Everything posted by Magnum
Autolanka Funniest Moments
Probably the bonnet was removed without marking the original location to fix at the hinge
The bonnet is misaligned cuz of the aftermarket lights?
- ## Post Whoring - Part 3 ##
Japanese Car News
Yep people looking for a vehicle in the rage 5-6mil will definitely consider this over the vehicles you have mentioned. Also though this isn’t a competitor of CHR, I think it would eat into the CHR market in SL
Japanese Car News
Looks nice with the Modellista kits
Good Tyre Brand....!
If you do a fair bit of long distance stay away from the cheap Chinese knock off tyres. As Devinda mentioned, loads of R&D and testing go in to those expensive tyres. All tyres are black and round but they aren't all the same, those expensive tyres are expensive for a reason. Those quality tyres make a massive improvement in emergency braking distance and general grip levels. In addition they absorb minor potholes and imperfections better than those cheaper tyres. Watch this:
- Best place to find/Anyone have wheel center caps?
You can buy them on eBay. You need to search using the diameter- [Civic 2018] One year later...
If you think my van is low then you should see my friend's one Have you got any mods planned? Yellow fog lamp overlays looks good on these- ## Post Whoring - Part 3 ##
- GT Tyres
Try Kumho or Hankook or Sumitomo. i think Hyundai and Kia vehicles come with Hankook tyres from factory as well Sounds like they are all season tyres, I think SL weather requires summer tyres. I know someone who recently bought these tyres, will see how they will perform.- GT Tyres
- GT Tyres
Does that mean it’s like a winter tyre? I thought those were sort of like all terrain tyres.- Japanese Car News
Nah, I’m not a big fan of this design, maybe it’ll grow on me as time goes by. It’s anyway too big for SL roads- Japanese Car News
Makes sense, I just checked the specs of Alphard and this is much bigger than the Alphard in both dimension and weight.- toyota prado 150 tire pressure for srilankan road conditions?
Whats the make and model of this tyre?- Japanese Car News
Toyota has planned to introduce new van to the Japan market as GranAce, which is basically the Granvia sold in export market. Its a passenger version of the 300 series Hiace. The van is 5300mm in length, 1970mm in width and 1990 in height. It will be offered as either as six or eight seater. The power plant under the bonnet would be the 1GD mated to a six speed transmission. Toyota hasn't confirmed the power figures, however I assume it would be similar to the Granvia(130kw@3400rpm and 450nm@1600-2400rpm). I expect the weight of the van would be between 2600-2700kg. It would be interesting to see how this would fair in the Japanese market, it seems like it would eat into the Alphard/Velfire market. Note: This isn't a replacement for the Hiace 200 series, This is more like bringing back the Granvia/Super Custom, Sometime back Toyota confirmed that they wouldn't introduce the export 300 series to the Japan market but instead continue with the ongoing 200 series(Its probably because its too big) for now. https://global.toyota/en/newsroom/toyota/29933304.html- Japanese Car News
The 1L variant would be super popular in SL- toyota prado 150 tire pressure for srilankan road conditions?
It's the same rating everywhere, in the past tyres were using layers of plies, higher the ply, stronger the tyre. However, modern tyres are made using other materials hence now we use a 'load rating index.' Load rating is mentioned in numbers, you will find it after the tyre size. For easy reference tyre shops in SL match the load rating to the old ply rating, for example 98 load rated tyre would be similar to a 6 ply tyre, the tyres on my Hiace are load rated at 104/106, the tyre shop told me it's a 8 ply tyre. The 265/65/R17 tyre you came across probably has 4 layers of ply in addition to other materials because 110-112 load rating is equivalent to a 9 or 10 ply rating- toyota prado 150 tire pressure for srilankan road conditions?
I get what you’re saying, a stronger tyre will be harder, but if I’m not wrong modern tyres don’t have plies, in Sri Lankan people match the weight rating of tyres to old ply rating. Only way to find out is to try two different tyre sets on same vehicle one after the other and compare the comfort- toyota prado 150 tire pressure for srilankan road conditions?
Is this true? Some people fix lower ply tyres than the original ones on SUVs and Vans in SL believing it’ll increase comfort. I’m not sure how true this theory is. i believe Prado will have 8 ply tyres- Shifting to N while the engine is running
If I’m gonna sit for like a minute at a traffic light I shift to N and apply the parking brake. I don’t think Shifting between gears often will damage the gearbox but it will wear out a small washer behind the gear selector. I have seen that happen once on a van but then again that was a rented van and it had a gearbox issue, D was stuck in 3rd so you had to shift between 2 and L. Doing that often probably wore out the washer. It’s not good engage park before engaging the parking. The loud thud you get when shifting back to D is the sound from the gearbox. When you shift into Park before applying parking brake, the gearbox holds the vehicle in place rather than the parking brake. - Best place to find/Anyone have wheel center caps?
