Everything posted by MV-5
Odometer fraud - Real Story
this is not about this single instance. if you really want to avoid from these frauds , one of the best thing you can do is avoid any kind of re-seller (car sale or baiyas). some re-sellers doesn't event bother to remove the old classifieds (because they know buyers do not even pay attention to detail or information that they can easily access). but we should always seek for all form of information that we can access. ex: i was looking for a used Cerato, then i found a advertisement (in AL). just looking at the advertisement i knew it is from a re-seller. how did i identify and why didn't i call the seller? simple attention to detail, i normally go through these advertisements frequently (even without having an intention to buy a car). So i even remember the photo shoot locations. suddenly came into mind two advertisements i saw. you also can see those two advertisements still in AL (just search for the key word Jaguar XF) you will see two advertisement of same car photo shoot at same location.check the mileage. NOTE : i was looking for a used Cerato not for a Jaguar XF :-)
Toyota axio 2007 ac cooling issue
to be frank i don't know, but normally this kind of replacement do with a different model due to few reasons, 1. it is hard to find the original model or it is too expensive 2. original model is notorious for frequent failures (might be not suitable for condition in sri lanka). in both cases it is 100% OK to go for a different model, but only technicians who has loads of experience know the compatibility with the other components and what the components are that should be replaced to long last the whole system. My suggestion :ask them the reason to go for a different model. get the second opinion as well (or wait until a AXIO user (who came across the same situation) reply to this thread ).
that means when AC compressor rotates at high RPM it is capable to do its job. otherwise it can not. probably you have to replace the compressor (but 70K is too early to overhaul an AC system...) . what is the reason behind that they ask you to replace it with a 240 one (did they mention some durability issue related to the original model)?
Exactly, they can not do magic. if they can do this , there is only one way that i can imagine.it is : probably they might have contacts with agents service record systems and insurance companies (somehow). so the only possibility is contact these parties and get the highest recorded ODO value and the date and compile it.
Unusual Tire Wear
it is a fact that all your tires are 5+ years old (technically expired). but you said that rear tires are fine. anyway you have to change the tires. but it is good to check for bad tie rods (inner and outer both).
- Hyundai accent 1500 fuel conaumption
I would like to buy a car but?
I would take this as an advice. if it is only a "few rotten eggs" you will not be able to see a trend of advertising for dual clutch repair for these vehicles. just search that famous "quick site" (i*man.lk) for the text "dual-clutch-repair". within few months if you do the same search you will be able to find out more than 10-20search results. but still "quality repair work" will cost you.
AC gas leak - dashboard removal
it is straight forward to locate the leak, they call it "UV light". any auto AC workshop can do this if they have the tools. AFAIK refrigerant comes with the dye (if it is not they can feed it external). so they can first check the areas in the engine bay as you said. if all components in the engine bay is OK still they can proceed without removing the dashboard (in most of the cars i have seen it is possible to remove the cooler without removing the dashboard, then they can separately test it to identify leaks, normally this last part is done in a full AC service).
Buying First Car
This is what i understood (not sure 100% correct): there is way (but unfortunately can not be applied for JDMs ), check the first letter (or might be a digit) of the VIN (or chassis number). if it starts with "J" then it was manufactured in Japan (M=shared by few Asian countries including India)
Best Tyre Brand and its price for a Toyota IST
Yes (indirectly). uneven tyre wear (due to bad tie rods, bad rack ends or incorrect wheel alignment) shows lack of attention. so owner can not say it is a well maintained car.
Axio
No one will be able to answer your question unless you provide following information in very detail level. Those are, current condition of: 1. Engine and transmission 2. Body 3. Chassis 4. Exterior and interior 5. Steering system (rack,rack end , PS pump,tie rods) 6. Brakes . . 67. Radiator/water pump/other components of cooling system. . . . 101. Alternator . .
Interior lights failed
dome light is not so important, try to restore the footwell illumination at any cost.that makes your car cool. dome lights are common in every car, that is why it is not important.
- Nissan Cefiro - 230 Jm - Fuel Economy + Maintenance - Advice
Resistor for LED Lights (72W / 24V)
what is this 72W rating, it is not the consumption (12 x 2.25 = 27W), right ?
Hyundai Tucson 2011 Crank Pulley Replacement @60K
do you feel some excessive vibration or do you see some wobbling in crank pulley. don't know about Tucson,you can call agent service workshop and ask whether it is instructed to change (in service manual) the crank pulley at 60k km even though we cant see any problem (just like ATF change at this mileage, plug replacement at this mileage....). if you see any problem definitely this is something you need to attend quickly, otherwise it is not good to crankshaft and all other parts driven by this pulley.
Need a car between 2.1lax to 2.5 lax
in this case , since your max budget is 2.5 mil, then try to find the oldest and very bad shape vehicle with that price tag and buy it. if that kind of bad shape vehicle has a 2.5 mil price tag what that means.......... that car has a very very good second hand market, simple.
- Nissan nawara
Prius hybrid battety
so you think that in a used battery each and every cell has the same capacity and you think that a cell become a bad cell in a instance and before "that instance" it has the same capacity that other cell has and after "that instance" it is not. probably you might be right.my knowledge is zero when it comes to electricity or related stuffs.
KIA sportage Transmission oil change
If you are a car owner , then better to have the service (workshop) manual with you.so my advice is try to find the service manual and refer it.service (workshop) manual contains every detail related to your vehicle. copied form the service manual : <start copied text> NOTE: ATF of 6 speed automatic transaxle doesn't need to be replaced. If the vehicle is used severely in business or personal use, replace ATF every 60,000 miles. Severe usage is defined as • Driving in rough road (Bumpy, Gravel, Snowy, Unpaved road, etc) • Driving in mountain road, ascent/descent • Repetition of short distance driving • More than 50% operation in heavy city traffic during hot weather above 32°C(89.6°F). • Police, Taxi, Commercial type operation or trailer towing, etc <end copied text>
Ford Laser - ABS & Hand Break indicators
c1175 is error code 14 (one long flash + 4 short flashes) and LashNeo has shared (link) the procedure (steps mentioned in the workshop manual is bit different) that should be followed to troubleshoot/fix the issue.unfortunately not even car mart follows this procedure for this error code. this is not a DIY because i don't think you have the right SST (49 G066 001). But as LashNeo said, check the connectivity first.
No, for wheel speed sensor failure, it would light on the ABS indicator only or ABS light with the handbrake indicator. it depends on the error code, but the root cause might be the same. ex: error code 11 = Circuit failure of RF ABS wheelspeed sensor error code 41 = RF ABS wheelspeed sensor and/or sensor rotor malfunction error code 45 = RF ABS wheelspeed sensor input signal missing in these all cases probably it is the RF wheelspeed sensor that we have to clean or replace (if it is 45 , just cleaning the sensor will not help, it might be a bad sensor or or problem in the wire connection).
AC PROBLEM
BJ5P, i think your car is more than 15 years old. when did you do your last AC service?
"blinking"? could you pls attach a video , i haven't seen ABS indicator is blinking. if indicator doesn't say problem about ABS Controller module , no need to replace that. just replace only the wheel speed sensor. best way to get a genuine ABS sensor is amayama.com (it cost me just around 7.5K LKR, but mazna asked me 13K for a genuine brand new and 7K for a used genuine). if you order this online , find the right part number using the part catalog, rear left and right part numbers are different. If you are a DIY guy, then this is a very easy job (read the service manual, you have to remove the rear seat as well). i have uploaded a video about ABS self diagnosis.https://www.youtube.com/watch?v=LYoYvhF7mc0 there is attached PDF in that video that you may refer to decode the error code : https://drive.google.com/file/d/0Bw6iDMN3PxtnRUoyelVNQTBDZVU/view?pageId=110512347860950658930 EDIT : this image was taken from my order history from amayama. this part number (green color box) is for RR for Mazda 323 2000 (might be the same part number for Ford laser RR ABS wheel speed sensor).
Ford Laser 2000 - Manufactured in Japan or Singapore
I think it is because Mazda (manufacture of this Ford) doesn't follow the conventional format of VIN. Convention is that 10th digit (char) should be used to represent the manufacturing year. Mazda doesn't follow this .but what i understood is (might be wrong), after first 9 digits/chars , all the rest of digits represent the sequential number. in that sequential number first or second digit represent the assembly plant. if your VIN number 10th and 11th digits are "0" , then i think that it is assembled in a plant in Japan.but i don't know which digit exactly represent the "plant" (10th or 11th) you may get a better idea referring this: http://www.club323f.com/forum/viewtopic.php?t=11344 EDIT : i searched the net , now i am sure that it is the 11th digit and , if 11th digit is 0, then it is from Hiroshima plant.
