connected and have the same root cause. my preference is Nilwala (not Mazna for this case, but ATF change can be done at Mazna)
If someone wants to know how Micro serve to their customers, there is Facebook group called Geely Pandas owners club sri lanka (i can not past the link here because of AL forum rules). you can see tons of negative comments. page admin has also faced the same kind of treatment , as an example i will write how he (admin) has started to post it in that FB page, <quote from FB> Dear <Removed - but this is the link of Micro page> People. I maintained my car through your company from the beginning of time on last 3 years. I wasted money, i wasted my time to stay whole day for a small service and even a small repair blah blah. And also last time i have done my 35k service in your cheating place too. I'm writing like this because what i faced today's situation. Today i went to my friends place to replace my iridiums. (Thanx to Mahesh you sent me the details about plugs and thats was helpful to me) So he checked the air filter, it looks like full of charcoal. It looks like not cleaned or not replaced from your services for ages. Then we checked the Throttle body, it filled with full of carbon and you guys still stay like dumb on services. Then we checked injectors as well and those all covered with full of carbon and all blackish and filled with dirt. What the hell you guys are doing in servicing vehicle? See the image attached below, when you remove the black engine cover, it was like "නාවින්න කුණු කන්ද". Even in a last 3 years, you guys never remove it atleast one time and put a vacuum or air pressure or seems you people not tried to clean the top mount engine ares. because there are too much dirt තට්ටු තට්ටු . . . ! So shame on you guys. what the hell you guys doing with our valuable time to waste full of a day and working with not trained careless workers? dont you guys have no money to get people to do the works and who love to work on these things? you guys just only doing the oil changing when servicing? really? Great. This is for your attention my friend <removed> and other members in this group. About that hell of place you putting your car in to services. Screenshot this and send to their higher management to see what the hell people doing in their place. They knows only eat in time, drint tea in time and stop the works at 4.30 in time. Thats all. Wasting our f**king time. Good luck micro . . .! Thank you very much my friend at <removed> who showed me all those things and showed few faulty things in my car that needs to repair soon. Thanx again.
No, theoretically there is an equation , if you know these parameters you can calculate the speed from RPM
it is very basic who knows how a conventional auto box or manual box works, in the same gear , speed is proportional to RPM. IRage , you are right , that is why engine stalls when you release the clutch in a manual car without balancing it. when a gear is fully engaged if the car speed is 0, then RPM is 0. i thought this need no explanation because it is so simple , i repeat ,for the SAME gear, speed is proportional to RPM when gear is fully engaged (no clutch slipping) you all know gear ratios and how power transmit happens and relationship between RPM and gear ratio and the speed and relationship between torque and RPM and throttle position, right? IRage, in this case , if this is a manual car if vehicle speed is reduced to 20kmph then RPM will drop down to 571, which you feel engine is going to stall and power is not enough to accelerate the vehicle because even at full throttle RPM 571 will not produce enough power, that why we shift down to second to get a good RPM and accelerate the vehicle. i guess you both are kidding
That is perfect. 70kmph probably it is in the top gear . so there is no gear change at 100kmph in this specific case. so (2000/70) x 100 = 2857
Thanks , this part help us to judge the validity of your whole comment.
You want us to select a car for you based on our requirements and criteria. No problem, it is Tiida.
How? so you think axle is mounted to the top of the Tyre.
find a ruler and get an idea about 6.5 mm length.
